Nexus 5548up OS 5.1(3)N2(1) with L3 Card
ataranen
I find some inconsistent behavior in the above platform. After a clean reboot, the interfaces  are up, but cdp neighbors are not showing. The switch has no  configuration (after reboot with no startup-config). To make things worse sometimes it will  boot properly and show cdp neighbots, other times it won't. When that happens all the port-channel  and other configurations don't work as well. The switch has L3 card. Any ideas?
I have tried installing NX-OS 5.2 and then moving back to 5.1. I want to stay at 5.1 That didn't solve anything.
5k1# show cdp neighbors
Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater,
                  V - VoIP-Phone, D - Remotely-Managed-Device,
                  s - Supports-STP-Dispute
Device-ID             Local Intrfce Hldtme Capability  Platform Port ID
Switch                 mgmt0         158    S I       WS-C2970G-24T Gig0/22
5k1# show interface e1/14-15 brief
Ethernet      VLAN    Type Mode   Status  Reason Speed     Por
t
Interface Ch
Eth1/14       1       eth  access up none                        10G(D) --
Eth1/15       1       eth  access up none                        10G(D) --
5k1# show module
Mod Ports  Module-Type                      Model                  Status
1    32     O2 32X10GE/Modular Universal Pla N5K-C5548UP-SUP        active *
3    0      O2 Daughter Card with L3 ASIC    N55-D160L3             ok
Mod  Sw              Hw      World-Wide-Name(s) (WWN)
1    5.1(3)N2(1)     1.0     --
3    5.1(3)N2(1)     1.0     --
Mod  MAC-Address(es)                         Serial-Num
1    547f.eea3.fe28 to 547f.eea3.fe47         FOC16193NET
3    0000.0000.0000 to 0000.0000.000f         FOC16125D4B
5k1# show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_serie
s_home.html
Copyright (c) 2002-2012, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 3.6.0
  loader:    version N/A
  kickstart: version 5.1(3)N2(1)
  system:    version 5.1(3)N2(1)
ataranen
I have tested this issue on another 5548UP with L3 running the same NX-OS version and get the same problem. Show CDP from the switch is not discovering devices, but the neightbors can see the 5K in question. Reboot sometimes will fix it, but not always. I suspect a problem with the software since that doesn't happen in NX-OS 5.2. The one I am using is
Software
  BIOS:      version 3.6.0
  loader:    version N/A
