12-19-2013 01:41 AM
we like to use N5548 and N5020 in same VPC.. Is it possible.. or must be switches of same type
We did configuration and VPC is formed... just VPC consistency check shows type 2 errors for some Network Qos stuff
Do you see it as issue?
thanks
12-19-2013 04:46 PM
The vPC with 5500 and 5000 isn't supported, even showing just a type-2 inconsistency, this is should not working well.
The QoS, the buffers and the asics are completly different.
This is the reference that says this isn't supported.
http://www.cisco.com/en/US/partner/docs/switches/datacenter/nexus5000/sw/interfaces/521_N11/b_5k_Interfaces_Config_Guide_Release_521N11_chapter_0101.html#d11509e288a1635
Richard
