Using ASR920 12SZ IM Onchip GNSS and PTP profiles
I would like to make standalone ASR920 router as a PTP grandmaster, which can use the GNSS clock connected on it.
In the PTP server ordinary clock, the user guide talks about configuring 1pps and 10mhz clock as input source from incoming data.
however my requirement is the router can be configured with as standalone master with clock sourced from onhip GNSS receiver and derive ordinary clock for slaves connected to its 1G and 10G interfaces.
10Mhz and 1pps shall generate output signals based on GNSS incoming signal
let me know if the correct steps for the same.
0 Replies 0
