Beginner
Is Nexus 7009 supported in Solarwind NMS
Is Nexus 7009 supported in Solarwind (NPM) network management solution for SNMP poll?
Can we read the CPU utilization & environment monitoring of Nexus 7009 through Solarwind NPM?
4 REPLIES 4
Please find attached the
Please find attached the document from solarwinds website.
I hope this helps.
Engager
Hello iftahmed, the question
Hello iftahmed, the question was about CPU utilisation and environment monitoring, not netflow.
Rehan, yes you can, use SNMP here is my sample I use Orion NPM to monitor N7Ks as well.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Highlighted
Beginner
What version of solarwind are
What version of solarwind are you using?
Can we monitor the environment (temperature) of N7K in solarwind?
Engager
Hello Rehan, we are using
Hello Rehan, we are using Orion NPM 10.6 - yes you can monitor the environment temperature, as you can see from the screenshot in my previous post.
Hope this helps.
B
Content for Community-Ad
August's Community Spotlight Awards
