configure & troubleshoot anyconnect
ASR9000: Satellite Troubleshooting Guide
352
Introduction
This  document provides a guide on how to Troubleshoot common issues on satellite (ASR9000v/ASR901) with  the ASR9000 and ASR9900 series routers.
Satellite discovery Protocol
The Discovery protocol is the lowest level protocol in satellite bringup, and provides the bootstrap mechanism by which a Satellite and Host begin communicating.  The purpose of the Discovery protocol is for the Host to become aware of a reachable Satellite device, and exchange sufficient information to set up (bootstrap) a full Control session. The Host device initiates discovery. Satellite devices are factory-shipped to listen for incoming Discovery probe packets.
The protocol operates at Layer 2. It is a prerequisite that the devices be provided with L2 connectivity, either directly, or via intermediate nodes that forward the Discovery protocol packets.
Discovery protocol steps
  • Host sends a Discovery Probe packet
  • Satellite responds with a Discovery Identification packet
  • Host sends a Discovery Configure packet
  • Satellite responds with a Discovery Ready packet
  • Host sends a Discovery Ack packet
Discovery Protocol states
  • Stopped -- The link is down. Unshut the satellite Fabric link or the member links incase Bundle is used as ICL.
  • Probing for satellites / Discovering – The Discovery protocol has sent probe packets to the satellite. It is waiting for a response from the satellite.
  • Configuring satellite – The Discovery protocol has sent “configuring” packets to the satellite. It is waiting for a response from the satellite.
  • Ready -- Discovery protocol has completed. Control protocol bring-up can now start.
Troubleshooting
Satellite Stuck in Discovering State
RP/0/RSP1/CPU0:ASR9K-PE-Agg-1#sh nv satellite status satellite 300
State: Discovery halted; Conflict: no Identification received yet
Type: asr9000v
IPv4 address: 12.23.54.230
Configured satellite fabric links:
Bundle-Ether300
Port range: GigabitEthernet0/0/0-39
Discovered satellite fabric links:
TenGigE0 /1/0/19: Discovery halted; no Identification received yet
TenGigE0 /1/0/9: Discovery halted; no Identification received yet
  • If the satellites are configured with 511 new topologies (Simple Ring/Chain, L2 fabric, Dual head) , Check the image version (show version) of Satellite by logging into the satellite console . If the Host is running with 511 image and satellite is not running with a 511 compatible image (15.1(3)SVG ), it is expected that it would not be discovered in the new topologies. Please follow following steps to upgrade the satellite with the new compatible 511 image:
    • Connect the satellite in hub and spoke mode on the host.
    • Transfer and activate the 9000v/901 image to the satellite.
    • Check the output of sh nv sat status to check the satellite displays “latest version”
    • Please refer to image transfer section incase of issues with image transfer.
    • Move the satellites back to the new 511 topologies as required
    • Satellites ordered post 5.1.1 release would be shipped with factory-burnt 511 image but older satellites have to upgraded to 511 image first before they can be used in the new topologies.
  • Satellite state shown asDiscovery halted; Conflict: no Identification received yet”
“Status: Probing for Satellites; Conflict: no Identification received yet state” means that the Host is sending DPM probes to satellite and waiting for a response. The satellite is either not responding to the discovery probes from the host or the host drops the discovery replies from the satellite.
    • Check for Packet drops on Host or Satellite:
      • If the host is not sending out discovery probes or the host is receiving discovery replies from the satellite but dropping the packets either on the interface or the NP, check “sh interface <ICL_LINK>” counter on the Host. The input and output counters would show SDAC discovery input and output packets.
                          Check the NP counters of the ICL port. Look for any drops on the NP counters.
                          if IN_SATELLITE_DISCOVERY_DISCARD NP counter is increasing:
        • Check if icl bit is programmed in uidb for icl interface
                                     show uidb data location 0/0/CPU0 tenGigE 0/0/1/0 ingress
                                          Satellite IC interface           0x1
        • If the ICL bit is not set in UIDB, we need to check the vlan ea db
                                     sh ethernet infra internal ea trunks tenGigE 0/14/0/3 location 0/14/cPU0      --> main interfaces
                                     sh ethernet infra internal ea subs tenGigE 0/14/0/3.1 location 0/14/cPU0 --> for  icl which is a sub interface (incase of L2 Fab)
                                        is_in_icl_mode:
        • If the bit is not set in vlan ea then we need to check the vlan ma
                                    sh ethernet infra internal ether-ma trunks tenGigE 0/14/0/3 location 0/14/cPU0 ( use subs for sub interfaces)
                                        is_in_icl_mode: 1
Note: Incase of bundle ICL, Satellite IC bit is set for ICL bundle interface but not for ICL bundle member.
Please collect the below traces and show tech for the above scenarios for further debugging:
          • Show tech satellite
          • Show tech pfi
          • Show tech Ethernet interfaces
          • Show tech bundle
          • sh nv satellite trace internal hardware all location <ICL_Linecard_Location>
      • If the host is sending out discovery probes and not receiving discovery replies from the satellite, check the ICL counter (sh interface Tengige 1/45-48) on the satellite (connecting using console) . If there are input counters and no output counters on Satellite ICL interface, then the satellite is dropping the discovery packets. Check the BCM counters on the ICL link to check for drops:
login to bcm shell by the below command
LC:Satellite#test bcm shell ( for 9000v)
show c xe0 where xe0 -xe3 is tengige 1/45 to tengige 1/48
LC:Satellite#test platform bcm shell for (901)
Show c ge2 or ge3 ,where ge2 is gig 0/10 and ge3 is gi 0/11
BCM.0> show c xe0
RUC.xe0 : 87 +30 5/s
RDBGC0.xe0 : 2 +1 -------------> RDBGC0 counter- this counter represents drops
RDBGC2.xe0 : 15 +4
If the satellite is dropping the discovery packets, please collect the below outputs.
show satellite discovery - to check the in/out discovery counters
show satellite nv-info
show satellite iclid_info active
show satellite iclid_info dump
sh monitor event-trace satellite discovery all - for trace logs
show satellite swsb <icl port>   [ ICL port ranges from 45-48]
.   From BCM shell:
4.1 fp show entry 1
4.2 fp show entry <entryid>            [ Entry id can be get from 3.2 command…check for “Probe FP id”]
4.3 show c                                               [ execute 3-4 times at interval of 2 secs]
4.4 vlan show 4094
If the issue is reproable please enable the below debugs and recreate the issue:
debug sdac discovery all
* first start with the below SDAC debugs
debug sdac discovery discovery info
debug sdac discovery discovery error
debug sdac discovery discovery notification
debug sdac discovery discovery state-machine
* If there are no errors or clues from the above debugs,
then add the following PD debugs:
debug satellite discovery info
debug satellite discovery error
* To take a look at the raw packet contents, use the following debugs
PI - debug sdac discovery packet
901 PD - debug satellite control misc
  • 511 L2 Fabric Satellite stuck in Discovery State:
    • Verify the reachability from the host to the satellite via the l2 cloud.
    • Only p2p l2 fab circuits are supported for l2 fab connections. If you have bridge domains/vpls/trunk ports in the l2fab cloud, convert them to p2p xconnects or VCs
    • Trace the discovery probe packets from the host over the l2 cloud with each hop in the l2 cloud. Check the node where the packets are getting dropped and follow the usual triage process for packet drops.
Satellite stuck in Configuring state
  • Satellite in Dual head/Ring topology stuck in configuring on one of the hosts:
    • Check if MPLS LDP is up between the 2 hosts
    • Check if ICCP is up between the 2 hosts (show iccp group)
    • Check if ORBIT is up between the 2 hosts (show nv satellite protocol redundancy)
    • IF LDP or ICCP is not up, follow the usual triaging steps for ASR9K.
    • If ICCP is up and ORBIT is down then collect “show tech satellite” from both hosts and send it to Satellite support team.
  • Collect “show tech satellite” if satellite is stuck Configuring state for all other topologies and if ORBIT is up in Dual Head Topology.
Satellite Control Protocol
The Control Protocol encompasses the remaining steps of Satellite Bringup. It makes use of the connectivity set up by the discovery protocol to provide a reliable and extensible mechanism for the Host device and each satellite device to exchange the required configuration, state, etc.
Control Protocol States
  1. Connecting: The Control protocol is trying to connect to the TCP Socket. “show tcp” on both the host and Satellite should give more info on this.
  2. Authenticating: The Control Protocol has sent an authentication message and is waiting for a response from the satellite.
  3. Checking ver: The control protocol has sent a version request to the satellite and is waiting for a response.
  4. Connected: The control protocol is up
Troubleshooting
Satellite stuck in Connecting state:
  • Check if ping works from the host to the satellite IP address.
    • In case of Dual host/Ring topology, check if you have same ipv4 address or ipv4 unnumbered loopback address  configured for the ICL on both hosts. The loopback address for the ICLs on both hosts should be different.
    • If this doesn’t works then carry out the usual debugging for ping failure, please refer to the section for ping failure on satellite.
  • Check if TCP session is UP. “show tcp brief” should show the state as “ESTAB”.
    • Collect “show tcp packet-trace <pcb>” for the link which shows the issue (use show tcp brief | inc <peer ip> to get the pcb)
    • Collect “show tcp trace”. Send the logs to TCP team.
  • If TCP is UP, then debugging needs to be done from the ICPE perspective:
    • Collect “show tech-support satellite” from both the hosts in case of ring/dual home topology.
    • Collect the output of “show tcp brief”
    • Send the ablove outputs to icpe team for further debugging.
  • If above three steps are fine then debugging needs to be done from sdac perscpective. Enable following debugs on host during repro and send it out to sdac team for further analysis:
    • Debug sdac discovery notifications
    • Debug sdac control info
    • Debug sdac control error
    • Debug sdac control all feature-channet 14 (topology channel)
    • Debug sdac control all feature-channel 3 (crosslink feature channel)
  • If above steps are fine then we need to debug from satellite perspective. Enable following debugs on host and save the details for further debugging:
    • Debug satellite control error
    • Debug satellite control info
    • Debug satellite mim all
    • Debug satellite crosslink-mgr 0 all
    • Debug satellite crosslink-mgr misc
    • Collect the output of “show monitor event-trace satellite discovery all”
Image Transfer/Activation Issues
Check if image transfer was successful
Typical times for image transfer for 9000v is about 3-5 mins and for 901 is 4-6 mins. Following logs appear on the console once we start transfer:
RP/0/RSP0/CPU0:dor1101eiuc202#install nv satellite 9002 transfer progress
Mon Dec  2 16:32:08.652 CET Install Op 6: transfer: 90021 configured satellite has been specified for transfer.
1 satellite has successfully initiated transfer.
Press Ctrl+C at any time to stop displaying the progress bar.
| Working...
RP/0/RSP0/CPU0:Dec  2 16:33:05.676 : icpe_satmgr[1164]: %PKT_INFRA-ICPE_GCO-6-TRANSFER_DONE : Image transfer completed on Satellite 9002 Completed.
From the above log image is transferred in 1 min. Since the recorded time is less than the expected time, image transfer itself failed.
     Activation Process
     Once the activation is started, the satellite goes for a reload and comes up with the newly transferred image.
     Note: For Host Upgrade from pre 511 image to 511 image
    1. Activation for 9000v is a 2 step process and would cause the 9000v to reload twice
    2. When activate is issued after transferring the image, the satellite would reload and come up with an intermediate image
    3. The host would detect this and initiate another image transfer automatically .
    4. The satellite would go for a reload again and come up with the new version.
    If image transfer to the 9000v or 901 satellite fails, please check the below:
  • Check if you have MPP configured. If yes, you need to add an exception for the ICL Links as can be viewed from:
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.2/interfaces/configuration/guide/hc42satl.html#wp1158566
  • Check if you have tftp homedir configured on the ASR9000 host.
hostname Host1
tftp vrf default ipv4 server homedir disk0:
If the tftp transfer requests from satellite comes on the default vrf [through manual IP configuration] and tftp home directory configured on the host is disk0: then image transfer request will fail as the tftp_fs will try to read the disk0:/ path. Please check DDTS CSCuj02716 for more details.
Please remove the tftp homedir and retry the transfer again.
  • Check whether the tftp service is configured or not using following cli.
Show cinetd services
RP/0/RSP0/CPU0:R3#show cinetd services
Vrf Name                         Family  Service  Proto  Port  ACL                  max_cnt    curr_cnt  wait     Program Client     Option
default                          v4      telnet   tcp    23                         10         0         nowait  telnetd    sysdb
default                          v4      tftp     udp    69                         unlimited  0         wait    tftpd      icpe-cpm /pkg/fpd-nv/              <<<<<<<<<<<<<<<< ICPE started the service, shows as client.Inout output also there should be some tftp service started by icpe-cpm,
  • ASR901 Specific image transfers issues/Checks
    • If the ASR901 already have a standalone non nV image, image transfer may fail due to lack of space on the 901. Please delete the non-nV image from the 901 flash and execute "squeeze flash:" to free up space.
    • For ASR901 the image transfer may take sufficiently more time sometimes than normal, if the flash does not have enough space, the squeeze will automatically kick in when image transfer is attempted, this operation may take close to 30 mins.
  • If the image transfer is still unsuccessful, try image transfer without “progress” keyword.
  • If above steps doesn’t helps then please enable the below debugs on the 9k and the satellite prior to enabling the transfer and provide the logs to the satellite support team.
    • On ASR9K:
      debug cinetd
      debug tftp server
      debug nv satellite internal cpm tftp verbose
    • On Satellite
      debug satellite img_dwnld all
    Image Transfer is successful but Activation says “not latest version”.
  • Check for the image version on Satellite “show version”. Following is the version information for various releases:
SVA---15.1(3)SVA 4.2.1
SVB ---4.2.3
SVC ---4.3.0
SVD---4.3.1
SVE---5.1.0
SVF---4.3.2
SVG---5.1.1
  • If the version on satellite matches with the version for the ASR9000 release, then upgrade is successful. The “not latest version” message in “show nv satellite status” can be ignored as the satellite is running with the latest version. This could happen if the SMU was built with its file descriptors not updated correctly, this has no operational impact.
  • If the version on satellite doesn’t matches with the above list, then Activation of image failed. Please collect “show tech satellite” from host and provide it to Satellite support team.
Ping or Data Packet Drop on Host
Ping fails on Satellite interface
  • Check the nv status(show nv satellite status). The satellite should be in connected state. Please refer to satellite bringup sections incase satellite is not in Connected state.
    • If the satellite is connected with “Dual home” topology then refer to section “debugging traffic drops on dual head setup”.
    • Check the arp table of the destination IP Address. If ARP is not resolved proceed to the next step.
    • Check if cross-links are formed correctly on the satellite and interfaces are up on satellite.
LC:Satellite#sh satellite crosslink tenGigabitEthernet 1/45
Interconnect Link: TenGigabitEthernet1 /45 xos_if: 5
icl_id: 1 host_id: 1 cp_vlan: 0
Link State: Up SDAC State: Discovered Crosslink State: Up
Access Port ICLID Link State ForcedDown ? TxDisabled ?
Gi1/1 1 Up No No
Gi1/2 1 Up No No
Gi1/3 1 Up No No
Gi1/4 1 Up No No
If crosslink map is missed or not expeted, please turn on “debug sdac control all feature-channel 3/ feature-channel 4(for bundle ICL), and send the data for further analysis.
If interfaces are showing up on the satellite but down on the host, collect “show tech satellite” from host and “debug sdac control all feature-channel 1” from the satellite.
    • If  ARP is resolved correctly then check for packet drops on host as well as satellite:
      • If ping packets are getting dropped on the host. Check the NP drop counter, which is increasing. Follow usual debugging steps for packet drops on ASR9K.
      • Send ping packets from the host with packet size 1400. Check for ICL counters to confirm if the packet went out of the host.
      • Check ICL stats on Satellite to see if the ping packets are getting received on satellite(show in ten 1/x)
login to bcm shell
test bcm shell for 9000v and test platform bcm shell for 901.
show c xe0 where xe0 -xe3 is ten 1/45 to ten 1/48
BCM.0> show c xe0
RDBGC0 counter- packets are dropped,check if this is same as ping rate
RDBGC2.xe0 : 15 +4
ITPOK.xe0 : 91 +29 6/s
ITUC.xe0 : 85 +28 5/s
ITMCA.xe0 : 4 +1
ITPKT.xe0 : 91 +29 6/s
IT64.xe0 : 2 +1
IT127.xe0 : 40 +3
IT255.xe0 : 17 +4
IT1518.xe0 : 26 +21 4/s----> packets sent out towards the host
ITBYT.xe0 : 48,626 +30,872 7,043/s
IR64.xe0 : 21 +6
IR127.xe0 : 41 +4
IR255.xe0 : 16 +4
IR1518.xe0 : 26 +21 4/s ---> this counter means packets with size 1400 are recieved on bcm shell
Check if the “echo reply” is going out of Satellite ICL ( port gig 300/0/0/0 would mean ge0 on bcm shell and so on):
BCM.0> show c ge0
RUC.ge0 : 767 +767 4/s
RDBGC1.ge0 : 17 +17
GR127.ge0 : 50 +50
GR1518.ge0 : 734 +734 4/s --- >>> packets recieved back from remote router.
GRPKT.ge0 : 784 +784 5/s
GRBYT.ge0 : 1,046,372 +1,046,372 6,858/s
GRMCA.ge0 : 17 +17
GRUC.ge0 : 767 +767 4/s
GRPOK.ge0 : 784 +784 5/s
GT127.ge0 : 50 +50
GT1518.ge0 : 734 +734 4/s -----------> packets go out of access port.
GTPKT.ge0 : 784 +784 4/s
GTMCA.ge0 : 17 +17
GTBYT.ge0 : 1,046,372 +1,046,372 6,765/s
GTUC.ge0 : 767 +767 4/s
GTPOK.ge0 : 784 +784 4/s
PERQ_PKT(0).ge0 : 784 +784 4/s
PERQ_BYTE(0).ge0 : 1,046,372 +1,046,372 6,765/s
BCM.0>
Trace the packets end to end along the path and determine where the packets are getting dropped. If packets are getting dropped on the bcm shell(RDBGC0 counter usually indicates drops) and if the drop rate on this counter is same as the total rate drops, contact the satellite team.
    • If ARP is not resolved on the host check if the ARP is resolved on the other end connected to satellite. If ARP is resolved on the other end, send ping packets with size 1400 and trace the packet path same as above on the opposite direction.
    • If ARP is not resolved on either end, then initiate ping from the host and host will send ARP requests, check the qos tm counters to see if packets go out of host.
    • Configure static arp on the host and initiate ping, now the host will send normal ping packets(not arp packets), check the counters on the ICL link and the satellite as above.
    • If the network is a ring/chain topology, follow the same procedure, the difference being, we need to trace the packets on each satellite along the way between the host and the satellite under question.
Traffic DROP Scenarios on Host
  • EGR_SATELLITE_NOT_LOCAL_DROP on egress NP on 9K
If there are drops under the egress NP on 9K incrementing under “EGR_SATELLITE_NOT_LOCAL_DROP”, the NP local bit is not set correctly on ICL or the packets are not taking the correct ICL bundle member as per the load- balancing algorithm.
Packets are loadbalanced on the ICL bundle as per the following formula:
(Satellite ether port number +2 ) modulo (no of members in bundle)
For eg, if the sat ether port is 100/0/0/0 and there are 3 members in the bundle, the traffic will take the ICL member (0+2) modulo 3 2, ie the member with LON=2.
The value for LON can be got from
sh bundle load-balancing bund-ether <> loc <>
Member Information:
Port: LON ULID BW
Te0/0/0/23 0 0 1
Te0/3/0/1 1 1 1
Te0/3/0/3 2 2 1
Capture the below CLI's to check for the np local bit programming on the ICL Bundle members:
RP/0/RSP0/CPU0:vkg1#sh controllers pm inter gigabitEthernet 100/0/0/32 location 0/3/CPU0
Thu Nov 8 01:55:39.482 UTC
Ifname(1):
GigabitEthernet100 _0_0_32, ifh: 0x1a60 :
iftype 0x59
egress_uidb_index 0x30
ingress_uidb_index 0x30
port_num 0x0
subslot_num 0x0
phy_port_num 0x108
channel_id 0xa
channel_map 0xc
lag_id 0x2
virtual_port_id
0x108
Take virtual_port_is value =0108, revese the digits-0801
show controllers np struct
EgR -Port detail all-entries np2 location 0/3/CPU0
Entry 24: >>
KEY:0801 KEY SIZE:2
MASK:ffff MASK SIZE:2
RESULT:112
800200400a2000100000001405539575f710b000000000008012200000000 RESULT SIZE:32
<< it should be set to 8, if not programmed it is set to 0
RP/0/RSP0/CPU0:vkg1#show controllers np struct egr-port se ke 0801 np2 location 0/3/CPU0
Node: 0/3/CPU0:
Entry 1: >>
KEY:0801 KEY SIZE:2
RESULT:112800200400a2000100000001405539575f710b000000000008012200000000 RESULT SIZE:32
Collect the below traces and contact the satellite support team.
    • PARSE_DROP_IN_UIDB_TCAM_MISS drops on Ingress NP on Satellite interface
If data packets are dropped on ingress satellite interface with NP drops as PARSE_DROP_IN_UIDB_TCAM_MISS the ICL mode may not be set on the ICL physical port. CHeck the UIDB on the ICL link
                     - sh nv satellite trace internal hardware all location <ICL_Linecard_Location>
                show ethernet hardware interface <> loc <> -> Gives the tcam address
                show prm server tcam entries l2-LT <tcam addr> 1 np0 location <> -> dumps uidb entry
    • RSV_DROP_IN_L3_NOT_MYMAC drops on Ingress NP on Satellite interface
When these drops are seen, please collect sh nv satellite trace internal hardware all location <ICL_Linecard_Location> Satellite interface counters not updated on host
If satellite interface counters are not updated on host, check the output of sh nv sat protocol control to see if all channels are open. Collect the output of show tech satellite and contact the satellite support team.
Debugging traffic drops on dual head setup
  • If traffic is getting dropped on the host, check if the redundancy attributes are published correctly on the satellite interface.
    • Check “show im database interface <sat ether name> detail” to ensure the redundancy attributes are published correctly. It should be set to Active on active host.
RP/0/RSP0/CPU0:vkg3#sh im database interface gigabitEthernet 100/0/0/30 detail | i Redundancy
     GDP - Global Data Plane, RED - Redundancy, UL - UL
Redundancy State:         ACTIVE
    • Collect “show tech satellite” incase there is a discrepancy in the above output
  • For VPWS scenario, verify that the PW is ACTIVE with active host and STANDBY with the standby host.
  • In cases where ORBIT flaps may happen (RSP switchover on either hosts, mpls ldp flapping etc.), there may be a temporary traffic drops of about 2 secs in either direction, this is caveated for 511 release through CSCuj91250.
  • For all other traffic drops scenarios refer to section for Ping or Data Packet drops on host.
Related Information
ASR9000/XR: Using Satellite(Tech Note)
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-3/interfaces/configuration/guide/hc43xasr9kbook/hc43satl.html
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r5.1/interfaces/configuration/guide/hc51satl.html
Santosh Sharma, CCIE #40773
S/W Engineer, ASR9000
Abhisek Jhunjhunwala,
