02-10-2015 12:51 AM
Dear All,
I have a set up like same like attached diagram.My questio is ,once I put both N5K into VPC, after 10-15 minitues ,pinging to server
(10.10.66.126) will stop.
I cannot see error from the N5k side.All VPC/port channel/interfaces/keep alive link are up.But will stop pinging .
Can any expert advice me on this regard?
boot kickstart bootflash:/n5000-uk9-kickstart.6.0.2.N2.4.bin
boot system bootflash:/n5000-uk9.6.0.2.N2.4.bin
interface Vlan900
description vPC keepalive link
no shutdown
ip address 2.2.2.1/24
interface Ethernet1/44
description ** vPC keepalive link **
switchport access vlan 900
duplex full
interface port-channel10
description ** vPC Peer-link **
switchport mode trunk
switchport trunk allowed vlan 1-899,901-3967,4048-4093
spanning-tree port type network
speed 10000
vpc peer-link
interface Ethernet1/43
description "vPC Peer Link - N5K"
udld aggressive
channel-group 10 mode active
interface port-channel2
description VC1-Bay1-4 ports
switchport trunk allowed vlan 66
spanning-tree port type normal
interface Ethernet1/1
channel-group 2 mode active
02-15-2015 11:35 AM
check LACP status on switch:
show port-channel summary
Do you have a VirtualConnect module? You can check LACP state by checking the SUS link neighbors.
02-15-2015 08:33 PM
Thanks Peter for replying...
All seems to be ok. You can check from the configuration.
Yes other end is a VM HP server.
