Overview
Path Computation Engine for OpenFlow (PCE-OF) is a new OpenDaylight (ODL) application that applies policy-based path computation and programming that provides a level of “smart” traffic engineering to OpenFlow networks. OpenFlow is a protocol for programming flow tables on switches.
ODL is a collaborative, open-source project used to advance software-defined networking (SDN). OpenDaylight is a community-led, industry-supported framework consisting of code and blueprints. Using this framework, you can accelerate process adoption, foster innovation, reduce risk, and create a more transparent approach to SDN. OpenDaylight can be a core component within any SDN architecture. Building on open-source SDN and NFV controllers enables users to reduce operational complexity, extend the life of their existing infrastructure hardware, and enable new services and capabilities only available with SDN.
Check it out here: OpenDaylight Path Computation Engine for OpenFlow v1
Scenarios
- Scenario 1: Explore PCE-OF
Requirements
Components
- CentOS 7
- PCE-OF 1.0
- Docker 1.11.2
- OpenDaylight SNAPSHOT build
Features
PCE-OF | - Policy-based traffic engineering for OpenFlow networks
- OpenDaylight enabled application
Topology
