115
Beginner
Nexus 5548 and L3
Is the L3 daughter card required for connected inter-vlan routing and static routing? Or is it only for dynamic routing?
If I have the base license but not the L3 daughter card, am I still able to create L3 SVIs?
Forgive my ignorance as I am trying to get my head around it! I am trying to figure out if the daughter card is needed for any sort of layer 3 configuration such as SVIs.
ck
1 ACCEPTED SOLUTION
Highlighted
Rising star
Without the L3 daughter card
Without the L3 daughter card you have in effect just a Layer 2 switch, no layer 3 functionality.
See below a similar discussion on the L3 daughter card for the 55K:
https://supportforums.cisco.com/discussion/12475461/create-new-vrf-n5548
Don't forget to rate all posts that are helpful.
1 REPLY 1
Highlighted
Rising star
Content for Community-Ad
August's Community Spotlight Awards
