Community Helping Community
3800
Highlighted
Beginner
Whitelist / Blacklist Group
     I just purchase the Cisco 892 Router to add to my network.  The main usage for it is white/black listing.  Is it possible to have a group of 5 computers to have access to everything on the web and a group of 15 computers to be blocked on every sites and ports (msn, bittorrent,...) except 2 websites?
Best regards,
Tommy
Everyone's tags (5)
2 REPLIES 2
Re: Whitelist / Blacklist Group
Best regards,
Tommy
Hi Tommy,
Yes you can do by creating acl for ip which want to access everything and acl for which needs to be blocked.check out the belwo link hope that clears out your query!!
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00800fc176.shtml#markinboundhacks
If helpful do rate
Ganesh.H
Also you might want to consider content filtering on the router. It is build for content filtering.
here is the feature http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6643/white_paper_c89-492776.html
And here is the sample config http://supportforums.cisco.com/docs/DOC-8028
I hope it helps.
PK
Content for Community-Ad
FusionCharts will render here
