ASR9000/XR: Understanding and using RPL (Route Policy Language)
138463
Introduction
In this document I'll discuss the operation, use and some examples on RPL, or the route policy language.
Route policies are mandatory for E-BGP peers, at least a "pass-all" like RPL is required in order to import and export routes.
Core Issue
In IOS we used to have route-maps to control the import, export and manipulation of routes. IOS-XR doesn't have route-maps but something more powerful called route policy language. It is a very programmatic approach in route-maps.
Where as IOS route-maps operate as a series of statements which are executed sequentially, Route-policies not only operate sequentially but provide the ability to invoke other route-policies much like a ‘C’-program is able to call separately defined functions. This enables to creation of hierarchical policies. In addition, and most importantly into respect the scope of this paper, route-policies are ‘compiled’ into a run-time executable portion of code.
Editing route policies
When you have configured a route policy that you want to edit afterwards, you need to restart from scratch or copy paste the existing RPL as entering the route-policy configuration would wipe the existing one out:
RP/0/RSP0/CPU0:A9K-BNG(config)#route-policy test
RP/0/RSP0/CPU0:A9K-BNG(config-rpl)#if med eq 100 then
RP/0/RSP0/CPU0:A9K-BNG(config-rpl-if)#set local-preference 100
RP/0/RSP0/CPU0:A9K-BNG(config-rpl-if)#endif
RP/0/RSP0/CPU0:A9K-BNG(config-rpl)#end-policy
RP/0/RSP0/CPU0:A9K-BNG(config)#commit
Fri Jan 20 14:58:39.900 EDT
% WARNING: Policy object route-policy test' exists! Reconfiguring it via CLI wil
l replace current definition. Use 'abort to cancel.
RP/0/RSP0/CPU0:A9K-BNG(config-rpl)#if local-preference eq 123 then
RP/0/RSP0/CPU0:A9K-BNG(config-rpl-if)#set origin incomplete
RP/0/RSP0/CPU0:A9K-BNG(config)#do sh run route-policy test
Fri Jan 20 14:59:53.705 EDT
route-policy test
  endif
  end-policy
As you can see the previous if statement is completely gone, copy pasting and offline editing are also not very easy to use! There is a solution!
RP/0/RSP0/CPU0:A9K-BNG#edit route-policy test ?
  emacs  to use Emacs editor
  nano   to use nano editor
  vim    to use Vim editor
  <cr>
I tend to prefer VI and then you can edit your RPL in a VI like manner:
Editting screen:
route-policy test
  else if med eq 100 then
    set weight 44
  endif
  end-policy
I am inserting the bold italic lines and press "ZZ" to exit and save the VI editor. (Note I made a config error in RED)
"/dev/shmem/rpl_edit.115790135" 8 lines, 149 characters written
Proceed with commit (yes/no/cancel)? [cancel]:
Now the config error here by splitting "else if" and look what happens when I try to commit:
Parsing.
149 bytes parsed in 1 sec (148)bytes/sec
% Syntax/Authorization errors in one or more commands.!! SYNTAX/AUTHORIZATION ER
RORS: This configuration failed due to
!! one or more of the following reasons:
!!  - the entered commands do not exist,
!!  - the entered commands have errors in their syntax,
!!  - the software packages containing the commands are not active,
!!  - the current user is not a member of a task-group that has
!!    permissions to use the commands.
    set weight 44
  endif
  end-policy
Continue editing? [no]:yes
"/dev/shmem/rpl_edit.115790135" 8 lines, 145 characters written
Proceed with commit (yes/no/cancel)? [cancel]: yes
Parsing.
145 bytes parsed in 1 sec (144)bytes/sec
Committing.
Prepared commit in 0 sec
1 items committed in 1 sec (0)items/sec
Updating.RP/0/RSP0/CPU0:Jan 20 15:04:20.101 : config[65848]: %MGBL-CONFIG-6-DB_COMMIT : Configuration committed by user 'root'. Use 'show configuration commit changes 1000000522' to view the changes.
Updated Commit database in 1 sec
So from now one when you want to edit RPL's, prefix sets or as-sets or community sets, use this editor
RP/0/RSP0/CPU0:A9K-BNG#edit ?
  as-path-set       edit an as-path-set
  community-set     edit a community-set
  extcommunity-set  edit an extended-community-set
  policy-global     edit policy-global definitions
  prefix-set        edit a prefix-set
  rd-set            edit a rd-set
  route-policy      edit a route-policy
RPL operation
RPL Actions
The route policy requires a "ticket" for the route to be accepted or dropped. These are the different operatators
Pass – prefix allowed if not later dropped
pass grants a ticket to defeat default drop
Execution continues after pass
Set – value changed, prefix allowed if not later dropped
Any set at any level grants a ticket
Execution continues after set
Values can be set more than once
Done – prefix allowed, stop execution
Drop – prefix is discarded
Explicit drop stops policy execution
Implicit drop (if policy runs to end without getting a ticket)
One thing important to add is here that if you have a policy that is "sequential" like
if med 10 then
 set med 20
endif
if med 20 then
 drop
endif
the execution will NOT drop prefixes with MED10. The reason for that is, although somewhat counter intuitive, that the sequence of operation uses the ORIGINAL value during processing, hence the second if statement will not match for the what was original med of 10...
If you like to get the behavior that both 10 and 20 are dropped, you could do something like this:
if med 10 then drop
else if med 20 then drop
else pass
endif
Don't forget the final pass, as there is an implicit deny.
Hierachical policies
The ability to reference one policy in another
route-policy one
     set weight 100
end-policy
route-policy two
     set med 200
end-policy
route-policy three
    apply two
    set community (2:666) additive
end-policy
route-policy four
    apply one
    apply three
    pass
end-policy
Parameter Passing
The ability to call one policy with a variable to be used in another policy:
route-policy one ($med)
  set med $med
end-policy
route-policy two
  apply one (10)
end-policy
Or with 2 variables:
route-policy three ($med,$origin)
  set med $med
  set origin $origin
end-policy
route-policy four
  apply three (10, incomplete)
end-policy
Inline vs. Named sets
In your RPL you can put the prefix set or as-path etc in the IF statement construction or you can reference a separate set with the AS-list.
They look like the following:
Inline:
route-policy use_inline
  if as-path in (ios-regex '_42$', ios-regex '_127$') then
    pass
  else
    drop
  endif
end-policy
Named-Set:
as-path-set named_set
  ios-regex '_42$',
  ios-regex '_127$'
end-set
route-policy use_named
if as-path in named_set then
    pass
  else
    drop
  endif
end-policy
There is a performance difference between teh two. the Named Set is obviously slightly slower, but is easier to manage especially when the list gets long. I would personally recommend for short lists to use inline and for longer lists to use the named-set.
Each individual set element results in a separate call to the expression engine:
as-path-set as_51
ios-regex ‘_2129$’,
ios-regex ‘_2147$’,
ios-regex ‘_2856$’,
ios-regex ‘_3486$’,
ios-regex ‘_6432$’,
ios-regex ‘_6468$’,
ios-regex ‘_7310$’,
ios-regex ‘_7768$’,
ios-regex ‘_7862$’,
ios-regex ‘_8296$’
end-set
The same set can be written as follows:
as-path-set as_51
ios-regex '_(2129|2147|2856|3486|6432|6468|7310|7768|7862|8296)$'
end-set
Example AS-Path-Set, Community-Set and Prefix-Set
AS-PATH
as-path-set aset1
    ios-regex ’_42$’,
    ios-regex ’_127$’
end-set
Prefix-Set
prefix-set galaga
171.68.118.0/24,
192.168.0.0/16 ge 16 le 30
end-set
Community-Set
community-set cset1
      12:34,
      12:78,
      internet
end-set
•Match by value, wildcard, or regular expression
•2 16 bit values separated by colons
•Support for common community keywords
internet
local-AS
no-advertise
no-export
private-as
Show commands
show bgp policy route-policy <name>
Only display prefixes matching policy – filter show command
RP/0/0/CPU0:XR#show rpl route-policy states
ACTIVE -- Referenced by at least one policy which is attached
INACTIVE -- Only referenced by policies which are not attached
UNUSED -- Not attached (directly or indirectly) and not referenced
Working with Prefix-Sets
Here some examples of using prefix-sets. The use of the variable masks is not easy to understand and I found the CCO documentation not very explanatory, so here a few extra words on that.
Prefix:                                        Explanation:
10.0.1.1,                match only one possible value, 10.0.1.1/32, mask omitted means 32.
10.0.2.0/24,             match only one possible value, 10.0.2.0/24
10.0.3.0/24 ge 28,       match a range of prefix values, from 10.0.3.0/28 to 10.0.3.255/32
10.0.4.0/24 le 28,       match a range of values, from 10.0.4.0 to 10.0.4.240 (eg we can’t “reach” the last 4 bits)
10.0.5.0/24 ge 26 le 30, matches prefixes in the range from 10.0.5.0/26 to 10.0.5.252/30
10.0.6.0/24 eq 28        match any prefix of length 28 in the range from 10.0.6.0/28 through 10.0.6.240/28
10.0.7.2/32 ge 16 le 24, matches any prefix of length 32 in the range 10.0.[0..255].2/32 (from 10.0.0.2/32 to    10.0.255.2). This is a little funky given the “7” in the 3rd octet which effectively    becomes don’t care.
10.0.8.0/26 ge 8 le 16   matches any prefix of length 26 in the range 10.[0..255].8.0/26 (from 10.0.8.0/26 to    10.255.8.0/26)
Let me visualize it with some real outputs.
I am using an RPL that sets the local pref to 1234 if it matches the prefix set, and that prefix set is as per the above sample list.
=> What is excluded here ?  Is 10.0.3.128 excluded from the prefix range ?
Whether the .128 is excluded or not, depends on the mask of the prefix being advertised.
Basically what this means is that if the mask of the route is larger or equal than 28 (so 29,30,31,32) then it matches:
   Network            Next Hop            Metric LocPrf Weight Path
*>i10.0.3.0/28        8.1.1.1                100   1234      0 2 3 {4} i
*>i10.0.3.16/28       8.1.1.1                100   1234      0 2 {3,4} i
*>i10.0.3.32/28       8.1.1.1                100   1234      0 2 3 {4,5} i
*>i10.0.3.48/28       8.1.1.1                100   1234      0 2 i
*>i10.0.3.0/26        8.1.1.1                100    300      0 2 3 {4} i
*>i10.0.3.64/26       8.1.1.1                100    300      0 2 {3,4} i
*>i10.0.3.2/31        8.1.1.1                100   1234      0 2 {3,4} i
*>i10.0.3.4/31        8.1.1.1                100   1234      0 2 3 {4,5} i
*>i10.0.3.6/31        8.1.1.1                100   1234      0 2 i
*>i10.0.3.0/24        8.1.1.1                100    300      0 2 3 {4} i
=> What is excluded here ?  10.0.4.1, .2, .3, .17, .18,.19,.20, etc?
Same as before, but now where the mask is less than 28, so routes in the 10.0.4.x range that have a mask that is shorter 28 will get “hit”.
The mask on the prefix itself sets the “base”. Eg 10.0.3 would not match here as it is not part of the 10.0.4.0/24. Seems obvious but just to be clear ...
*>i10.0.4.0/24        8.1.1.1                100   1234      0 2 3 {4} i
*>i10.0.4.0/26        8.1.1.1                100   1234      0 2 3 {4} i
*>i10.0.4.64/26       8.1.1.1                100   1234      0 2 {3,4} i
*>i10.0.4.128/26      8.1.1.1                100   1234      0 2 3 {4,5} i
*>i10.0.4.48/28       8.1.1.1                100   1234      0 2 i
*>i10.0.4.64/28       8.1.1.1                100   1234      0 2 3 {4,5} i
*>i10.0.4.24/30       8.1.1.1                100    300      0 2 3 i
*>i10.0.4.28/30       8.1.1.1                100    300      0 2 {3} i
Combining the previous two together on the .5.0 range:
*>i10.0.5.4/30        8.1.1.1                100   1234      0 2 {3,4} i
*>i10.0.5.8/30        8.1.1.1                100   1234      0 2 3 {4,5} i
*>i10.0.5.12/30       8.1.1.1                100   1234      0 2 i
*>i10.0.5.4/31        8.1.1.1                100    300      0 2 3 {4,5} i
*>i10.0.5.6/31        8.1.1.1                100    300      0 2 i
*>i10.0.5.5/32        8.1.1.1                100    300      0 2 3 {4,5,6} i
*>i10.0.5.6/32        8.1.1.1                100    300      0 2 3 i
*>i10.0.5.0/25        8.1.1.1                100    300      0 2 3 {4} i
*>i10.0.5.128/25      8.1.1.1                100    300      0 2 {3,4} i
*>i10.0.5.64/26       8.1.1.1                100   1234      0 2 {3,4} i
*>i10.0.5.128/26      8.1.1.1                100   1234      0 2 3 {4,5} i
*>i10.0.7.2/32        8.1.1.1                100   1234      0 2 3 {4} i
*>i10.0.7.3/32        8.1.1.1                100    300      0 2 {3,4} i
*>i10.0.0.2/32        8.1.1.1                100   1234      0 2 3 {4} i
*>i10.0.0.3/32        8.1.1.1                100    300      0 2 {3,4} i
*>i10.1.7.2/32        8.1.1.1                100    300      0 2 3 {4} I <<doesn’t match because of 2nd octet
If I slightly change the prefix statement to: 10.0.7.4/32 ge 16 le 24
*>i10.0.7.0/30        8.1.1.1                100    300      0 2 3 {4} i
*>i10.0.7.4/30        8.1.1.1                100    300      0 2 {3,4} i
*>i10.0.7.8/30        8.1.1.1                100    300      0 2 3 {4,5} i
Still no match as the base mask is not met on the prefixes received.
So the /<whatever> determines the MASK of the route I wanted to match. whereas the GE/LE provide me the variance in either that mask (if bigger) or from the other octects (if smaller then the /mask)
Verifying performance of your RPL
To determine what in your route-policy is consuming the majority of the time, you can use route profiling.
It allows some data collection in the background with minimal impact  on the execution of the rpl. After the collection has been running for  some time you can use show commands to find out which steps take a lot  of time in the execution and make some improvements.
Once we figure out which portion of the policy is performance drag, its much easier to try out an alternative. Something like regex match always failing means we need to evaluate route using prefix match prior to validating its as-paths.
Example usage:
debug pcl profile detail
then
Router# show pcl protocol bgp 10 neighbor-in-dflt default-IPv4-Uni-1.2.3.4 policy profile
Policy execution profile
Protocol : bgp 10
Attachpoint : neighbor-in-dflt
AP Instance : default-IPv4-Uni-1.2.3.4
Policy Name : rpl_profile(nexthop)
Pass : 10
Drop : 5
Total : 15
Avg execution time : 110usec
Router#sh rpl route-policy rpl_profile detail
route-policy test
  apply test2
  done
end-policy
route-policy test2
  delete extcommunity rt all
end-policy
route-policy rpl_profile($p_nexthop)
  if next-hop in $p_nexthop then
    set local-preference 155
    set med 155
  else
    set local-preference 77
    set med 77
  endif
  set community (0:0)
  apply test
  set extcommunity rt (1:1)
end-policy
Router# show pcl protocol bgp 10 neighbor-in-dflt default-IPv4-Uni-1.2.3.4 policy profile detail
Protocol : bgp 10
Policy : rpl_profile(nexthop)
Pass : 15
Drop :  0
Total : 15
Node Id   Num visited  Avg exec time  Policy operation
           15          0usec                    route-policy rpl_profile
PXL_0_5            15         99usec                        if next-hop pfxmatch ... then
PXL_0_3            10          0usec                              set local-preference 155
PXL_0_4            10          0usec                              set med 155
PXL_0_6            15          0usec                              community assign
                            15          0usec                           route-policy test
                            15          0usec                                       route-policy test2
PXL_0_1            15          0usec                                                rt delete-all
                            15          0usec
PXL_0_2            15          0usec
PXL_0_8             0          0usec                              rt assign
                             0          0usec
PXL_0_1             5          0usec                                          set local-preference 77
PXL_0_2             5          0usec                                          set med 77
GOTO :        PXL_0_6
                            0          0usec
Router#
Usable attachpoints for RPL
Changing or modifying Route policies (or prefix/community sets)
As you have noticed when editting RPL's you need to reconfigure the complete policy in the regular CLI. An easier method is using the "edit" option described above.
When you are changing your RPL or prefix-set or any other list that RPL is using, it will trigger a few things:
If the RPL is used for BGP and your peer is not REFRESH capable, it will restart your BGP session.
If the peer is REFRESH capable a full table refresh is executed.
The reason for that is, that the RPL change or say prefix set change could have excluded some routes before that now may need to be imported.
On the Receiving Side:
For BGP, routes that are filtered are completely discarded and are NOT kept in memory with some kind of mark that says bgp rpl filtered.
We will use route refresh to obtain the routes again from the neighbor whenever there is a change in inbound route policy.
For this the neighbor has to be refresh capable, else we have to do clear bgp.
When the BGP peer receives a route refresh request it sends the complete table again to the requesting peer. While asking for the table they ask for the relevant (AFI, SAFI) table. When the routes are received from the peer an inbound filter if any is applied and the routes are aggregated.
On the sending side:
if I apply an RPL basically removing some previously advertised route, would BGP send withdraws for these now filtered routes?
What would rpl/bgp do when the RPL is modified to:
           1) do advertise some previously filtered routes
To advertise previously filtered routes it is similar to regular advertising of routes
           2) stop advertising previously advertised routes
BGP will send withdraws when it stops advertising previously filtered routes.
Xander Thuijs, CCIE #6775
Sr. Tech Lead ASR9000
hank
Beginner
Thanks but I am not trying to set the community value.  I think jheitz has solved my issue.
9ruso9
Beginner
Thanks for the post, it's really useful. I have two questions about this.
1) I am trying to edit a prefix-set already created from the edit command, but I can't set a new prefix adding the range (le | ge ), there is no option after set the network.
ASR#edit prefix-set XXXX inline add 200.200.0.0/28 le 32
I am trying to avoid create the full prefix-set. is there another option?
2)Is there any option to take a look on the prefixes denied by policy in BPG?
I am able to see the the number by #show bgp vrf VPN_2 neighbors Y.Y.Y.Y but not which they are.
Jose
xthuijs
hi jose, thanks!!
normally bgp will drop the prefix from the table and there is no way to see that you actually received the prefix. however if you enable soft reconfig inbound, then you create a pre-filter shadow table on a per neighbor bases (cost more memory) (and usually done for non route refresh capable neighbors).
then you can look at the prefilter table via show bgp neighbor <neigh> received.
you can apply an rpl also to that command to display based on that rpl filter.
for the other question, the inline add/remove/prepend option only takes a prefix, but no further parameters.
rpl, prefix, as and community sets use a different parser then the normal command parser of XR, but you could possibly use emacs or vim/nano to edit the route policy so you dont have to re-add the whole policy.
cheers
xander
SeymaNGET
Beginner
Hi Xander,
Could you please advise if we can use 4 bytes ASN as the community value? As a test from my end, the maximum number I can put is 65535. Is there any possible way we can increase it?
Thanks and regards,
Seyma
xthuijs
hi seyma,
The 4 bytes ASN can be written with a set of 2 times 2 bytes the following way: The 4-byte range is 1.0 to 65535.65535 and the format is high-order 16-bit value in decimal . low-order 16-bit value in decimal. This means that the value: 131299 should be written: 2.227
Does that work?
there was a recent issue with rpl parameters and 4 byte ASN CSCuv10653, fixed in XR601/534.
I'll also dig up the ext community 4 byte asn dev that was done recently to see which release that went in.
I see you're asking about ext comm specifically, but just to note RPL ASPLAIN is supported since XR401
AS configuration for neighbors also can accept either format.
RP/0/RSP0/CPU0:A9K-BNG(config-bgp)#neighbor 1.2.3.4 remote ?
  <1-65535>           2-byte AS number
  <1-65535>.          4-byte AS number in asdot (X.Y) format - first half (X)
  <65536-4294967295>  4-byte AS number in asplain format
cheers
xander
SeymaNGET
Beginner
Hi Xander,
Thank you very much for your reply. Appreciate your help. :-)
Cheers,
Seyma
Hey Xander.  Another fine article from you.
Can you elaborate or maybe send me a link that may potentially have more information on the variables aspect?  I have this route policy in one of our core routers, and I don't fully understand it:
Route-Policy XYZ($prefixset, $aspathset, $location)
Any help would be appreciated.  Thanks.
-Michael
bedgewor
So this is the start of a route-policy that allows for three variables to be passed to it; at it's attach point.    So for example the BGP config may look like this:
router bgp 100
  address-family ipv4 unicast
neighbor 1.1.1.1
  remote-as 200
      route-policy XYZ (Cust1-PrefixSet, Cust1-ASPathSet, Cust1-CommunityLoc) in
      route-policy STANDARD out
In essence the inbound RPL XYZ would reference a PrefixSet (Cust1-PrefixSet) defined on the box and pass in the first variable, the AS-Pathset (Cust1-ASPathSet) which references the second variable, and a Community Set (Cust1-CommunitLoc) which would be the third variable.
The benefit of parametirzation is that you can use the same logic over and over again with the same RPL, but just change the variables that you push into it.
More can be found here:
http://www.cisco.com/c/en/us/td/docs/routers/crs/software/crs_r4-2/routing/configuration/guide/b_routing_cg42crs/b_routing_cg42crs_chapter_0111.html#con_1115577
or in my book (There is chapter on route-policy, etc):
https://goo.gl/7FNfVr
HTH, -brad
mrimch.amal
Beginner
In IOS, I often check the acl counters to verify my configuration therefore I count on them for troubleshouting reasons.
Now I'm using cisco xr so I have to use rpl and prefix-set, what would be the alternative of such functionality?
(If there is a helpful show command, I'll appreciate it)
xthuijs
you know, there wouldn't be much value in seeing the acl counter seeing how many times the prefix was matched, because if the neighbor is flapping you see that counter incrementing ever after over time.
but I sense your use case here that you like to see if the prefix is getting matched, or not, and for that you could possibly use the show bgp <rpl> to see what prefixes match the rule.
there is also the possibility to run the pcl to get some perf stats which will tell you during actual execution which clauses the prefix matched (and what its execution time was).
a test rpl functinality to test the prefix is open via CSCub93613    Test command for RPL (send prefix and follow RPL processing
cheers
xander
Iulian Vaideanu
Enthusiast
Hi Xander,
Is there any way to show a list of BGP neighbors using a specific route-policy?  With IOS it's easy to "show running-config | include <route-map-name>", but the "hierarchical/indented" section-style config in IOS XR makes that useless...
Thanks.
bedgewor
Hi Lulian,
you can find out where an RPL is linked by checking its attachpoint by using the command show rpl route-policy route-policy-name attachpoints.
So using the command for the Route-Policy PASS_ALL, I can see that it is associated to 10.100.121.1 in the IPv4 Unicast Address Family Inbound, and 10.100.121.1 in the IPv4 Unicast Address Family in the Outbound attach points
RP/0/RP0/CPU0:CRS-D#show rpl route-policy PASS_ALL attachpoints
Fri May 12 10:58:45.650 EDT
BGP Attachpoint: Neighbor
Neighbor/Group type afi/safi in/out vrf name bound by
10.100.121.1 -- IPv4/uni in default PASS_ALL
10.100.121.1 -- IPv4/uni out default PASS_ALL
Mathias Rufer
Beginner
show rpl route-policy <xyz> attachpoints
show rpl route-policy <xyz> references
Or simply
show run formal router bgp | include <rplname>
Rufer
xthuijs
XR has a nicer way, you can use the 1st command to see which policies are active (that is tied to something/used) and the 2nd command to findout where they are attached to:
RP/0/RSP0/CPU0:A9K-BNG#show rpl active route-policy det
Fri May 12 09:09:04.857 EDT
The following policies are (ACTIVE)
route-policy REDPOL
  if destination in REDPREF then
    set origin egp
    set weight 5555
  else
    pass
  endif
end-policy
route-policy drop-all
  drop
end-policy
route-policy first
  if origin is igp then
    set local-preference 123
  endif
end-policy
route-policy pass
  pass
  set next-hop 122.1.1.2
end-policy
route-policy pass-all
  prepend as-path 10 3
end-policy
route-policy pass-all-parm($hey)
  var globalVar1 $hey
  if globalVar1 eq 15169 then
    set local-preference 5555
  else
    set weight 666
    pass
  endif
end-policy
  route-policy pass-all-parm(100) referenced by route-policy pass-all-parm
  route-policy pass-all-parm(15169) referenced by route-policy pass-all-parm
route-policy private-as-check
  if as-path in privAS1 then
    set med 1234
  elseif as-path in privAS2 then
    set med 5678
  else
    set med 9999
  endif
end-policy
route-policy second
  if local-preference is 123 then
    set med 321
  endif
end-policy
route-policy setNH
  set next-hop 1.2.3.4
end-policy
route-policy subscribers
  if destination in subs then
    pass
  else
    drop
  endif
end-policy
route-policy t
  if destination in test then
    set next-hop 8.8.8.9
    pass
  else
    drop
  endif
end-policy
route-policy umbrella
  apply first
  apply second
end-policy
RP/0/RSP0/CPU0:A9K-BNG#show rpl route-policy umbrella attachpoints
Fri May 12 09:10:39.430 EDT
3.0.0.235                                --    IPv4/uni   in   default    umbrella
smailmilak
Enthusiast
please try with "show bgp vrf Internet policy route-policy POLICY_NAME  summary" (remove vrf Internet)
You will see for which neighbors this particular route-policy is used.
See under "Advertised to"
It's something :)
