somnathr
Introduction
Cisco's CGv6 (Carrier Grade IPv6) solution helps customer transitioning from IPv4 to IPv6 gradually, maintaining business continuity. VSM (Virtualized Services Module) on ASR9K is a Service Card which provides different CGv6 Applications. This is the next generation Service Card after ISM (Integrated Services Module). This document talks about how to deploy NAT44 (Network Address Translation - from IPv4 to IPv4), one of the applications fall under CGv6 suite of applications.
This document does NOT intend to cover details on VSM, how to install CGv6 software on VSM, how to trouble-shoot CGv6 issues, CGv6 Applications other than NAT44.
DISCLAIMER: This document contains some Public IP addresses to explain different deployment use-cases and features related to NAT44. The Public IP addresses are picked up randomly and matching of these addresses with any specific customer's or organization's public IP is purely coincidental. Please DO NOT use these public addresses in your NAT setup / deployment, unless the public IP addresses are not owned by you / your organization. Cisco is not responsible for any issues arising out of this.
Introduction to NAT44
This section introduces NAT44 and terminologies related to it.
1. Why NAT44 ?
IPv4 address is 32-bit long which means there can be 4,294,967,296 (i.e., 4 billions) unique addresses. However, population on earth has crossed 7 billions and is still growing. Also, nowadays, a single person can own multiple IP devices, each having its own IP address. Thus, we are running short of IPv4 addresses. In 2 of the 5 RIR (Regional Internet Registries), IPv4 address exhaustion is declared (in its last /8 stage).
Apat from moving to IPv6 (which uses 128-bit long IP address), an alternate mechanism is to use NAT44 where Private IP addresses can be re-used in different Private networks, but can be translated to a unique Public IP address when the packet enters Internet or Public network.
If you are a Service Provider and running short of Public IP addresses, NAT44 should be of great usefulness to you as an intermediate solution before you slowly convert your IPv4 network into IPv6.
2. NAT44 Overview
NAT44 literally means translating one IPv4 address to another IPv4 address. "Typically", first IPv4 address is "Private" IPv4 Address (defined by RFC 1918) and second IPv4 address is "Public" (non-Private) IPv4 address. As defined by RFC 1918, Private IPv4 addresses fall in the following blocks.
Start IP Address End IP Address Comments
10.0.0.0 10.255.255.255 10.0.0.0/8 prefix - contains 16,777,216 addresses
172.16.0.0 172.31.255.255 172.16.0.0/12 prefix - contains 1,048,576 addresses
192.168.0.0 192.168.255.255 192.168.0.0/16 prefix - contains 65,536 address
However, it is to be noted that not always "Private" IPv4 address is to be translated to "Public" IPv4 address. There are deployment cases where NAT44 is used to convert "Private" IPv4 address (say, 192.168.x.x range) to another "Private" IPv4 address (say, 10.x.x.x range) as well.
NOTE: In this document, however, we will refer "Private" side as the pre-NAT side of the NAT device and "Public" side as the post-NAT side of the NAT device, irrespective of the actual IP address being used.
One more important point, although NAT indicates Network Address Translation, it is actually NAPT (Network Address and Port Translation). What it means is - in addition to IPv4 address, Layer 4 (UDP/TCP) port is also translated by NAT44.
NOTE: Unless mentioned otherwise, in this document, NAT44 will indicate translation of both IPv4 address and Port.
Following Layer 4 Protocols are supported by NAT44 implementation on VSM.
  • UDP (IP Protocol 17) - UDP Port number (2 bytes) is translated along with IPv4 address.
  • TCP (IP Protocol 6) - TCP Port number (2 bytes) is translated along with IPv4 address.
  • ICMP (IP Protocol 1) - ICMP Identifier field (2 bytes) in Echo Request and Echo Response messages is used as (dummy) Layer 4 port.
  • GRE (used with PPTP ALG, IP Protocol 47) - Call ID field (2 bytes) is used as (dummy) Layer 4 port.
Another useful property of NAT44 is multiple Private IP addresses can be mapped to one Public IP address. This is possible as all of the 65,536 ports (0 to 65,535) on any Private IP address are typically not used by Applications.
Following diagram shows how NAT44 works.
As shown above, the Private IP addresses 192.168.1.1 and 192.168.1.5 are translated to same Public IP address 20.1.1.1 (along with specific Layer 4 ports) by the NAT44 device (VSM on ASR9K). The translation entries are maintained in NAT DB at the NAT44 device.
3. Basic Terminologies
In this section, let us get introduced with different terminologies related to NAT44 deployment on VSM.
Terminology Definition / What it means
Inside / Subscriber Side / Access Side / Private Side Private side of the NAT44 device (which usually contains Private IPv4 addresses)
Outside / Network Side / Core Side Public side of the NAT44 device (which usually contains Public IPv4 addresses)
Inside-to-Outside (I2O) Traffic flowing from Inside to Outside across NAT44 device
Outside-to-Inside (O2I) Traffic flowing from Outside to Inside across NAT44 device
Stateful (SF) Which preserves State or Database. E.g. - NAT44 is Stateful protocol.
Endpoint Independent Filtering (EIF)
Any device (IP + Port) can send O2I traffic to a Public IP + Port which exists in NAT DB. VSM implements this behavior. It is also termed as "Full-Cone NAT".
Endpoint Dependent Filtering (EDF)
Only the device (IP + Port) which has received I2O traffic can send O2I  traffic to a public IP + Port which exists in NAT DB. Destination IP and  port information is also maintained in NAT DB in this case. VSM implements this behavior (Address-Dependent as well as Address and Port-Dependent)
Port Parity Preservation
Odd port should be translated to Odd port and Even port should be translated to Even port. VSM supports this.
4. Standard Compliance
Following are the important RFCs that the NAT44 solution on VSM complies (most of the cases, fully) to.
RFC Number / IETF Draft Name Title of the Specification Additional Comments
RFC 768 User Datagram Protocol (UDP)
RFC 792 Internet Control Message Protocol (ICMP)
RFC 793 Transmission Control Protocol (TCP)
RFC 959 File Transfer Protocol (FTP)
RFC 1812 Requirements for IP Version 4 Routers
RFC 3954 Cisco System Netflow Services Export Version 9
RFC 4787 Network Address Translation (NAT) Behavioral Requirements for Unicast UDP
RFC 5382 NAT Behavioral Requirements for TCP
RFC 5424 The Syslog Protocol
RFC 5508 NAT Behavioral Requirements for ICMP
RFC 6888 Common Requirements for Carrier Grade NATs (CGN) Evolved from draft-nishitani-cgn
Basic Deployment Scenario: NAT444
This section talks about one of the basic deployment scenario for NAT44 which is called "Double NAT44" or "NAT444".
5. Network Diagram
Following diagram depicts NAT444.
In the above diagram, there are 2 NAT44 instances shown (hence, it is termed as "Dual NAT44" or "NAT444").
  • CPE (Customer Premise Equipment) NAT44 - This typically happens within customer premise. Each customer / end user is given one (or, more) IPv4 address (10.8.1.11 in the above example) by the Service Provider. There could be multiple devices within customer premise which will have IPv4 addresses in 192.168.1.x network (as shown in the above diagram). As an example, CPE NAT44 device translates IPv4 address/Port of 192.168.1.1:4128 to 10.8.1.11:6593, while sending the packet out to provider network. A NAT table is maintained at CPE NAT level as well. But, the scale of this is less (as there won't be too many end devices). As you can see, both Private-side and Public-side IP addresses used here are from RFC 1918 (i.e., Private IPv4 addresses).
  • CGN (Carrier Grade NAT) or LSN (Large Scale NAT) - This happens within the Service Provider network. CGN device (as per the diagram) translates Private IPv4 address/Port of 10.8.1.11:6593 to a public IPv4 address/Port of 170.0.0.1:9185 before sending the packet to Internet. A relatively huge NAT table is maintained at CGN level as it may need to deal with millions of CPEs.
VSM with ASR9K will be positioned as CGN in Service Provider network.
6. NAT44 on VSM Configuration
Before we start configuring NAT44 on VSM, let us understand the following concepts related to NAT44 implementation on VSM.
  • CGN Instance - On each VSM card, we can configure one CGN instance (<cgn1> in the diagram below).
  • NAT44 Instance - On each VSM card, we can configure one NAT44 instance (<nat1> in the diagram below).
  • ServiceInfra interface - ServiceInfra interface is a virtual interface which is used by the internal (to ASR9K) management / control traffic. We need 1 ServiceInfra interface per VSM card. ServiceInfra interface cannot be in any VRF (needs to be in default VRF).
  • ServiceApp interface - ServiceApp interface is a virtual interface which is used to bring CGv6 Application (NAT44) data traffic to VSM card. We need 1 pair of ServiceApp interface for each VRF instance - 1 Inside ServiceApp interface (ServiceApp <x> in the diagram below) to bring Inside traffic to VSM (I2O direction) and 1 Outside ServiceApp interface (ServiceApp <y> in the diagram below) to bring Outside traffic to VSM (O2I direction).
NOTE: ServiceInfra and ServiceApp interfaces are used within the ASR9K router only and do not need to be announced/redistributed into IGP.
  • Inside VRF instance - Within one NAT44 instance, we can have multiple Inside VRF instances. For each Inside VRF instance, we can have different NAT44 parameters configured. Inside ServiceApp must be within one unique Inside VRF. Outside ServiceApp may or may not be within a (Outside) VRF.
NOTEs:
- We cannot have multiple Inside ServiceApps within same Inside VRF.
- We can, however, have multiple Outside ServiceApps within same Outside VRF or default VRF.
- Inside and Outside VRF cannot be same.
  • Logical Partitioning inside VSM - Internally, VSM is divided into 2 Logic Partitions. Hence, in order to achive full throughput and scale limit (per VSM), you should have minimal of 2 Inside VRFs, 4 ServiceApp interfaces (2 in each partition), 2 Public IP address pool, etc. Traffic / subscribers which needs to avail NAT44 service also needs to be divided into 2 groups (each one associated to each Inside VRF). Following table shows the partitioning of ServiceApp interfaces between these 2 groups (which needs to be kept in mind during configuration).
Logical Partition  / Group 1 Logical Partition / Group 2
ServiceApp 1, ServiceApp 2 ServiceApp 3, ServicApp 4
ServiceApp 5, ServiceApp 6 ServiceApp 7, ServiceApp 8
ServiceApp 9, ServicApp 10 ServiceApp 11, ServiceApp 12
ServiceApp 253, ServiceApp 254 ServiceApp 255, ServiceApp 256
NOTE: ServiceApp interafce pair needs to be selected from same Logical Partition (as per the above table). Otherwise, packets will be dropped. Using consecutive numbers for ServiceApp interface pair will be recommended (as shown above).
Following diagram provides summary / overview of NAT44 configuration for VSM.
Below are sample configurations for each of the above steps.
Step 1: Install and Activate CGv6 VM Configure on VSM Card at Slot 1
! Install CGv6 VM's OVA package
RP/0/RSP0/CPU0:ios# virtual-service install name cgn123 package /disk0a:/usr/vsmcgv6.ova node 0/1/CPU0
! Configure and Activate CGv6 VM
RP/0/RSP0/CPU0:ios#conf t
Fri Aug 2 18:10:25.525 UTC
RP/0/RSP0/CPU0:ios(config)#virtual-service cgn123
RP/0/RSP0/CPU0:ios(config-virt-service)#vnic interface tenGigE 0/1/1/0
RP/0/RSP0/CPU0:ios(config-virt-service)#vnic interface tenGigE 0/1/1/1
RP/0/RSP0/CPU0:ios(config-virt-service)#vnic interface tenGigE 0/1/1/2
RP/0/RSP0/CPU0:ios(config-virt-service)#vnic interface tenGigE 0/1/1/3
RP/0/RSP0/CPU0:ios(config-virt-service)#vnic interface tenGigE 0/1/1/4
RP/0/RSP0/CPU0:ios(config-virt-service)#vnic interface tenGigE 0/1/1/5
RP/0/RSP0/CPU0:ios(config-virt-service)#vnic interface tenGigE 0/1/1/6
RP/0/RSP0/CPU0:ios(config-virt-service)#vnic interface tenGigE 0/1/1/7
RP/0/RSP0/CPU0:ios(config-virt-service)#vnic interface tenGigE 0/1/1/8
RP/0/RSP0/CPU0:ios(config-virt-service)#vnic interface tenGigE 0/1/1/9
RP/0/RSP0/CPU0:ios(config-virt-service)#vnic interface tenGigE 0/1/1/10
RP/0/RSP0/CPU0:ios(config-virt-service)#vnic interface tenGigE 0/1/1/11
RP/0/RSP0/CPU0:ios(config-virt-service)#commit
Fri Aug 2 18:11:34.285 UTC
RP/0/RSP0/CPU0:ios(config-virt-service)#activate
Step 2: Configure ServiceInfra interface
! Bring up 10-GE interfaces on VSM
! Must before configuring any ServiceInfra/App interfaces
interface TenGigE 0/1/1/0
  no shut
interface TenGigE 0/1/1/1
  no shut
interface TenGigE 0/1/1/2
  no shut
interface TenGigE 0/1/1/3
  no shut
interface TenGigE 0/1/1/4
  no shut
interface TenGigE 0/1/1/5
  no shut
interface TenGigE 0/1/1/6
  no shut
interface TenGigE 0/1/1/7
  no shut
interface TenGigE 0/1/1/8
  no shut
interface TenGigE 0/1/1/9
  no shut
interface TenGigE 0/1/1/10
  no shut
interface TenGigE 0/1/1/11
  no shut
! Define Service Infra interface
interface ServiceInfra 1
  ! Assign IPv4 address and netmask
  ipv4 address 100.1.1.1 255.255.255.252
  ! Define service location
  service-location 0/1/CPU0
Please note that inside and outside VRFs are also need to be configured, as shown below.
vrf ivrf1
    address-family ipv4 unicast
vrf ivrf2
vrf ovrf1
vrf ovrf2
Once the VRFs are configured, let us proceed with further configuration.
Step 3 and 4: Configure Ingress and Egress LC Interfaces
! Configure Ingress interfaces
interface TenGigE0/0/0/0
 ! Add it to Inside VRF
 vrf ivrf1
 ! Assign IP address to it
 ipv4 address 10.10.10.1 255.255.255.0
interface TenGigE0/0/0/1
 vrf ivrf2
 ipv4 address 10.10.11.1 255.255.255.0
! Configure Egress interfaces
interface TenGigE0/2/0/0
 vrf ovrf1
 ipv4 address 20.20.20.1 255.255.255.0
interface TenGigE0/2/0/1
 vrf ovrf2
 ipv4 address 20.20.21.1 255.255.255.0
Step 5: Configure CGN and NAT44 Service parameters (Important ones are shown)
! Define CGN Instance
service cgn cgn1
 ! Define location
 service-location preferred-active 0/1/CPU0
 ! Define NAT44 Service Type and instance (one per VSM card)
 service-type nat44 nat1
  ! Define per-user Port limit for NAT44 instance
  portlimit 250
  ! Enable Active FTP ALG
  alg ActiveFTP
  ! Define UDP protocol session timeout values
  protocol udp
    session initial timeout 240
    session active timeout 600
  ! Define inside VRF
  inside-vrf ivrf1
    ! Define Public IP address Pool
    map outside-vrf ovrf1 address-pool 100.1.1.0/24
  ! Define inside VRF
  inside-vrf ivrf2
    map outside-vrf ovrf2 address-pool 100.1.2.0/24
Step 6 and 7: Configure Inside and Outside ServiceApp interfaces
! Define Inside Service App interfaces
interface ServiceApp 1
 ! Define VRF where it should belong to (optional)
 vrf ivrf1
  ipv4 address 1.1.1.1/30
  ! Define CGN instance and service type in which it belongs to
  service cgn cgn1 service-type nat44
interface ServiceApp 3
 vrf ivrf2
  ipv4 address 1.1.2.1/30
! Define Outside Service App interfaces
interface ServiceApp 2
 vrf ovrf1
  ipv4 address 2.1.1.1/30
interface ServiceApp 4
 vrf ovrf2
  ipv4 address 2.1.2.1/30
Step 8 and 9: Configure Traffic Diversion Rules
! Define static route for Inside-to-outside traffic
router static
 ! Specify the Inside VRF
 vrf ivrf1
  ! Define address family
   ! Re-direct all traffic to Inside Service App
   0.0.0.0/0 ServiceApp 1
router static
 vrf ivrf2
   0.0.0.0/0 ServiceApp 3
! Define static route for Outside-to-inside traffic
router static
 vrf ovrf1
   100.1.1.0/24 ServiceApp 2
router static
 vrf ovrf2
   100.1.2.0/24 ServiceApp 4
7. I2O Packet Flow on VSM
Following diagram shows the packet flow within ASR9K (including VSM) for Inside to Outside NAT44 traffic at a high-level.
Step 1: Packet from Inside / Private side reaches ASR9K Ingress Line Card.
Step 2: Forwarding lookup (rule added by static route, ACL-based forwarding, etc.) should forward the packet to VSM card, via Inside ServiceApp 1 interface. Inside VRF (ivrf1) will be used during the forwarding lookup.
Step 3: NAT44 Application performs necessary action for the packet. As it is Inside-to-Outside packet, it first checks if there is a NAT entry exists for the source IP (10.10.10.2) and port (5000). If it does not exists, it allocates a Public IP (from the Public IP pool configured) and port and creates a NAT entry. From the NAT entry, it finds the corresponding Public IP (100.2.0.192) and port (23156) and replaces the existing Source IP and port with the same.
Step 4: After NAT translation is done, a forwarding lookup is done in Outside VRF (ovrf1) for the destination IP address (5.5.5.2) which forwards the packet to egress LC interface.
Step 5: Egress Line Card interface sends the packet out to Outside / Public side.
8. O2I Packet Flow on VSM
Following diagram shows the packet flow within ASR9K (including VSM) for Outside to Inside NAT44 traffic at a high-level.
Step 1: Packet from Outside / Public side reaches ASR9K Ingress Line Card.
Step 2: Forwarding lookup (rule added by static route, ACL-based forwarding, etc.) should forward the packet to VSM card, via Outside ServiceApp 2 interface. Outside VRF (ovrf1), if being configured, will be used during the forwarding lookup.
Step 3: NAT44 Application performs necessary action for the packet. As it is Outside-to-Inside packet, it first checks if there is a NAT entry exists for the Destination IP (100.2.0.192) and port (23156). If it does not exists, packet is dropped. Otherwise, from the NAT entry, it finds the corresponding Private IP (10.10.10.2) and port (5000) and replaces the existing Destination IP and port with the same.
Step 4: After (reverse) NAT translation is done, a forwarding lookup is done in Inside VRF (ivrf1) for the destination IP address (10.10.10.2) which forwards the packet to egress LC interface.
Step 5: Egress Line Card interface sends the packet out to Inside / Private side.
Parameters to be considered before Deployment
Before deploying NAT44 solution with VSM, you need to analyze the deployment scenario/requirement and come up with the appropriate values of different configurable parameters related to NAT44. Improper selection of the parameters may not address the deployment goals accurately.
9. Performance and Scale
These are possibly the most important parameters to be considered during deployment. These are not configurable parameters, but these will determine how many VSM cards will be needed for the NAT44 solution.
  • Identify the performance and scale need for NAT44 solution
  • Please check "CGv6 on VSM Feature Support" page, to find out the supported scale and performance values.
Based on the above two, find out how many VSM cards will be needed for the solution.
NOTE: For better NAT44 performance, Cisco recommends keeping the default physical interface MTU size on the customer-facing interfaces in NAT44 deployment.
10. Address Pool and Mapping
Identify the following for the deployment scenario.
  • How many Public IPv4 addresses the customer has to form the Public IP pool ?
  • How many (approximately) Private (Pre-NAT) IPv4 addresses the customer has ?
  • Do you need to limit the ratio of Private to Public IP addresses ?
Based on the same, number of inside VRFs, address pools, many-to-one ratio can be configured as follows.
Address Mapping related parameter configuration
service cgn cgn1
  inside-vrf ivrf1
   map outside-vrf ovrf1 address-pool 100.1.1.0/20
   ! Define Many to one IP addresses maping
   map ip many-to-one 6
NOTE: Network address and Broadcast address in the subnet (as configuredby address-pool parameter) are also used as NAT'ed Public / Outside IP address.
11. VRF (Inside and Outside)
Identify the following VRF related information from deployment requirement.
  • Whether Private side traffic comes / can / should come in VRF or not ?
  • Whenther Public side traffic can / should go in a VRF or not ?
  • Is there a overlap of Private IP addresses or not ?
  • Are there different values of certain parameters (which are configured per-VRF) needed or not ?
  • What is the Scale and Bandwidth requirement for each VRF
Above information will determine,
  • How many Inside and Outside VRFs will be needed in the solution
  • Which per-Inside VRF parameters need to be set
  • How the Public IP pool needs to be divided
12. Port Limit (Per-User)
As NAT DB is shared among all users, there could be a situation where few users (Private IP owners) uses lots of NAT entries (in thousands) and because of the same, new users cannot create NAT entries. In order to keep control on creation of NAT entries by a single user, Port Limit parameter is introduced. Port limit indicates how many port numbers are allowed per Private / Inside IP address. If any flow arrives after Port Limit is reached, no NAT entry will be created for the same and the packets for the new flows will be dropped. The Port limit value will be same for all Private IP addresses.
NOTE: Port Limit is specified per Private / Inside IP address and NOT per Public / Outside IP address.
Find out the following:
  • How many ports will be needed by a Private IP address holder ?
  • How many Public IP addresses are available ?
Based on the above Port Limit can be configured as follows.
Configuration of Port Limit
service cgn cgn1
  portlimit 250
13. External Logging (Netflow and Syslog)
As you have seen above, a NAT DB entry is created for each new flow (Private IP address and port) which keeps the mapping of Private / Inside IP address + Port and Public / Outside IP address + Port. The NAT DB entry is deleted when the flow terminates (because of timeout and any user intervention).
On VSM, we support millions of NAT translations with high (in thousands and millions) setup and deletion rate (Please refer to CGv6 on VSM Feature List for scale numbers). This produces huge amount of NAT translation entries / records which cannot be stored / saved on VSM or ASR9K because of limited disk space. Hence, there is a need of having external servers where these translations can be saved.
The creation and deletion of NAT transactions (also called "Logging Records") are very important to be saved to get association of different IP addresses. In almost all countries, it is mandated by the Lawful Agencies / Authorities that the Service Provide must provide these records accurately so that the agencies can find out the owner of these APIs for different reasons. Thus it becomes a very important feature for deployment of NAT44.
On VSM, we support the 2 formats of logging records - Netflow (version 9) and Syslog. Table below compares the two.
Items for Comparison Netflow Version 9 (NFv9) Syslog
Standard Document
RFC 3954
RFC 5424
Text / Binary format Binary Text
Underlying Layer 4 protocol UDP (Server usually uses Port 2055, 2056, 4432, 4739, 9995, 9996, 6343) UDP (Server typically uses Port 514)
Average Logging Recod Size 20 Bytes (with DBL and BPA disabled) 70 Bytes (with DBL and BPA disabled)
Usage of Template Uses Netflow Template Does not use any template
Logging records are sent to Logging Server (IP address and Port for which is configurable) either when the Logging packet is complete or timeout occurs. Logging packets are sent with ServiceInfra interface's remote IP (for e.g., 100.1.1.2 is the remote IP of 100.1.1.1) as Source address.
NOTE: External Logging Server IP address should be reachable via any ASR9K LC interface (NOT via Management Ethernet interface), in default VRF.
Destination-Based Logging (DBL)
In some countries, Lawful Agencies also require the Service Provider to provide the Destination IP address and Port (along with Source IP address and Port information) as part of Logging Record. This is termed as Destination-Based Logging (DBL).
NOTE: Including Destination (IP + Port) information in the Logging Record will increase the size of the Record.
DBL can be supported with Netflow v9 as well as with Syslog.
Bulk Port Allocation (BPA)
In order to reduce the size of the logging record, a feature called Bulk Port Allocation (BPA) is introduced.
Without BPA, for every new flow, a Port is allocated for the Public IP and a new logging record is created with Private IP + Port and Public IP + Port. Similarly, another Logging record is created when a flow or NAT entry is deleted.
Following table captures the working of it (without BPA) with some sample IP addresses and port numbers.
Event Inside Source IP + Port Outside Source IP + Port Logging Record Additional Comments
A new flow arrives 10.1.1.1:1000 170.0.0.5:8175 10.1.1.1:1000 <-> 170.0.0.5:8175
New port (8175) allocation happens.
New logging record is created
Existing flow arrives 10.1.1.1:1000 170.0.0.5:8175 N/A
No new Port allocation happens.
No logging record is created
A new flow arrives (with new port, but same IP) 10.1.1.1:2000 170.0.0.5:13591 10.1.1.1:2000 <-> 170.0.0.5:13591
New port (13591) allocation happens.
New logging record is created.
With BPA, for the first new flow, a bulk (group) of Ports are allocated (but only one port from the group is assigned for the new flow) for the Public IP and a logging record is created with Private IP and Public IP + Start Port + End Port. Next time, a new flow comes, a new port from the already allocated pool is taken and no logging record is created. Only when all the ports in the group are used, a new bulk is allocated and logging record is created. Similarly, when all the ports from a group is released, a (deletion) logging record is generated.
Following table captures the working of it (with BPA enabled) with sample IP addresses and port numbers.
Event Inside Source + Port Bulk Port Allocation (size 64) Outside Source IP + Port Logging Record Additional Comments
A new flow arrives 10.1.1.1:1000 Allocates Bulk Port range (8192 - 8255) for 170.0.0.5 170.0.0.5:8201 10.1.1.1 <-> 170.0.0.5:8192-8255
Bulk port allocation and new port (8201) assignment happens.
Existing flow arrives 10.1.1.1:1000 N/A 170.0.0.5:8201 N/A
No logging record is created.
A new flow arrives (with new port, but same IP) 10.1.1.1:2000 N/A 170.0.0.5:8199 N/A
New Port (8199) allocation happens (from same port range).
A new flow arrives (with new port, but same IP) 10.1.1.1:5000 N/A 170.0.0.5:8236 N/A
New Port (8236) allocation happens (from same port range).
Following table illustrates the amount stoage space needed per second with varying translation creation + deletion rate for both Netflow and Syslog (with DBL disabled). It also shows the impact of BPA on the storage.
NAT translation creation + deletion rate per second Netflow without BPA Syslog without BPA Netflow with Bulk size 256 and 50% utilization Syslog with Bulk size 256 and 50% utilization
20,000 0.8 MB 2.8 MB 6.25 KB 21.875 KB
50,000 2 MB 7 MB 15.625 KB 54.6875 KB
100,000 4 MB 14 MB 31.25 KB 109.375 KB
500,000 20 MB 70 MB 156.25 KB 546.875 KB
1,000,000 40 MB 140 MB 312.5 KB 1.093 MB
NOTE: Both DBL and BPA cannot be enabled at the same  time. This is because BPA requires logging record to be generated for a  set of NAT entries whereas DBL requires logging record to be generated  for each NAT entry. These are conflicting requirements.
Please collect the following information and accordingly determine External Logging related parameter configuration.
  • What setup rate needs to be supported ?
  • Do the Lawful Agencies mandate DBL ?
  • What protocol (netflow or syslog) the external logging server support ?
  • How many packets per second the logging server can support ?
  • How many logging servers need to be configured ?
  • How much space would be needed for storing logging record ? How much would the cost of disk space ?
Following table shows how to configure different external logging parameters.
Configuration of External Logging Parameters
service cgn cgn1
  inside-vrf ivrf1
   ! Define Netflow V9 logging configuration
   external-logging netflow version 9
    ! Define netflow server configuration
    server
     ! Define logging server address and port
     address 10.10.0.0 port 2055
     ! Define Path MTU size
     path-mtu 1200
     ! Define refresh rate
     refresh-rate 50
     ! Define timeout
     timeout 50
    ! Define Syslog logging configuration
    external-logging syslog
     server
      address 10.10.0.1 port 514
14. NAT Session Timeouts (TCP, UDP, ICMP)
As the new flows creates NAT entries, we need a way to delete those NAT entries as well. Protocols like UDP is connection-less and hence, there is no way to identify when a session / connection has ended by inspecting the packets. Also, in some cases, if no packet flows between the applications for a long period of time, there is no point in holding on to the NAT entries, as that will disallow creation of new NAT sessions.
Due the above reasons, NAT entries are deleted when session timeout happens.
For every protocol (TCP, UDP, ICMP), we have different types and values of session timeouts, as depicted below.
  • TCP - It has two timeouts.
    • Initial Timeout - It kicks in before the connection moves into Active state. Default: 120 sec.
    • Active Timeout - It kicks in when the connection is in Active state. Default: 30 Minutes.
  • UDP - It has two timeouts as well.
    • Initial Timeout - It kicks in before the connection moves into Active state. Default: 30 sec.
    • Active Timeout - It kicks in when the connection is in Active state. Default: 120 sec.
  • ICMP - It has one timeout. Default: 60 sec.
If the timeout is configured to be too less, NAT sessions will be deleted too soon, resulting in changing of Public IP addresses. This may cause issues with the Applications.
If the timeout is configured to be too high, NAT sessions will remain in the system for long time (even though there is no data is flowing using the session) and it will restrict new sessions to be created as well (resulting in dropping of those packets).
Hence, timeout value needs to be set appropriately.
NOTE: These timeouts are set for the NAT44 instance (per VSM card) and cannot be configured differently for each Inside VRF.
You need to have some knowledge about the following, to determine the timeout values.
  • Application traffic that is going through the network
    • How sensitive it is with respect to change in IP address ?
    • How periodically, it would generate packets
  • How many NAT sessions are expected ?
Following table shows how to configure timeout values for different protocols.
Configuration of Session Timeout (TCP, UDP, ICMP)
service cgn cgn1
  protocol udp
   session initial timeout 65535
   session active timeout 65535
  ! Define TCP protocol session timeout values
  protocol tcp
  ! Define ICMP protocol session timeout value
  protocol icmp
   timeout 908
15. Endpoint Independent and Dependent Filtering (EIF / EDF)
Filtering behavior of NAT is explained in Section 5 of RFC 4787.
When an internal endpoint opens an outgoing session through a NAT,    the NAT assigns a filtering rule for the mapping between an internal    IP:port (X:x) and external IP:port (Y:y) tuple.     The key behavior to describe is what criteria are used by the NAT to    filter (Outside-to-Inside, O2I) packets originating from specific external endpoints. We have the following 3 options here:
  • Endpoint-Independent Filtering (EIF) - NAT forwards any packet destined to X:x, regardless of the external IP address and port source.
  • Endpoint-Dependent Filtering (EDF)
    • Address-Dependent Filtering - NAT forwards any packet destined to X:x, provided it is coming from the external IP to which I2O packets were sent earlier.
    • Address and Port-Dependent Filtering - NAT forwards any packet destined to X:x, provided it is coming from the external IP:port to which I2O packets were sent earlier.
All the behavior are explained in the following diagram with an example scenario.
As shown above, depending on the filtering policy and NAT session DB, O2I packets coming from specific IP and port will be either allowed to cross NAT device (VSM card) or dropped by CGv6 Application on VSM.
Table below shows how to configure CGv6 application on VSM to support different filtering policy.
Configuration for Endpoint-Independent and Endpoint-Dependent Filtering
! To configure Endpoint-Independent Filtering
service cgn cgn1
  inside-vrf ivrf1
   ! Do not specify 'filter-policy' CLI for Endpoint-Independent Filtering
! To configure Address Dependent Filtering
service cgn cgn1
  inside-vrf ivrf1
   ! Filtering policy for Address Dependent Filtering
   filter-policy ignore-port
! To configure Address and Port Dependent Filtering
service cgn cgn1
  inside-vrf ivrf1
   ! Filtering policy for Address and Port Dependent Filtering
   filter-policy
16. Traffic Diversion (to VSM)
We can use different mechanisms to divert the traffic to VSM card (to specific ServiceApp interface).
Default Route
If the inside traffic is arriving on a (Inside) VRF and ALL traffic needs to undergo NAT44 operation, we can add a default route under the VRF to divert traffic to the Inside ServiceApp (as shown below).
Configuration for Traffic Diversion using Default route
router static
 vrf insidevrf1
   0.0.0.0/0 serviceapp 1
Static Route
In some cases, Outside ServiceApp interfaces reside in same / default VRF. Hence, in order to divert O2I traffic to specific Outside ServiceApp interfaces, static route can be used in the following way.
Configuration for Traffic Diversion using Static Route
router static
  ! Diverting traffic for one Public IP pool to one Outside ServiceApp
  100.1.1.0/24 serviceapp 2
  ! Diverting traffic for another Public IP pool to another Outside ServiceApp
  200.1.1.0/24 serviceapp 4
ACL-based Forwarding (ABF)
In certain deployment cases, default route may not work.
  • Deployment Use-case 1: Customer wants to divert traffic coming from specific subscriber network (containing Private IP address) to VSM (for NAT44) and the remaining traffic (which may already contain Public IP address) need not go to VSM.
  • Deployment Use-case 2: Customer wants to distribute subscriber traffic into different Inside VRFs which may go to same VSM card or different VSM cards (but, will certainly using different Public IP pool).
  • Deployment Use-case 3: Subscriber / Access / Inside traffic comes in default / global VRF and we need to distribute the traffic to different Inside ServiceApps which are in different Inside VRFs.
NOTE: Typically, ABF is to be used in Private side / Subscriber side and NOT towards Public / Core / Network side.
In the above cases, ABF provides a very good solution. Below is sample configuration on how to use ABF for traffic diversion.
Configuration for Traffic Diversion using ABF
! Define IPv4 Access List
ipv4 access-list nat44_abf
 ! Divert to ServiceApp 1
 10 permit ipv4 10.0.100.0/24 any nexthop1 vrf ivrf1 ipv4 5.1.1.2
 ! Divert to ServiceApp 3
 20 permit ipv4 10.0.200.0/24 any nexthop1 vrf ivrf2 ipv4 6.1.1.2
 100 permit ipv4 any any
! Configure Ingress Interface
interface TenGigE0/5/0/2
 vrf subscriber
 ipv4 address 10.1.1.1 255.255.255.0
 ! Apply ABF on Ingress Interface
 ipv4 access-group nat44_abf ingress
! Define one Inside ServiceApp interface
interface ServiceApp1
 vrf ivrf1
 ipv4 address 5.1.1.1/30
! Define another Inside ServiceApp interface
interface ServiceApp3
 vrf ivrf2
 ipv4 address 6.1.1.1/30
17. Static Port Forwarding
There is a very important point about Dynamic NAT44. All the NAT translations / sessions are created by I2O traffic. If O2I traffic reaches VSM for which there is no NAT entry, the packets will be dropped. This works fine for most of the cases as the session / traffic is initiated by Applications which reside on Private side.
However, there are cases, where a server resides on the Private side of the network. In this case, there are 2 issues.
  • Clients (on Public side) cannot initiate session to this Server, as those (O2I) packets will be dropped by VSM.
  • Clients do not know the Public IP of the Server (and cannot use Private IP to communicate either)
To address these problems related to Server sitting on Private side of the network, a new feature called "Static Port Forwarding" is introduced. Following diagram explains "Static Port Forwarding" feature functionality.
Using Static Port Forwarding, user can provide the Private IP address and Port (via CLI) and NAT44 Application on VSM generates (dynamically) the corresponding Public IP and Port. Also, these mapping are made permanent - i.e., they do not get timed out and get deleted. The Public IP and port generated by the Application can be added to DNS database and thus made available to all.
With this design, any device on Public side of network can now send traffic to the known Public IP and port (to reach the Server sitting inside Private network). Also, as the NAT entry is permanent, O2I traffic always finds the entry and using the same can translate the packet (without dropping it).
Staic Port Forwarding entries can be created separately for each protocol - TCP, UDP and ICMP. To know the maximum number of such entries, please check CGv6 on VSM Feature page.
NOTES:
- User cannot provide the Outside / Public IP and port while configuring Static Port Forwarding.
- Outside / Public IP is generated by the NAT44 Application and hence, can be random.
- Outside port is usually assigned same as Inside Port, unless the Outside port is already being used
As these are used for Servers located in Private network, it is desirable that the Public IP address remain constant across RP failover.
As Outside / Public IP address for a Static Port Forwarding entry is allocated by NAT44 application based on the instant situation of Public IP availability stock as well as the allocation algorithm's state, it is highly probable that if the Static Port Forwarding entry is deleted and re-added or, if the VSM card is reloaded), it may allocate a different Public IP address.
In order to keep the same Outside IP address, it is recommended to add the Static Port Forwarding configuration as a first thing after VSM card comes up and when there is no NAT traffic on the router / VSM card (could be in a "maintenance window"). That way, every time, VSM is reloaded, the Public IP addresses assigned for Static Port Forwarding entries will remain the same.
Try to find out the following, before using Static Port Forwarding.
  • Will there be any Servers sitting in the Private side of the deployment network ?
  • How many of those Servers will be ?
  • Can the Public IP address of the Servers be random and can be published via DNS or similar mechanism ?
A sample configuration for Static Port Forwarding is shown below.
Configuration for Static Port Forwarding
service cgn cgn1
  service type nat44 nat1
   inside-vrf ivrf1
   map address-pool 180.0.0.0/24
   ! Define TCP related configuration
   protocol tcp
    ! Define Static Port Forwarding configuration
    static-forward inside address 10.0.0.50 port 6050
    static-forward inside address 10.0.0.50 port 80
   ! Define UDP related configuration
   protocol udp
    static-forward inside address 10.0.0.61 port 550
   ! Define ICMP related configuration
   protocol icmp
    ! For ICMP, 'identifier' field in ICMP header is used for 'port'
    static-forward inside address 10.0.0.189 port 750
Following table shows the NAT entries corresponding to the above Static Port Forwarding entries (for TCP protocol).
"show cgn nat44 <> inside--translation" output for Static Port Forwarding
RP/0/RSP0/CPU0:VSM-Lab#show cgn nat44 nat44-1 inside-translation protocol tcp inside-vrf vrf1 inside-address 10.0.0.50 port start 25 end 8000
Fri Nov  1 13:44:44.874 UTC
Inside-translation details
NAT44 instance : nat44-1
Inside-VRF     : vrf1
  Outside         Protocol  Inside       Outside       Translation   Inside      Outside
  Address                   Source       Source        Type          to          to
                             Port         Port                        Outside     Inside
        Packets     Packets
  180.0.9.0          tcp       80           80            static       1218         45
  180.0.9.0          tcp     6050         6050            static        516       7162
NOTE:
- Outside IP (180.0.9.0) and Ports are assigned by the NAT44 Application when user supplies Inside IP (10.0.0.50) and Ports (80, 6025).
- "Translation Type" is shown as "static" (as opposed to "dynamic")
- Outside port is same as Inside port (usually, unless it is not available)
18. Application Layer Gateway (ALG)
Application Layer Gateway (ALG) is a device which has the capability of inspecting into a packet beyond layer 4 and can change Application layer content to meet certain need.
NAT44 changes IP address and Layer 4 (UDP/TCP/ICMP etc.) port. There are certain applications which embeds IP address and/or Port information in Application content. Now, the issue is while the packet traverses across a NAT44 device, layer 3 and 4 addresses get changed. However, in the Application layer, the content still contains old layer 3 and / or layer 4 addresses. This causes an issue in the Application as this is unexpected. Hence, the need of ALG functionality within a NAT device which while changing Layer 3 and 4 packet content, also changes Application content where Layer 3 and 4 addresses were embedded. With this change, end Application will be happy as it does not need to deal with 2 sets of addresses any more.
However, there are 2 ways this problem can be solved.
  • Adding ALG functionality to NAT device - ALG functionality needs to be added to NAT device for each such Applicaton which embeds Layer 3 and/or 4 addresses in Application content.
  • Changing the Application to deal with NAT device in the network - Application needs to assume that the Layer 3 and/or 4 address can get changed on the way (as there could be NAT device in the network) and hence, either avoid embedding Layer 3/4 addresses in Application content or find other mechanism to handle 2 sets of addresses.
The main challenges in adding ALG functionality to NAT device are:
  • Every time a new Application is written which embeds Layer 3/4 address in Application content, all NAT devices need to be changed to address the new Application. This is not scalable as lot of new Applications are written everyday.
  • In order to implement ALG for an Application, NAT device needs to understand the Application protocol as well as packet formt/content. Many Applications implement proprietary protocol and hence, do not want to make the same as public information. Hence, those Application packets will face issues with NAT device.
  • There are applications (like, crypto) which do not want any intermediate device to understand / peek into the Application content and modify it. These packets should only be encoded/decoded by end Applications. These application packets would not be able to deal with intermediate NAT device.
On the contrary,
  • Application can be written in such a way not to use Layer 3/4 addresses in Application content and to use Application-level ID, instead.
  • There can be other mechanisms, e.g. - using STUN (Session Traversal Utilities for NAT) that applications can take to handle intermediate NAT device.
NOTE: Due to the above reasons, our solution does not encourage to support ALG within NAT44 functionality.
However, few basic ALG functionality is implemented with NAT44 Application. These are:
  • Active FTP (File Transfer Protocol) - Passive FTP does not need ALG.
  • RTSP (Real Time Streaming Protocol)
  • PPTP (Point-to-Point Tunneling Protocol)
Following table show how to configure / enable different ALGs on VSM.
Configuration of ALGs
service cgn cgn1
   alg ActiveFTP
    ! Enable RTSP ALG
    alg rtsp
   ! Enable PPTP ALG
   alg pptpAlg
19. Redundancy
Redundancy is an integral part of CGN (Carrier Grade NAT). Majority of the Service Providers want Redundancy in their network to make it more resilient. It helps in minimizing the traffic outage when one device fails.
On VSM, we support 2 types of redundancy.
  • N:1 ABF-based redundancy (N can be 1 as well)
  • 1:1 Warm Stand-by Redundancy (starting from XR release 5.2.2)
N:1 ABF-Based Redundancy
In this case, there needs to be N Primary VSM card and 1 Backup VSM card. Value of N can be 1 as well, but typically would be 2 or 3. Following are different characteristics of this solution.
  • Each VSM card needs to be configured independently
    • Configuration (usually) should be similar (w.r.to parameters, number of ServiceApp interfaces, etc.)
  • In ABF configuration, For each Primary VSM,
    • ServiceApp interface on Primary VSM becomes 1st Next-Hop and ServiceApp interface on Back-up VSM becomes 2nd Next-hop
  • Each VSM will have different Public IP address pools (Address Pool is not same in Primary and Backup)
  • When one Primary VSM card fails, Backup VSM card receives all the traffic of Primary VSM card.
  • When Primary VSM card comes up, all traffic again switches back to it from Backup VSM card (it causes, another traffic outage)
  • Each VSM card can support full scale and bandwidth
Following table shows how the ABF Next-Hop configuration would look like for N:1 (N = 3) ABF-based Redundancy.
ServiceApp interfaces ABF Next-Hop 1 ABF Next-Hop 2
ServiceApp interfaces on Primary VSM 1 ServiceApp interfaces on Primary VSM 1
ServiceApp interfaces on Backup VSM
ServiceApp interfaces on Primary VSM 2
ServiceApp interfaces on Primary VSM 3
Following diagram depicts N:1 (N = 2) configuration with 1 set of ServiceApps.
As shown in the diagram,
  • before 1st failure, traffic coming from 10.2.0.0/24 subnet will go via Primary 1 VSM (Inside ServiceApp 1) which will use Public IP pool of 151.0.1.0/24.
  • if and when Primary 1 VSM fails, traffic coming from 10.2.0.0/24 subnet will go via Backup VSM (Inside ServiceApp 5) which will use Public IP pool of 151.0.3.0/24.
  • Instead of Primary 1 VSM, if Primary 2 VSM would have failed, traffic from 10.2.1.0/24 (not 10.2.0.0/24) should have switched to Backup VSM.
Following table captures the relevant ABF configuration for this sample setup.
Sample Configuration for N:1 Redundancy using ABF
! ABF rule for Inside to Outside traffic
ipv4 access-list abf_2_1
  10 permit ipv4 10.2.0.0/24 any nexthop1 vrf inside1 ipv4 1.1.1.2
                                 nexthop2 vrf ibackup ipv4 1.1.5.2
  20 permit ipv4 10.2.1.0/24 any nexthop1 vrf inside2 ipv4 1.1.3.2
  30 permit ipv4 any any
! Static route for Outside to Inside traffic
router static
    151.0.1.0/24 ServiceApp 2
    151.0.2.0/24 ServiceApp 4
    151.0.3.0/24 ServiceApp 6
In this mode, one VSM card acts as Primary and another as backup. Following are the properties of 1:1 Warm Stand-by redundancy.
  • Easy to configure (Active and Stand-by locations are specified once)
  • A single Public IP address pool is used
  • Configuration is sent to both VSM cards
  • NAT Application data traffic reaches to Active card only
  • During switchover (usually takes few seconds), dynamic NAT entries get deleted (on failed VSM cards) and re-created on newly Active VSM card. Hence, there would be some traffic drop. Also, Private to Public IP/Port mapping gets changed during Switchover.
  • When the previously Active VSM comes up, it stays as Stand-by and the traffic does not come back to it (until the Active VSM card fails)
  • Each VSM can support full scale and throughput
Following diagram explains the working of 1:1 Redundancy for NAT44.
1:1 Warm standby redundancy
Please note that both Primary and Backup VSM cards share same ServiceApp interfaces and NAT44 configuration (including Public IP pool).
Following tables shows how to configure 1:1 VSM redundancy.
Configuration for 1:1 Warm Standby Redundancy
! Configure preferred-active and preferred-standby VSM
service cgn cgn1
  service-location preferred-active 0/1/cpu0 preferred-standby 0/2/cpu0
    inside-vrf inside1
      map address-pool 151.0.1.0/24
      ! Remaining configurration
To check the health of the VSM card and trigger redundancy switchover, in case any failure occurs, following HA-specific test can be enabled:
  • Data Path Test - It checks if the packet path from CGv6 Application to Fabric works fine or not.
If the test is enabled and any failure is detected by the test, the VSM card will be reloaded.
NOTE: By default, these tests run in the back-ground however, no acton is taken in case failure is detected. Using the following CLI, the test is enabled.
Configuration of HA  Data-Path tests
! To enable Data Path Test
service-cgv6-ha location 0/1/cpu0 datapath-test
20. NAT44 Licenses
In order to use NAT44 functionality on ASR9K, Licenses needs to be purchased. Depending on the number of Stateful Translations needed by the solution, required number of NAT44 specific licenses can be purchased. This fits nicely with "Pay as you grow" model as well.
Following licenses need to be purchased for NAT44 and other CGv6 applications.
License Part Number License Description Additional Comments
A9K-VM-LIC Cisco ASR 9000 Application VM License For launching (activating) any Application VM, this license is needed. When CGN software is ordered, one free A9K-VM-LIC will be provided along with it.
A9K-XLAT-LIC-5M Cisco ASR 9000 CGN / NAT44 License (1 per 5 million translations)
For 60 Millions translations, 12 of these licenses will be needed.
Same license is applicable for both ISM as well as VSM cards.
Details of the Licensing (how to install, etc.) can be obtained from ASR9K S/w License Operations White Paper.
21. Summary of parameter values
In the following table, all the useful parameters are listed along with their default and valid range of values. You can consult this table to come up with the parameter value for your deployment case.
Parameter (CLI) Defined at what level Default Value Range of Values Supported from XR Release Additional Comments
alg ActiveFTP
per NAT44 instance
Disabled
Enable / Disable 5.1.1 Active FTP ALG
alg pptpAlg
per NAT44 instance
Disabled Enable / Disable 5.1.1 PPTP ALG
alg rtsp
per NAT44 instance
Disabled Enable / Disable 5.1.1 RTSP ALG
bulk-port-alloc size
per Inside VRF Disabled
16, 32, 64, 128, 256, 512, 1024, 2048, 4096
5.1.1
dynamic-port-range start
per NAT44 instance 1024 1 - 65535 5.1.1
Starting port number (for Public IP address) to be used for Dynamic NAT entries.
external-logging netflow v9 server path-mtu per Inside VRF 1500 bytes 100 - 2000 5.1.1
external-logging netflow v9 server refresh-rate per Inside VRF 500 packets 1 - 600 5.1.1
For sending NFv9 template
external-logging netflow v9 server timeout per Inside VRF 30 seconds 1 - 3600 5.1.1 For sending NFv9 template
external-logging syslog server path-mtu
map ip one-to-one per Inside VRF Disabled 1 - 65535 5.1.1
portlimit per NAT44 instance 100 1 - 65535 5.1.1
protocol udp session initial timeout
per NAT44 instance 30 sec 1 - 65535 5.1.1
protocol udp session active timeout
per NAT44 instance 120 sec 1 - 65535 5.1.1
protocol tcp session initial timeout
protocol tcp session active timeout
per NAT44 instance 1800 sec 1 - 65535 5.1.1
protocol tcp mss per Inside VRF   28 - 1500 bytes 5.1.1
22. NAT44 Configuration / Feature Differences with ISM
Parameter / Criteria ISM Value VSM Value Additional Comments
Number of ServiceApp Interfaces 244 256
Number of NAT44 Translations 20 Millions 60 Millions
End-point Dependent Filtering Not Supported Supported
TCP Sequence Check Not Supported Supported
CLI: map ip many-to-one Supported Not Supported Will be supported on VSM in future release
Minimum number of Public IPv4 addresses in a Pool 4 (i.e., /30) 32 (i.e., /27)
Back to top
23. MTU and Fragmentation Considerations
Configure the MTU on physical VSM interfaces to 1518.
Specific Deployment Scenarios / Use-Cases
In this section, specific deployment scenarion / use-cases and presented which can be useful for some deployment.
24. Sample Applications over NAT44
Following table lists some of the important / well-known applications and their working status over NAT44 (on VSM).
NOTE:
- This list is not a complete/exhaustive list of applications that would work with NAT44.
- It also does not mean that any application not listed here will not work with NAT44.
Application Details of Application (Protocol / Port) Working Status with NAT44
HTTP Typically HTTP server runs over TCP Port 80 Works with NAT44
E-mail Typically uses TCP, server ports: SMTP (25, 587), POP3 (110), IMAP (143)
Works with NAT44
FTP Typically uses TCP port 20 (data) and port 21 (control) Works with NAT44
Telnet Typically uses TCP port 23 Works with NAT44
SSH Typically uses TCP port 22 Works with NAT44
VNC Typically uses TCP port 5900, 5800, 5500 Works with NAT44
VPN Client (SSL) Typically uses TCP Works with NAT44
VPN Client (PPTP+GRE) Typically uses TCP and GRE Works with NAT44
VPN Client (IPSec) Typically uses IPSec (via NAT-T) Works with NAT44 (as NAT-T uses UDP)
Xbox Gaming   Works with NAT44
25. Multiple Outside ServiceApps sharing same Outside VRF
It is very common to have default VRF as Outside VRF and when there are multiple Inside VRFs mapped to the same. In the following table, a sample ServiceApp and VRF configuration is shown. Please note that in this case, multiple Outside ServiceApps share share a comon Outside VRF.
Inside VRF Inside ServiceApp Outside VRF Outside ServiceApp
ivrf1 ServiceApp 1 default or ovrf ServiceApp 2
ivrf2 ServiceApp 3
default or ovrf
ServiceApp 4
To handle this scenario, we need to specify "outsideServiceApp" parameter configuration to indicate what is the Outside ServiceApp to be used with the mapping. Static route rule for specific Public IP address pool should guide the traffic to specific Outside ServiceApp. Only these configurations are shown below. Rest of the configuration remain the same.
Configuration for Shared / Common Outside VRF
service cgn cgn1
    ! 1st Inside VRF
    inside-vrf ivrf1
      ! MAP command using outsideServiceApp
      map [outside-vrf ovrf] outsideServiceApp ServiceApp2 address-pool 100.0.1.0/24
    ! 2nd Inside VRF
    inside-vrf ivrf2
      map [outside-vrf ovrf] outsideServiceApp ServiceApp4 address-pool 100.0.2.0/24
router static
[vrf ovrf]
! Divert traffic to 1st Outside ServiceApp
100.0.1.0/24 ServiceApp 2
    ! Divert traffic to 2nd Outside ServiceApp
    100.0.2.0/24 ServiceApp 4
26. NAT Bypass
There is an use-case where traffic selected traffic coming onto ASR9K via a Private side interface needs to go via NAT44 application, whereas remaining traffic can bypass NAT44 and should get forwarded via regular forwarding rule. This is called NAT bypass.
To implement NAT bypass, let's consider this situation:
  • Private Traffic enters ASR9K via one VRF (say, RED)
  • Selected traffic gets diverted to VSM card's Inside ServiceApp which is in different VRF (say, BLUE) and after translation comes out of Outside ServiceApp and eventually goes out of ASR9K via core-facing interface which is in RED VRF.
  • Rest of the traffic (which bypasses NAT44) goes out of ASR9K via same core-facing i/f in RED VRF.
Please note that other than NAT bypass, there could be other deployment scenario where preserving VRF (across VSM) becomes a necessity. But, the solution would be same / very similar.
The above scenario can be achieved using VSM with some additional ABF and Static Route and appropriate VRF configuration.
Let us take a look at the following diagram as a sample scenario.
In the above diagram, traffic enters and exits out of ASR9K in RED VRF. Also, please note that Inside ServiceApp is in BLUE vrf whereas Outside ServiceApp is in RED VRF.
Following table shows the specific or additional configuration that is needed for appropriate traffic diversion.
Additional Configuration to support NAT Bypass
! Define ACL to divert traffic to ServiceApp 1 (RED to BLUE VRF)
ipv4 access-list cgn_abf
  ! Divert traffic to ServiceApp 1 in BLUE VRF
  10 permit ipv4 10.10.10.0/24 any nexthop1 vrf BLUE ipv4 1.1.1.2
  20 permit ipv4 any any
! Apply ABF on Ingress LC interface
interface TenGigE 0/0/0/0.1
  vrf RED
  ipv4 address 10.10.10.1/24
  ! Apply Ingress ABF
  ipv4 access-group cgn_abf ingress
! We need a special static route to divert O2I traffic (after reverse NAT)
! to the right interface
router static
  ! After reverse NAT, look-up is done in BLUE (Inside) VRF
  vrf BLUE
      ! Divert to TenGigE 0/0/0/0.1 interface
      10.10.10.0/24 vrf RED 10.10.10.2
27. MPLS (Layer 3) VPN and NAT Interworking
An Multiprotocol Label Switching (MPLS) Layer 3 Virtual Private Network (L3VPN) consists of a set of sites that are interconnected by means of an MPLS provider core network. At each customer site, one or more customer edge (CE) routers attach to one or more provider edge (PE) routers.
MPLS VPNs are easier to manage and expand than conventional VPNs. When a new site is added to an MPLS VPN, only the edge router of the service provider that provides services to the customer site needs to be updated. The components of the MPLS VPN are described as follows:
  • Provider (P) router — Router in the core of the provider network. PE routers run MPLS switching and do not attach VPN labels to routed packets. VPN labels are used to direct data packets to the correct private network or customer edge router.
  • Provider Edge (PE) router — Router that attaches the VPN label to incoming packets based on the interface or subinterface on which they are received, and also attaches the MPLS core labels. A PE router attaches directly to a CE router.
  • Customer edge (CE) router — Edge router on the network of the ISP that connects to the PE router on the network. A CE router must interface with a PE router.
Details on L3VPN can be obtained from ASR9K MPLS Layer 3 VPN Configuration Guide.
Service providers and enterprises that have network application services they want to offer or share with customers and partners will want to      minimize any connectivity burden placed on the user of the service. It is desirable, even mandatory, to extend the offering to as many potential users as needed to achieve the desired goals or return.
By deploying NAT within the common MPLS VPN infrastructure, communications service providers can relieve some of the connectivity burden on      customers and accelerate their ability to link more shared application services to more consumers of those services
There are two options for NAT deployment within the MPLS provider edge:
  • Distributed with ingress NAT PEs
  • Centralized with egress NAT PEs
Following diagram shows Distrbuted NAT scenario with Ingress NAT PEs.
With this design, scalability is maintained to a large extent while performance is optimized by distributing the NAT function over many edge devices. Each NAT PE handles traffic for sites locally connected to that PE. NAT rules and access control lists or route maps control which packets require translation.
In the above case, at ingress PE router, customer private IP addresses are NAT'ed to public IP address by VSM card and then MPLS labels are added by it before the packet goes out of ASR9K. On the return path, MPLS label(s) are removed by MPLS-facing LC and IT packets are sent to VSM. VSM performs reverse NAT and sends the packet to LC which then sends it back to CE router.
With this design, scalability is reduced to some degree since the central PE must maintain routes for all customer networks that access the shared service. The application performance requirements must also be considered so that the traffic does not overburden the router that must translate the IP addresses of the packets. Because NAT occurs centrally for all customers using this path, IP address pools can be shared; thus, the total number of subnets required is reduced.
In the above case, in the egress PE router, first MPLS labels are removed by ingress LC and the IP packet is sent to VSM card. Customer private IP addresses are NAT'ed to public IP address by VSM card and the packets are forwarded to shared service network. In the reverse path, VSM translates Public destination IP to private IP addresses and then adds MPLS labels before sending it to egress LC. Egress LC swaps one label and sends the packet out of ASR9K towards MPLS network.
NOTE: MPLS labels should be removed by LC before sending the packet to VSM as IP packet. However, VSM can add the required MPLS labels before sending the packet to egress LC.
For sample MPLS VPN configuration, please refer to "Configuration Example: MPLS VPN on XR" document.
28. NAT Hairpining
Host behind a NAT device (on Private side) communicating with another host behind the same NAT device (on Private side) is called "NAT Hairpinning". Let us consider the following deployment use-case.
We have a server behind a NAT device which has a Public IP as well, created using Static Port Forwarding configuration. Now, this server can be accessed from hosts on public side of NAT device as well as Private side of the NAT device. When a host on Private side of the NAT device tries to communicate with the Server, it uses NAT Hairpinning. Following diagram depicts how NAT hairpinning works with NAT44 on VSM.
In this case, we first add a Static Port Forwarding entry for a service offered by the Server at 10.100.1.2:2055. Let's say, the Public IP pool configured is 200.2.0.0/24. NAT44 application allocates Public IP and port as 200.2.0.210:2055 (Please note that the port is preserved here). This Public IP and port is published / made available to the hosts. Let's the packet flow now when a host with Private IP 10.10.10.2 tries to access the service.
  • Step 1: Host sends a packet (with Source IP 10.10.10.2 and port 3000) to Server's Public IP and port and the packet reaches ASR9K on TenGigE 0/0/0/0.1 which is in VRF ivrf.
  • Step 2: Because of Static Route configuration in VRF ivrf, the packet is forwarded to VSM card via (Inside) ServiceApp 1 interface.
  • Step 3: Application treats this as I2O packet. A new dynamic NAT entry is created by NAT44 application and it translates source IP/Port from (Private) 10.10.10.2:3000 to (Public) 200.2.0.192:23516. Please note that the Destination IP address and port are not touched here. The packet is sent out and because of Static route definition for Public IP pool, the packet comes back to VSM card via (Outside) ServiceApp 2.
  • Step 4: Application treats this as O2I packet. As there is already a (Static) NAT entry exists for Destination IP and port, NAT44 application translates Destination IP address/Port from (Public) 200.2.0.210:2055 to (Private) 10.100.1.2:2055. Please note that the Source IP address and port are not touched here. The packet is sent out and via regular forwarding rule, it reaches egress i/f TenGigE 0/0/0/0.2.
  • Step 5: The packet is forwarded to the Server with Source IP/Port as 200.2.0.192:23516 and Destination IP/Port as 10.100.1.2:2055 and the server consumes it.
Response from the Server will take the reverse path and it will use Dynamic NAT rule in first reverse NAT and then Static NAT rule in second NAT processing, to reach the host.
In this case, Static Port Forwarding configuration is used for Server as an use-case. But, it can be another host as well for which there is no Static Port Forwarding configuration. Only important thing is sender needs to know the Public IP and port of the receiver.
Please note that there is no specific NAT44 configuration is needed for this. Regular / basic NAT44 configuration will work here. Hence, no configuration is provided here.
29. Handling of Asymmetric I2O and O2I traffic with better performance
Unlike ISM card, we do NOT need to make any special configuration (like, dividing traffic into 2 sub-groups) for VSM. As long as I2O + O2I traffic do not exceed the capacity of the CGv6 Application instances, direction of traffic does not matter i.e., I2O and O2I traffic do not need to be equally balanced.
Validation of Configuration
Once NAT44 on VSM is configured, we need different ways (mainly, via "show" CLIs) to validate those. In this section, important NAT44 related CLIs are listed and also explained how those can be used for validation.
30. show run
As a first step, different "show run" output should be verified to ensure that configuration commands are rightly applied. Following commands can be used.
'show run' commands Usage of it
show running-configuration  or show run
- Displays all the configuration on ASR9K.
- If you have less configuration, this is better way to get all NAT44 configuration at one shot.
- Otherwise (if you have lot of configuration, this may not be the best way to get all NAT44 configuration
show run service cgn * - Displays only CGN related information
show run interface service*
- Displays all ServiceInfra and ServiceApp interface configuration
- Also includes Service-Mgmt and Service-Engine interface configuration (which can be ignored)
show run router static - Displays all static route information.
31. show virtual-service list
This CLI will list down the services that are installed and running on ASR9K chassis.
Sample "show virtual-service list" CLI Output
RP/0/RSP1/CPU0:SERVICE_PE2_1#show virtual-service list
Tue Dec 24 15:35:50.161 UTC
Virtual Service List:
Name                   Status            Package Name             Node Name
______________________________________________________________________________
cgn1                   Activated         vsmcgv6.ova               0/1/CPU0
32. show virtual-service detail
This CLI shows detail information about the CGv6 service VM (mainly, what h/w resources are given to it, etc.), as shown below.
Sample "show virtual-service detail name <>" Output
RP/0/RSP1/CPU0:SERVICE_PE2_1#show virtual-service detail name cgn1
Tue Dec 24 15:38:20.951 UTC
Virtual Service cgn1 Detail
  State                   : Activated
  Node name               : 0/1/CPU0
  Node status             : Install Mgr Ready, SDR Mgr Ready
  Package information
    Path                  : disk0:/vsmcgv6.ova
    Application
      Installed version   : 1.0
      Description         : Carrier Grade NAT
    Signing
      Key type            : Unknown Package
      Method              : SHA1
    Licensing
      Name                : Not Available
      Version             : Not Available
  Activated profile name  : None
  Resource reservation
   Disk   : 10000MB
   Memory : 32768MB
   CPU    : 75 (system CPU %)
   VCPU   : 60
  Attached devices
  #             Type Name      Alias
  1         Watchdog None      None
  2            CDROM hdc       ide0-1-0
  3              HDD hda       DD_10GB_UM_local
  4       Serial/aux None      serial1
  5     Serial/shell None      serial0
  6              NIC net1      net1
  7              NIC net1      net1
  8              NIC net1      net1
  9              NIC net1      net1
  10             NIC net1      net1
  11             NIC net1      net1
  12             NIC net1      net1
  13             NIC net1      net1
  14             NIC net1      net1
  15             NIC net1      net1
  16             NIC net1      net1
  17             NIC net1      net1
Network interfaces:
    Name
    TenGigE0/1/1/0
    TenGigE0/1/1/1
    TenGigE0/1/1/2
    TenGigE0/1/1/3
    TenGigE0/1/1/4
    TenGigE0/1/1/5
    TenGigE0/1/1/6
    TenGigE0/1/1/7
    TenGigE0/1/1/8
    TenGigE0/1/1/9
    TenGigE0/1/1/10
    TenGigE0/1/1/11
  Resource admission (without profile)
    Disk space            : 10000MB
    Memory                : 32768MB
    CPU                   : 100% system CPU
    VCPUs                 : 60 (sockets:3 cores:10 threads:2)
33. show cgn nat44 <> statistics
This is a very important CLI related to NAT44. A sample output of the CLI is shown below.
Sample "show cgn nat44 <> statistics" CLI Output
RP/0/RSP0/CPU0:#Show cgn nat44 nat statistics
Fri Sep 16 23:12:40.018 UTC
Statistics summary of NAT44 instance: 'nat'
Number of active translations: 92400
Number of sessions: 30706
Translations create rate: 542
Translations delete rate: 1206
Inside to outside forward rate: 147827
Outside to inside forward rate: 204847
Inside to outside drops port limit exceeded: 10167470
Inside to outside drops system limit reached: 0
Inside to outside drops resource depletion: 0
No translation entry drops: 9453431
PPTP active tunnels: 3
PPTP active channels: 2
PPTP ctrl message drops: 1246
Number of subscribers: 0
Drops due to session db limit exceeded: 0
Pool address totally free: 499
Pool address used: 1549
Pool address usage:
  External Address       Ports Used
  200.0.9.0           79
  200.0.9.2           16
  200.0.9.8           57
  200.0.9.12         36
  200.0.9.16         78
  200.0.9.20         52
  200.0.9.24         65
  200.0.10.1        2
  200.0.10.24      1
  200.0.10.26    1
Following table explains the impotant fields from the above CLI and how it can be used for validation.
Please note that the values displayed by the CLI is valid at that instant for that particular VSM card. It may change at a later point of time.
Field Name Description Additional Comments for Validation
Number of NAT DB (Static + Dynamic) Entries Monitoring this over a period of time will provide the NAT44 translation scale used in the VSM card.
Number of sessions
Number of Session DB (Static + Dynamic) Entries
Monitoring this over a period of time will provide the NAT44 session  scale used in the VSM card.
Number of NAT44 translations created in last 1 second
Monitoring this over a period of time will provide the NAT44 session  setup rate on the VSM card.
Number of NAT44 translations deleted  in last 1 second
Monitoring this over a period of time will provide the NAT44 session  teardown rate on the VSM card.
Number of packets gone through NAT44 translation in I2O direction in last 1 second
Monitoring this over a period of time will provide the NAT44 packet processing rate on VSM card (PPS) in I2O direction
Number of packets gone through NAT44 translation in O2I direction in last 1 second
Monitoring this over a period of time will provide the NAT44 packet processing rate on VSM card (PPS) in O2I direction
Number of I2O packets dropped because no NAT entries cannot be created for the specific users which has reached port limit. If you have configured port limit value too less, you may hit this errors very often. You may need to consider to increase the port limit configuration in that case.
Number of I2O packets dropped because NAT DB or User DB is full.
In case you are hitting this very often, you may need to check if you're hitting the scale limit and if so, you may need to go for another VSM card.
Number of I2O packets dropped because Layer 4 port could not be allocated.
Number of O2I packets dropped because there was no NAT entry existing.
Number of NAT Users
Number of I2O packets dropped because Session DB is full.
34. show cgn nat44 <> inside-translation
This command is helpful in seeing the list of all Outside / Public IP address + Port mapping for a specific Inside / Private IP address (and a Port range).
Following is a sample output of the command.
Sample "show cgn nat44 <> inside-translation" CLI Output
RP/0/RSP0/CPU0:McKinely#show cgn nat44 nat1 inside-translation protocol udp inside-vrf red
                        inside-address 10.2.5.134 port start 1 end 4580
Wed May 15 14:25:09.713 UTC
NAT44 instance : nat1
Inside-VRF     : red
        Packets     Packets
  100.200.2.75       udp     4500         65024         dynamic       9236        2213
  100.200.2.75       udp     4501         65153         dynamic       2236        0
  100.200.2.75       udp     4502         65152         dynamic       4232        1218
  100.200.2.75       udp     4503         65155         dynamic       2236        7128
  100.200.2.75       udp     4504         65154         dynamic       2235        1821
  100.200.2.75       udp     4505         65157         dynamic       5236        3129
  100.200.2.75       udp     4506         65156         dynamic       2238        8172
  100.200.2.75       udp     4507         65159         dynamic       7238        2189
  100.200.2.75       udp     4508         65158         dynamic       2236        3119
  100.200.2.75       udp     4576         65226         dynamic       1239        2178
  100.200.2.75       udp     4577         65229         dynamic       8235        4171
  100.200.2.75       udp     4578         65228         dynamic       2235        0
  100.200.2.75       udp     4579         65231         dynamic       4230        4127
  100.200.2.75       udp     4580         65230         dynamic       2235        0
RP/0/RSP0/CPU0:#
Above table shows all Outside IP (100.200.2.75) and Port combination for Inside IP (10.2.5.134) and Port Range (1 through 4580).
NOTE:
- As one Inside address can only map to one Outside address, there are not multiple Outside addresses in 1st column.
- The number of entries in this table should not exceed Port Limit value.
35. show cgn nat44 <> outside-translation
This command is helpful in seeing the list of all Inside / Private IP address + Port mapping for a specific Outside / Public IP address (and a Port range).
Sample "show cgn nat44 <> outside-translation" CLI Output
RP/0/RSP0/CPU0:McKinely#show cgn nat44 nat1 outside-translation protocol udp
                        outside-address 100.200.2.75 port start 1 end 65535
Wed May 15 14:17:44.640 UTC
Outside-translation details
Outside-VRF    : default
   Inside          Protocol  Outside      Inside         Translation  Inside      Outside
   Address                   Destination  Destination    Type         to          to
        Packets     Packets
  10.2.5.134         udp     65024        4500          dynamic       4236        1216
  10.2.5.134         udp     65025        4885          dynamic       9233        5161
  10.2.5.134         udp     65026        4886          dynamic       4244        3491
  10.2.5.134         udp     65027        4887          dynamic       1281        6018
  10.2.5.134         udp     65028        4888          dynamic       2237        4187
  10.2.5.142         udp     65532        4882          dynamic       6261        3178
  10.2.5.142         udp     65533        4881          dynamic       7282        0
  10.2.5.142         udp     65534        4884          dynamic       1211        4178
  10.2.5.143         udp     65535        4883          dynamic       1261        5189
RP/0/RSP0/CPU0:#
Above table shows all Inside IPs (10.2.5.134, 10.2.5.142) and Port combination for Inside IP (100.200.2.75) and Port Range (1 through 65535). In this case, there are multiple Inside IP addresses are mapped to one Public IP address.
Monitoring CGN Using SNMP
The attached CGN_MIB_Parameters.xlsx sheet lists the parameters supported in the CGN implementation on VSM/ISM.
Useful Deployment Tips
  • Go through this Deployment Guide to clearly understand
    • how different feature works
    • what parameters are configurable and need to be considered for specific deployment
    • what are the different deployment use cases.
  • Go through "CGv6 on VSM: Features Supported Across IOS-XR Release" page  to exactly know from which release specific features that you're  interested in are supported. This will help you in selecting the right  IOS-XR release.
  • Select the configuration parameter values wisely, considering
    • pros and cons,
    • best-case and worst-case scenarios
    • side effects
  • Draw network diagram for deployment use-case including interface names (with VRF and IP address/subnet) and review for correctness.
  • Try to find out what type of application traffic (VPN, Games, SIP, Video, etc.) may undergo NAT44 and whether there could be issues or not (not all applications are NAT friendly)
    • If possible, try it in a lab setup, before actual deployment
  • Estimate traffic throughput and nature of it (burstiness, average, etc.), scale of sessions/users and accordingly use correct number of VSM cards and related configuration.
  • If possible, deploy in phases. First, send selected traffic (you can use ABF) through VSM and see if there are any issues. If not, you can send more and more traffic through VSM.
  1. CGv6 on VSM: Features Supported Across IOS-XR Releases
  2. CGv6 on ISM: Features Supported Across IOS-XR Releases
  3. CGv6 on ISM: CGN / NAT44 Deployment Guide
  4. ASR9K Configuration Guides
  5. ASR9K Command Reference Guides
  6. ASR9K BNG Deployment Guide
  7. IANA Service Name and Transport Protocol Port Port Number Registry
  8. Configuration Example: MPLS VPN on IOS-XR
  9. Cisco ASR9000 S/w License Operations White Paper
- 0 -
Nitin Pabbi
Hey Smail,
customer is complaining about following issue. Subscribers behind NAT are accessing customers services but every service that they use is accesses from different public IP. We are using a /22 pool.
>>>  This is an expected behavior considering VSM cores use for map of different destination addresses based on mapping at core.
Is there an option where one private IP can use same public IP for every session?
>>> Can you explore 1:1 or n:1 address mapping if this suffice your need.
As name pronounce, 1:1 is for mapping 1 private address with 1 public address
n:1 is for mapping multiple private addresses mapped to 1 public address.
Configuration is simple
service cgn Test_cgn1
 service-location preferred-active 0/2/CPU0
 service-type nat44 testnat1
  inside-vrf inside1
   map ip one-to-one  >>>>>>>> 1:1
   map outside-vrf outside address-pool 10.1.1.0/22
  inside-vrf inside1
   map ip many-to-one 2 >>>>>>> n:1
I think that the best solution would be using CGNAT as close to the edge as possible but this is not possible at the moment.
>>> Though its difficult to comment without going through the deployment topology but giving a thought if you filter out the desired prefixes by using firewall.
Nitin Pabbi
smailmilak
Level 4
Level 4
thanks for your solution. I've talked already about this two features with Aleksandar 7 days ago.
I am afraid to break something on the ISM because it's in production. I will probably create a new VRF and IP pool for testing only.
mkhalil10
Hi all
I have concern regarding the ABF traffic diversion
the ivrf1 and ivrf2 VRFs are clear to me , the VRF subscriber is not the outside VRF?
BR,
Mohammad
samiwehbi
Dears,
a couple of questions:
1) if you can clarify the refresh-direction feature, its basically bidirectional, but what does it exactly do & does it affect the number of ports used by a user (refreshes this info).
2) was informed that the VSM supports up to 60Gbps throughput but using two pairs of serviceapps for NAT44.
is it possible to fully utilize full VSM capability using only one serviceapp pair ?
thanks
Sami
rchappid
Refreshing feature is about
“Translation entries that do not have traffic flowing for specific time period are timed out and deleted to prevent unnecessary usage of system resources. Any traffic for a particular translation entry refreshes the entry and prevents it getting timed out. Usually, the refresh is based on packets coming from both inside and outside. This is referred to as bi-directional refresh mechanism. However, bidirectional refresh can lead to denial of service (DoS) attacks because someone from the outside can periodically refresh the entries even though there is no inside traffic.
When NAT refresh direction is configured as Outbound, the translation entries are refreshed only by traffic flowing from inside to outside and prevent DoS attacks.”
Please refer the below URL as well.
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r5-2/cg-nat/command/reference/b_cgnat_cr52xasr9k/b_cgnat_cr52xasr9k_chapter_00.html#wp3764256446
Raghu.ch
Kijush Maharjan
Hope someone can help me. I am trying to capture nat logs (Session-logs) into my syslog server. I have configured as in docs but i cannot see any logs moving to my syslog server.
service cgn cgnat
service-location preferred-active 0/1/CPU0
service-type nat44 nat1
portlimit 5000
alg ActiveFTP
alg rtsp
alg pptpAlg
inside-vrf insidevrf1
map outsideServiceApp ServiceApp2 address-pool 1.2.3.4.0/22
server
address 192.168.1.20port 514
protocol udp
session-logging
I have two vrfs i.e.. default and insidevrf1.
Nat works in insidevrf1.
Is there anything more that i need to do?
Thanks.
smailmilak
Level 4
Level 4
is 192.168.1.20 reachable from default VRF? If yes then it should work.
PauloHirakawa
I need to introduce a second VSM in a 9K chassis to load traffic between them. Is this a simple deployment installing the OVA in the new VSM or I'll have to create another instance and redirect the traffic into another vrf? How would be the configuration in the 9K with two VSMs?
a-gould
Kijush, this is my notes from my testing of cisco 9k/vsm-500 cgnat from a while ago...i'm copying and pasting from a Word document that I compiled of my findings....so I hope this helps. (i actually never deployed asr9k/vsm-500 cgnat, i went with juniper mx104 ms-mic-16g, it's pretty nice)
- Aaron Gould
Configuring Logging (syslog)
*** I initially thought that since the syslog server config is under the inside-vrf stanza, that the syslog server would need to be reachable in that vrf.  Nope, it doesn’t.  that syslog server is actually reachable in the default/global vrf and it works.  I’m getting syslog traps to both of those servers from cgn
RP/0/RSP0/CPU0:eng-lab-9k-1#sh run service cgn cgn1
Wed Dec 16 13:09:05.379 CST
service cgn cgn1
 service-location preferred-active 0/3/CPU0
  portlimit 65535
  alg ActiveFTP
  inside-vrf six
   map outside-vrf one outsideServiceApp ServiceApp2 address-pool 1.2.3.0/24
    server
     address 172.22.14.121 port 514
      session-logging
     address 172.22.14.247 port 514
      session-logging
*** wireshark on my windows VM is showing the following in the syslog trap
Facility: LOCAL0
Level: INFO
*** also showing source ip of packet is 3.1.1.2 which interestingly is coming from the serviceinfra1 interface subnet.
RP/0/RSP0/CPU0:eng-lab-9k-1#sh run int serviceinfra 1
Wed Dec 16 14:12:45.714 CST
interface ServiceInfra1
 ipv4 address 3.1.1.1 255.255.255.252
 service-location 0/3/CPU0
*** udp 514 is syslog destination… but source from 3.1.1.2 is udp port 4115
*** some syslog messages have one nat translation… I’m seeing some with MORE THAN ONE… like 2 or 3
*** here’s a trap with one xlation…
1 2015 Dec 16 21:03:53 - - NAT44 –
[SessionbasedWD 17 10.10.0.10 six - 1.2.3.120 60296 5060 - 212.83.188.161 5116 ]
*** here’s a trap with two xlations…
1 2015 Dec 16 21:00:30 - - NAT44 –
[SessionbasedAD 6 10.10.0.11 six - 1.2.3.49 34302 51597 - 74.125.21.188 5228 ]
[SessionbasedAD 6 10.10.0.11 six - 1.2.3.49 47817 55688 - 207.97.236.143 5222 ]
*** one came in like this…
1 2015 Dec 16 21:00:27 - - NAT44 - [SessionbasedAD 6 10.10.0.11 six - 1.2.3.49 38614 34322 - 31.13.66.1 443 ][SessionbasedAD 6 10.10.0.11 six - 1.2.3.49 44721 42569 - 31.13.66.3 443 ][SessionbasedAD 6 10.10.0.11 six - 1.2.3.49 48824 46201 - 31.13.66.3 443 ][SessionbasedAD 6 10.10.0.11 six - 1.2.3.49 37039 59156 - 31.13.66.3 443 ][SessionbasedAD 6 10.10.0.11 six - 1.2.3.49 45480 35683 - 52.17.34.252 5223 ][SessionbasedAD 6 10.10.0.11 six - 1.2.3.49 45751 62822 - 173.194.219.95 443 ]
*** I’ll add line breaks
1 2015 Dec 16 21:00:27 - - NAT44 –
*** …those 6 translations are WITHIN ONE SYSLOG TRAP PACKET !  I’m glad to see this since it seems to cut down on a crazy amount of syslog packets.  Perhaps it makes it more difficult for a parser to move through later on though… perhaps a tradeoff.
Nitin Pabbi
Hey  Paulo,
We have 2 types of redundancy support on VSM card.
1) 1:1 redundancy
2) n:1 redundancy.
details you get get from link  https://supportforums.cisco.com/discussion/13038731/ism-100-vsm-500-migration-and-redundancy-managment-guide-key-performance
1:1 redundancy can be achieved enabling single CLI under already configured CGN instance
RP/0/RSP0/CPU0:CGN(config)#
service cgn redundancy
 service-location preferred-active 0/1/CPU0 preferred-standby 0/2/CPU0
You need to create service-infra interface separately for standby VSM card. Remaining service APP interfaces get in sync by self.
will show you output like
RP/0/RP0/CPU0:CGN#show services redundancy
Service type     Name                    Pref. Active        Pref. Standby
ServiceInfra     ServiceInfra1           0/1/CPU0 Active
ServiceInfra     ServiceInfra2           0/2/CPU0 Active
ServiceCgn       redundancy              0/2/CPU0 Standby    0/1/CPU0 Active
for n:1 redundancy you need to create separate service instances .
RP/0/RP0/CPU0:CGN#sh run service cgn cgn1
service cgn cgn1
  portlimit 65535
  inside-vrf inside
   map outside-vrf outside address-pool <>
   portlimit 32
   bulk-port-alloc size 8
RP/0/RP0/CPU0:CGN#sh run service cgn cgn2
service cgn cgn2
 service-type nat44 nat2
  portlimit 65535
  dynamic-port-range start 1
   inside-vrf inside1
   map outside-vrf outside1 address-pool <>
   portlimit 100
Here traffic failure can be done using ABF.
Nitin Pabbi
Kijush Maharjan
Hi a-gould,
Yes you are right. I didn't know the source address for sending logs is serviceinfra ip. After allowing that IP, i can see logs in my syslog server.
Thanks for your explanation.
Carlos A. Silva
Level 3
Level 3
I'd like to ask a hypothetical question regarding VSM operation. Say I implement a regular CGNAT instance from an inside-vrf to the default-outside vrf (please assume this works normally). Now, this same box has two ISP connections to different providers (it doubles both as CGNAT and border router).
I end up announcing my public IP translation pool to both ISPs so that after getting NAT'd some of my traffic goes out to ISP-A and some goes to ISP-B. That means, after NAT, it goes out through different physical interfaces.
Just like it goes out through different outgoing interfaces, incoming traffic comes in through different incoming interfaces (ISP-A and ISP-B).
As far as I know, the CGNAT process is completely de-coupled from the (outside) routing process, so I shouldn't care through which interface incoming traffic arrives before it's sent to the VSM and it performs the "reverse" NAT operation, correct?
I thought I'd ask, just in case.
Thanks!
c.
a-gould
It's been a while since I messed with this VSM-500 CGNat stuff, (i ended up deploying juniper cgnat) I'm looking in my notes and it appears that the nat inside and outside interfaces are serviceapp interfaces decouple from the underlying physical interfaces.  Most of my tests were done with the goal of accomplishing cgnat via mpls vrf for inside and outside with phy ints being mpls label interfaces into my mpls cloud...so i could locate cgnat node anywhere in my mlps cloud and not have to put that vsm-500 module in my actual boundary node (or juniper ms-mic)..... this allowed me to create a fairly flexible placement of my cgnat boundary function...   in my network, 55% of my traffic is actual global internet traffic and 45% is locally stored caching of the big name cdn caches that we've all become familiar with (netflix, akamai, etc) ...so the cgnat boundary function *placement* is not a no-brainer to stick it on the Internet boundary node since half of my traffic doesn't even flow via the actual inet connections as i just mentioned.
subscribers-----PE------P-----PE(inside vrf)(cgnat, up and down prot stack)(outside vrf)PE------P----PE------inet
i learn 3 default routes via mb-ibgp into the outside vrf (routing-instance) .... so my juniper mx104 (2 MX104's actually since i run a dual redundant cgnat boundary) learns those 3 default routes and sends post-natted traffic out via one of those 3 default routes via my mpls core to the 3 boundary pe's... then of course labels are popped and native ip sent... on the way back, that traffic is bgp load-balanced or however i choose to have it sent back to my boundary nodes, then it's labeled and sent to the appropriate mx104 (by then it's seen more-specific /25's that i send from mx104 to my boundary pe's)...nat happens in the reverse.... labels are pushed , traffic sent to my PE's connected to my inet subs....then of course natively flows via ip and last-mile tech
-aaron gould
Nitin Pabbi
Hey Carlos,
In Cisco with VSM-500 we support destination based NAT and dont perform uRPF.
VSM don't track ingress or egress interface for traffic receiving/forwarding since its confine to its logical interfaces which are serviceApp IN and service App OUT.
At VSM we do public NAT which is nothing reverse NAT.
Nitin Pabbi
Kane Alvarez
Hi @somnathr,
Do we support real-time translation logging on VSM?
Customer will want to send real-time NAT translation log to ADC product to combine the log format and send it to Sandvine.
Thanks!
