01-12-2022 12:23 AM
we have a Nexus 5548UP with a trunk Port, Port is configured identical to some working connection, it has the following config:
interface Ethernet1/1
description icarus
switchport mode trunk
switchport trunk native vlan 145
switchport trunk allowed vlan 145,152
swi-rhb-server1# show int eth1/1 transceiver details
Ethernet1/1
transceiver is present
type is 10Gbase-SR
name is CISCO-OEM
part number is SFP-10GB-SR
revision is B4
serial number is OE50012225
nominal bitrate is 10300 MBit/sec
Link length supported for 50/125um OM2 fiber is 82 m
Link length supported for 62.5/125um fiber is 26 m
Link length supported for 50/125um OM3 fiber is 300 m
cisco id is --
cisco extended id number is 4
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature 29.04 C 75.00 C -5.00 C 70.00 C 0.00 C
Voltage 3.26 V 3.63 V 2.97 V 3.46 V 3.13 V
Current 7.05 mA 15.00 mA 1.00 mA 12.00 mA 2.00 mA
Tx Power -1.58 dBm 0.79 dBm -7.98 dBm 0.00 dBm -7.01 dBm
Rx Power N/A -- 3.01 dBm -16.02 dBm 0.00 dBm -13.01 dBm
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
the port is connected to a dell server with broadcom 57414 25g nic, in this nic is a cisco-compatible 10gb sfp+
the server thinks the port is up, nexus says its down, however, we are able to tcpdump packets coming from nexus over the "down" link. I dont know how to force it up now, t should already work. Vlans are running
thanks for any hint.
Solved! Go to Solution.
01-12-2022 02:48 AM
No worries glad all good and working, appriciated your feedback.
01-12-2022 01:04 AM
if this is 25G nic, can work with 10G compatable, then try no autonegition on Cisco side (# no negotiate auto). ( also if the config allow set the port speed 10GB on dell side)
can you post show interface eth 1/1
01-12-2022 02:28 AM
thanks for your time, and sorry for your time, its solved, my personal layer 8 Problem
01-12-2022 02:48 AM
