xthuijs
Introduction
IOS-XR has a very strong embedded mechanism to do user authentication and authorization. While XR does not have the concept of privilege-levels as what IOS had, the embedded user task group management is extremely strong allow for the creation of different task groups.
Tasks
Building blocks for on-box authorization scheme
4 types of permissions per task
  • Read
  • Write
  • Execute
  • Debug
Tasks
aaa
config-services
hsrp
netflow
sbc
acl
crypto
interface
network
snmp
admin
diag
inventory
ospf
sonet-sdh
atm
disallowed
ip-services
ouni
static
basic-services
drivers
ipv4
pkg-mgmt
sysmgr
bcdl
eigrp
ipv6
pos-dpt
system
bfd
ext-access
isis
ppp
transport
bgp
fabric
logging
qos
tty-access
boot
fault-mgr
lpts
rib
tunnel
bundle
filesystem
monitor
rip
universal
cdp
firewall
mpls-ldp
root-lr
vlan
cef
fr
mpls-static
root-system
vrrp
cisco-support
hdlc
mpls-te
route-map
config-mgmt
host-services
multicast
route-policy
Default task-groups
The following task-groups are predefined in IOS-XR
root-system: Root system users
root-lr: Root logical router users
netadmin: Network administrators
sysadmin: System administrators
operator: Operators performing day-to-day activities
cisco-support: highest level of privilege allowing lowest level access
What task group is needed for what command?
If you are unsure as to what task group and permission level you need in order to allow a certain command, use the "describe" keyword.
Example:
RP/0/RSP0/CPU0:A9K-TOP#describe show bgp summary
User needs ALL of the following taskids:
       bgp (READ)
So in order to allow a user to do the command "show bgp summary", we would need to allow the following line in
the task group definition:
task read bgp
It can also be the case that a particular user needs to be member of a particular (pre defined) task group.
such as a Process restart, you can only do when you are member of cisco-support:
RP/0/RSP0/CPU0:A9K-TOP# describe process restart bgp
        cisco-support (EXECUTE)
Tasks and user group example
In regular IOS-XR configuration define your task-group with the permissions and tasks you like
RP/0/RSP0/CPU0:A9K-TOP(config)#taskgroup basic-admin
RP/0/RSP0/CPU0:A9K-TOP(config-tg)# task read acl
RP/0/RSP0/CPU0:A9K-TOP(config-tg)# task read bfd
RP/0/RSP0/CPU0:A9K-TOP(config-tg)# task read bgp
RP/0/RSP0/CPU0:A9K-TOP(config-tg)# task write acl
RP/0/RSP0/CPU0:A9K-TOP(config-tg)# task write bfd
RP/0/RSP0/CPU0:A9K-TOP(config-tg)# task write bgp
RP/0/RSP0/CPU0:A9K-TOP(config-tg)# task debug bgp
You can also define a user group that imports several task groups:
usergroup noc-staff
taskgroup operator
inherit usergroup all-users
Privilege levels
As mentioned, XR doesn't have priv levels, but in order to leverage the existing AAA profiles from TACACS used for IOS based routes, we can create user-groups that are named as the privilege levels:
usergroup priv15
taskgroup root-system
taskgroup cisco-support
Now with tacacs we can send the priv via the options in service-exec:
service = exec { priv-lvl = 15 }
or via a radius AVP like:
cisco-avpair = "shell:priv-lvl=15"
NOTE: the syntax of "cisco-avpair" and the capitalization is dependent on the dictionary definition for the cisco avp.
Using AAA
For starters you need to point your user authentication to the external source for authentication:
aaa authorization exec default group tacacs+ local
aaa authentication login default group tacacs+ local
when you add the following to your tacacs profile :
TACACS:
service = exec {
task = "rwx:bgp,#operator"
RADIUS:
Cisco-AVPair = "shell:tasks=#sysadmin,rwx:bgp,r:ospf"
you'll inherit the read, write and execute permissions to BGP as well as the user will be part of the local operator group definition.
Either this group is part of the standard cisco embedded groups or it can be something that you have defined locally.
the radius profile allows read/write/execute on BGP, read for OSPF and membership to the sysadmin group
By using AAA you can either reference locally defined task groups OR you can define the task groups in the tacacs/radius response packet
or using a combination of both
Group Membership
To find out which groups you are currently member of while being logged in:
RP/0/RSP0/CPU0:A9K-TOP#show user tasks
Wed Mar 30 18:26:00.768 UTC
Task:                  aaa  : READ    WRITE    EXECUTE    DEBUG
Task:                  acl  : READ    WRITE    EXECUTE    DEBUG
Task:                admin  : READ    WRITE    EXECUTE    DEBUG
Command Authorization
In IOS we can do command authorization for each separate priv level. in XR we don't have priv levels hence either command author is enabled for ALL commands or none at all:
RP/0/RSP0/CPU0:A9K-TOP(config)#aaa authorization commands default group ?
  WORD     server-group name
  tacacs+  Use list of all TACACS+ hosts
Note: in order to do command author you must use TACACS, you cannot use radius.
Related Information
n/a
Xander Thuijs - CCIE #6775
Sr Tech Lead ASR9000
xthuijs
To find out which command belongs to what task permissions you can use the "describe" keyword (see example above).
If you want to know what say the standard task-group root-system provides, you can create an account with that permission level and do a "show user tasks", it will spit out all the permissions currently assigned to this user.
As for the show run, that is a tricky one. Basically show run will only display those config sections for which you have the right permission level. For instance if "bfd" is not part of your task group permissions, and you do a show run, then you will see the running, but none of the bfd commands that fall under that permission level will be printed.
regards
xander
Hi Xander,
How can I map existing IOS priviledge levels (e.g. level 2) to IOS-XR task groups? This is an issue when migrating an IOS platform to IOS-XR...
Florian
Hi Xander,
I found out how to configure privX user groups to map the priviledge levels to IOS-XR task groups. Nevertheless, I was not able to find a task list matrix that corresponds to IOS priviledge levels.
Florian
xthuijs
yeah the document above has an example how to create task groups that convert into priv levels from a naming convention that allows you to use the same priv level attributes from your IOS devices in your tacacs profiles.
In IOS priv 0 and 15 are the key ones and basically the levels 1-14 can be used to move the commands from their existing priv level to a new one.
With that, priv0 is merely an operator/monitor level and 15 is full access, which is the equivalent of a task group priv0 which only has read access to every command (so shows). Priv15 is the equivalent to cisco-support/root-system.
And mind you that cisco-support in 43 is merged now (see asr9k blog for more detail on that merge).
regards
xander
Thank you for the details on this, so I assume I need to map every IOS command to its IOS-XR task counter part manually as there is no matrix somewhere laying around at Cisco?
xthuijs
The built in usergroup "operator" may already give you a good start of priv level 0.
The priv 15 equivalent is the cisco-support/root-system.
xander
e.nieuwstad
hi is there a simple way to grant read access to everyhting so in stead of
service = exec {
task = "r:bgp,r:aaa,r:interface,r:ipv4 etc etc etc etc"
i would like to do
service = exec {
task = "r:*"
xthuijs
I see two options for you:
1) define a usergroup in XR that takes those permissions and send that task group down via tacacs so you dont have to split it out int he tacacs profile just a copy paste of the config in XR.
2) use the system defined group of operator which I think is a read only only.
xander
e.nieuwstad
xander,
I tried to second option
taskgroup priv5
inherit taskgroup operator
and I log in with a user who gets priv5 from the tacacs server I am even not able to do a show int brie.
I would like to keep the configuration as simple as possible and in a central place. It appears this is not possible so I think I'll go with updating the tacacs-server with all the required read permissions.
xthuijs
yup you can and we're close.
with operator I just see, you have the following permissions:
Task:       basic-services  : READ    WRITE    EXECUTE    DEBUG
Task:                  cdp  : READ
Task:                 diag  : READ
Task:           ext-access  : READ             EXECUTE
Task:              logging  : READ
so what you need to do is add the permissions for the task of something like this:
taskgroup test
task read interface
and then under the priv5, inherit in this case the "test" group for example.
keep adding all the read permissions you need under test, which is inherited by priv5 and you're all set.
regards
xander
e.nieuwstad
Xander I understand the taskgroup concept however I would have liked to have a predefined task-group which has read access to everything. The concept is clear thanks again for your help.
xthuijs
ah ok sorry. I see your request.
ok for now, the only option we have is what we discussed. meantime I will also file a ddts to create a system defined taskgroup "readonly" or whatever that basically gets every task with readonly by default. that might simplify the config then we were discussing on the previous note.
regards
xander
sarmed alkadumi
Hi Xander,
Thank you for the document, I have a problem allowing the following command to be executed for a specific user: "show policy-map interface xxx" , when I do "describe show policy-map interface xx" it tells me that qos (Read) is the only task ID I need, adding that into the taskgroup doesn't change anything, I still can't type "show policy-map" when i log in with that user account, is there something I am missing here, our ASR 9K is running version 5.1.0 .
thanks and regards,
Sarmed
xthuijs
Hi Sarmed, yeah that is a known problem...
This is fixed in 513 and 520, the ddts that described this problem is:
CSCuj44719    4.3.x "show policy-map" requires cisco-support (READ) taskid
xander
Atahar Khan
aaa authentication login mgmt local
aaa authorization commands 1 mgmt local
aaa authorization exec mgmt local
ip ssh port 2000 rotary 1
username mgmt view mgmt password 7 1511021F0725
parser view mgmt
secret 5 $1$GSuD$6sZiw9tIUMLSN2GckpN8eO
commands exec include all show
I am trying to convert this IOS-XE config into IOS XR but rotary command is not supported in XR.
is there any way to achieve the same goal ?
one user will be locally authenticated and others will get authenticated by TACACS.
line vty 5
session-timeout 30
access-class TELNET in
password 7 0822455D0A16
login authentication mgmt
rotary 1
transport input telnet ssh
transport output telnet ssh
