C220 M5 with 1387 VIC wont connect 40Gb to Nexus 3132Q
asta17
Beginner
Beginner
Hello, I've been trying to get my two C220 M5's to connect to my nexus switch for a better part of two months. When connecting the cables together no link will ever come up. I've set the speeds on both sides and tried auto speeds. Nothing seems to work. The only thing that does work is a QSA 10Gb adapter to the nexus, only 40Gb doesn't work. I do have a Dell R730 that will connect 40Gb to the nexus. Is there anything special that I should be doing? Cisco's website says this switch and cable is compatible with both the 1387 and the nexus.
I’ll be moving this to the Data Center part of the community as it’s not related to Collaboration.
Response Signature
