Best-Practise for Switch-Profiles with Nexus
Marcel Kamenz
Hi everybody,
if got a short question how you doing the switch-profile configuration with Nexus with switches.
The situation is easy, two Nexus 5672 connected via peer-link and a bunch dual-homed FEX's.
So what you're doing first? Import the whole config into the switch-profile or only the configure the interfaces that needed to be synced?
My question is what to do if there are some interfaces at the parent switch that not needed to be synced and should stay local?
So there is a bit of local configuration and synced configuration.
My testing shows that there are some commands that need to be in the switch-profile for the mutual exclusion checks.
What is your experience with switch-profiles?
0 Replies 0
