Daniel Segovia
Disclaimer
Cisco continues to recommend back-to-back cabled nV Edge solutions (as this is the most reliable method). However, in the case that nV Edge systems are geographically separated, this document will provide recommendations for such conditions.
ASR9000 nV EDGE L2 EOBC
Problem Definition
ASR9K nV Edge (cluster) systems are formed by connecting two chassis back-to-back using both control links and data links. However, if necessity requires the the chassis to be
