vPC between nexus 7000 and BNT FABRIC SWITCH 10GB in IBM Bladecenter
edwincharles
Dears ,
any one can help me in connecting the following
BNT 10 fabric switch with Nexus 7000 using port channel
how to configure it as port channel in BNT
design as attached
7 Replies 7
hello,
the side of blade server, whare are the configuration of LACP? becuase in the attachment i don't look the LACP active work.
you need enable LACP on side of blade switch.
/c/l2/lacp/port INT1
        mode active
/c/l2/lacp/port INT2
        mode active
/c/l2/lacp/port INT3
        mode active
this a example.
sorry neya,
the Core switch config is as below
CORE 1
interface Ethernet1/3
  description TO-IBM-APP1
  switchport mode trunk
  channel-group 26
  no shutdown
interface Ethernet1/4
  description TO-IBM-APP2
  channel-group 27
  no shutdown
interface port-channel26
  vpc 26
interface port-channel27
  vpc 27
CORE 2
  channel-group 26
  no shutdown
  channel-group 27
  no shutdown
  vpc 26
  vpc 27
weyy,
what part do you need to complete that implementacion?
hi,
i configured on one switch lacp, the link is up and running
but while configuring on the second switch , the ports goes up and down and disconnecting
Dear Neya,
The LACP config worked for the connectivity between the core.
is it possible to trunk the internal port for multiple vlans , as the blade servers have virtual OS
The configuraton side of core 1 and core 2 is fine, but you need to enable LACP but blade switch, I don't look the lacp active in the configuration enable lacp on interface the blade switch.
on core side should we change mode of channel group to active or no need
and for blade sw do we need to add the admin key or no need
        mode active
        mode active
