Nexus 5500 L3 Routing - upgrade ISSU?
oguarisco
Level 3
Level 3
we need to perform a SW upgrade on a 5.X Release on a pair of Nexus5500 with Dual-attached FEX and L3 daughtercard installed with IP Routing enabled.
I've read that ISSU Upgrade is not possible with L3 Routing feature active, and we should do a disruptive upgrade of each switch requiring a reboot...is this confirmed?
Thanks for a reply
O.G.
Sam Byers
Yes. ISSU isn't supported with the L3 daughter card installed and active.
Confirmation:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/upgrade/503_N1_1/n5k_upgrade_downgrade_503.html#wp641001
Same docs I've read...
BR
