Nexus 7K Module N7K-F248XP-25 showing powered-dn
Sunil Patil
HI,
I have one Nexus 7K switch in that Module N7K-F248XP-25 showing powerdown. Please find the details for below:-
Mod  Ports  Module-Type                         Model              Status
1    0      Supervisor module-1X                N7K-SUP1           active *
3    48     1/10 Gbps Ethernet Module           N7K-F248XP-25      ok
4    48     1/10 Gbps Ethernet Module           N7K-F248XP-25      powered-dn
5    48     10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L     ok
Mod  Power-Status  Reason
4    powered-dn     Reset (powered-down) because module does not boot
Mod  Sw              Hw
1    6.0(2)          2.1
3    6.0(2)          1.0
5    6.0(2)          1.2
Loggs:----------------------
Aug 17 19:51:05 L3_PUNE-T2DC-DC6-N7K2-51-SERVERS %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet4/8 is down (Interface
removed)
2012 Aug 17 19:51:05 L3_PUNE-T2DC-DC6-N7K2-51-SERVERS %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet4/48 is down (Interfac
e removed)
2012 Aug 17 19:51:05 L3_PUNE-T2DC-DC6-N7K2-51-SERVERS %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet4/5 is down (module remov
ed)
2012 Aug 17 19:51:05 L3_PUNE-T2DC-DC6-N7K2-51-SERVERS %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel51: Ethernet4/6 is down
2012 Aug 17 19:51:05 L3_PUNE-T2DC-DC6-N7K2-51-SERVERS %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet4/2 is down (module remov
ed)
2012 Aug 17 19:51:05 L3_PUNE-T2DC-DC6-N7K2-51-SERVERS %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet4/6 is down (module remov
ed)
2012 Aug 17 19:51:05 L3_PUNE-T2DC-DC6-N7K2-51-SERVERS %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet4/1 is down (Interface
removed)
Kindly let me know what is the issue with the Module.
6 Replies 6
Jerry Ye
You should contact TAC. This looks like hardware issue to me.
jerry
krun_shah
Make sure you have module 4 is in same VDC as module 3 or in its own dedicated F2 only VDC.
If so you can collect show tech module 4 and open a case.
I don't think that is a configuration issue. This is definitely hardware related.
jerry
Leo Laohoo
Duplicate post #2.
Gavin Lodge
Did you ever find a fix for this or did Cisco RMA it? I've having the same issue with an F2E card.
kimrobert
I am having this same issue. Except it looks like there is an ASIC failure.
2015 Jul 22 20:35:47 sungard-n7sw1 %PLATFORM-2-PFM_MODULE_POWER_ON: Manual power-on of Module 1
from Command Line Interface
2015 Jul 22 20:35:47 sungard-n7sw1 %PLATFORM-2-MOD_DETECT: Module 1 detected (Serial number JAF17
43AKAK) Module-Type 1/10 Gbps Ethernet Module Model N7K-F248XP-25E
2015 Jul 22 20:35:48 sungard-n7sw1 %PLATFORM-2-MOD_PWRUP: Module 1 powered up (Serial number JAF1
743AKAK)
2015 Jul 22 20:35:48 sungard-n7sw1 %PLATFORM-5-MOD_STATUS: Module 1 current-status is MOD_STATUS_
POWERED_UP
2015 Jul 22 20:35:52 sungard-n7sw1 %PLATFORM-1-PFM_ALERT: FAN_BAD: fan2
2015 Jul 22 20:36:22 sungard-n7sw1 last message repeated 2 times
2015 Jul 22 20:36:22 sungard-n7sw1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by e0a1700 o
n 10.34.107.102@pts/4
2015 Jul 22 20:36:22 sungard-n7sw1 %PLATFORM-1-PFM_ALERT: FAN_BAD: fan2
2015 Jul 22 20:36:46 sungard-n7sw1 last message repeated 2 times
2015 Jul 22 20:36:46 sungard-n7sw1 %BIOS_DAEMON-SLOT1-5-BIOS_DAEMON_LC_PRI_BOOT:  System booted f
rom Primary BIOS Flash
2015 Jul 22 20:36:52 sungard-n7sw1 %PLATFORM-1-PFM_ALERT: FAN_BAD: fan2
2015 Jul 22 20:36:53 sungard-n7sw1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin on
vsh.14481
2015 Jul 22 20:36:54 sungard-n7sw1 %MODULE-2-MOD_DIAG_FAIL: Module 1 (Serial number: JAF1743AKAK)
 reported failure on ports Ethernet1/9-12 (Ethernet) due to ASIC init failure in device DEV_CLP_L
3 (device error 0xcaf00200)
2015 Jul 22 20:36:57 sungard-n7sw1 %PLATFORM-2-MOD_DETECT: Module 1 detected (Serial number JAF17
2015 Jul 22 20:36:57 sungard-n7sw1 %PLATFORM-2-MOD_PWRUP: Module 1 powered up (Serial number JAF1
743AKAK)
2015 Jul 22 20:36:57 sungard-n7sw1 %PLATFORM-5-MOD_STATUS: Module 1 current-status is MOD_STATUS_
POWERED_UP
2015 Jul 22 20:37:02 sungard-n7sw1 %PLATFORM-1-PFM_ALERT: FAN_BAD: fan2
2015 Jul 22 20:37:43 sungard-n7sw1 last message repeated 4 times
2015 Jul 22 20:37:57 sungard-n7sw1 last message repeated 1 time
2015 Jul 22 20:37:57 sungard-n7sw1 %BIOS_DAEMON-SLOT1-5-BIOS_DAEMON_LC_PRI_BOOT:  System booted f
2015 Jul 22 20:38:03 sungard-n7sw1 %PLATFORM-1-PFM_ALERT: FAN_BAD: fan2
2015 Jul 22 20:38:03 sungard-n7sw1 %MODULE-2-MOD_DIAG_FAIL: Module 1 (Serial number: JAF1743AKAK)
2015 Jul 22 20:38:05 sungard-n7sw1 %PLATFORM-2-MOD_DETECT: Module 1 detected (Serial number JAF17
2015 Jul 22 20:38:05 sungard-n7sw1 %PLATFORM-2-MOD_PWRUP: Module 1 powered up (Serial number JAF1
743AKAK)
2015 Jul 22 20:38:05 sungard-n7sw1 %PLATFORM-5-MOD_STATUS: Module 1 current-status is MOD_STATUS_
POWERED_UP
2015 Jul 22 20:38:13 sungard-n7sw1 %PLATFORM-1-PFM_ALERT: FAN_BAD: fan2
2015 Jul 22 20:38:53 sungard-n7sw1 last message repeated 4 times
2015 Jul 22 20:39:08 sungard-n7sw1 last message repeated 1 time
2015 Jul 22 20:39:08 sungard-n7sw1 %BIOS_DAEMON-SLOT1-5-BIOS_DAEMON_LC_PRI_BOOT:  System booted f
2015 Jul 22 20:39:13 sungard-n7sw1 %PLATFORM-1-PFM_ALERT: FAN_BAD: fan2
2015 Jul 22 20:39:14 sungard-n7sw1 %MODULE-2-MOD_DIAG_FAIL: Module 1 (Serial number: JAF1743AKAK)
2015 Jul 22 20:39:14 sungard-n7sw1 %MODULE-2-MOD_FAIL: Initialization of module 1 (Serial number:
 JAF1743AKAK) failed
2015 Jul 22 20:39:14 sungard-n7sw1 last message repeated 1 time
2015 Jul 22 20:39:14 sungard-n7sw1 %PLATFORM-2-MOD_PWRDN: Module 1 powered down (Serial number JA
F1743AKAK)
2015 Jul 22 20:39:14 sungard-n7sw1 %PLATFORM-5-MOD_STATUS: Module 1 current-status is MOD_STATUS_
CONFIGPOWERED_DOWN
POWERED_DOWN
