Data Center Interconnect - Layer 2 Extension using vPC
lomonaco
Hi, I wanna if possible try to validate the design to connect 4 nexus 7010 to permit data center interconnect and layer 2 extension using the same vpc and the same port channel number and only 2 links between them as showed in the attach ppt
  Is anybody using a design like that ??
e-chuah
this will work if it is *only* layer2 between the two pairs of N7K. You cannot create a L3 SVI and attempt to route it via the vpc port channel. It won't work.  If you need both L3 and L2, one option will be to use OTV.  Rgds Eng Wee
