Nexus 7018 to HP Virtual Connect Flexfabric
Julio Sosa
I have a lot of problems to connect a HP VC FlexFabric to my Nexus 7K. First, we tried to form a etherchannel, it was impossible then we tried to connect in access mode with same results
Here some info about that:
>------ LOG ------<
CEP_N7018 %ETHPORT-5-SPEED: Interface Ethernet3/17, operational speed changed to 10 Gbps
2011 Sep 12 16:39:20 CEP_N7018 %ETHPORT-5-IF_DUPLEX: Interface Ethernet3/17, operational duplex mode changed to Full
2011 Sep 12 16:39:20 CEP_N7018 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet3/17, operational Receive Flow Control state changed to on
2011 Sep 12 16:39:20 CEP_N7018 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet3/17, operational Transmit Flow Control state changed to on
2011 Sep 12 16:39:20 CEP_N7018 %ETHPORT-5-IF_UP: Interface Ethernet3/17 is up in mode access
2011 Sep 12 16:39:20 CEP_N7018 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet3/17 is down (Link failure)
¿Anybody knows about problems or issues related to connect these kinds of equipments?
Jerry Ye
Can you post the config of the E3/17?
Is your N7K vPC?
jerry
We did with this bug and implement the workaround:
CSCtq02005
10GBASE-SR flap at linkup between N7K-F132XP-15 and HP FLex
