on 01-20-2012 10:47 AM
In this document I'll discuss the operation, use and some examples on RPL, or the route policy language.
Route policies are mandatory for E-BGP peers, at least a "pass-all" like RPL is required in order to import and export routes.
In IOS we used to have route-maps to control the import, export and manipulation of routes. IOS-XR doesn't have route-maps but something more powerful called route policy language. It is a very programmatic approach in route-maps.
Where as IOS route-maps operate as a series of statements which are executed sequentially, Route-policies not only operate sequentially but provide the ability to invoke other route-policies much like a ‘C’-program is able to call separately defined functions. This enables to creation of hierarchical policies. In addition, and most importantly into respect the scope of this paper, route-policies are ‘compiled’ into a run-time executable portion of code.
When you have configured a route policy that you want to edit afterwards, you need to restart from scratch or copy paste the existing RPL as entering the route-policy configuration would wipe the existing one out:
RP/0/RSP0/CPU0:A9K-BNG(config)#route-policy test
RP/0/RSP0/CPU0:A9K-BNG(config-rpl)#if med eq 100 then
RP/0/RSP0/CPU0:A9K-BNG(config-rpl-if)#set local-preference 100
RP/0/RSP0/CPU0:A9K-BNG(config-rpl-if)#endif
RP/0/RSP0/CPU0:A9K-BNG(config-rpl)#end-policy
RP/0/RSP0/CPU0:A9K-BNG(config)#commit
Fri Jan 20 14:58:39.900 EDT
% WARNING: Policy object route-policy test' exists! Reconfiguring it via CLI wil
l replace current definition. Use 'abort to cancel.
RP/0/RSP0/CPU0:A9K-BNG(config-rpl)#if local-preference eq 123 then
RP/0/RSP0/CPU0:A9K-BNG(config-rpl-if)#set origin incomplete
RP/0/RSP0/CPU0:A9K-BNG(config)#do sh run route-policy test
Fri Jan 20 14:59:53.705 EDT
route-policy test
endif
end-policy
As you can see the previous if statement is completely gone, copy pasting and offline editing are also not very easy to use! There is a solution!
RP/0/RSP0/CPU0:A9K-BNG#edit route-policy test ?
emacs to use Emacs editor
nano to use nano editor
vim to use Vim editor
<cr>
I tend to prefer VI and then you can edit your RPL in a VI like manner:
Editting screen:
route-policy test
else if med eq 100 then
set weight 44
endif
end-policy
I am inserting the bold italic lines and press "ZZ" to exit and save the VI editor. (Note I made a config error in RED)
"/dev/shmem/rpl_edit.115790135" 8 lines, 149 characters written
Proceed with commit (yes/no/cancel)? [cancel]:
Now the config error here by splitting "else if" and look what happens when I try to commit:
Parsing.
149 bytes parsed in 1 sec (148)bytes/sec
% Syntax/Authorization errors in one or more commands.!! SYNTAX/AUTHORIZATION ER
RORS: This configuration failed due to
!! one or more of the following reasons:
!! - the entered commands do not exist,
!! - the entered commands have errors in their syntax,
!! - the software packages containing the commands are not active,
!! - the current user is not a member of a task-group that has
!! permissions to use the commands.
set weight 44
endif
end-policy
Continue editing? [no]:yes
"/dev/shmem/rpl_edit.115790135" 8 lines, 145 characters written
Proceed with commit (yes/no/cancel)? [cancel]: yes
Parsing.
145 bytes parsed in 1 sec (144)bytes/sec
Committing.
Prepared commit in 0 sec
1 items committed in 1 sec (0)items/sec
Updating.RP/0/RSP0/CPU0:Jan 20 15:04:20.101 : config[65848]: %MGBL-CONFIG-6-DB_COMMIT : Configuration committed by user 'root'. Use 'show configuration commit changes 1000000522' to view the changes.
Updated Commit database in 1 sec
So from now one when you want to edit RPL's, prefix sets or as-sets or community sets, use this editor
RP/0/RSP0/CPU0:A9K-BNG#edit ?
as-path-set edit an as-path-set
community-set edit a community-set
extcommunity-set edit an extended-community-set
policy-global edit policy-global definitions
prefix-set edit a prefix-set
rd-set edit a rd-set
route-policy edit a route-policy
The route policy requires a "ticket" for the route to be accepted or dropped. These are the different operatators
pass grants a ticket to defeat default drop
Execution continues after pass
Any set at any level grants a ticket
Execution continues after set
Values can be set more than once
• Drop – prefix is discarded
Explicit drop stops policy execution
Implicit drop (if policy runs to end without getting a ticket)
One thing important to add is here that if you have a policy that is "sequential" like
if med 10 then
set med 20
endif
if med 20 then
drop
endif
the execution will NOT drop prefixes with MED10. The reason for that is, although somewhat counter intuitive, that the sequence of operation uses the ORIGINAL value during processing, hence the second if statement will not match for the what was original med of 10...
If you like to get the behavior that both 10 and 20 are dropped, you could do something like this:
if med 10 then drop
else if med 20 then drop
else pass
endif
Don't forget the final pass, as there is an implicit deny.
The ability to reference one policy in another
route-policy one
set weight 100
end-policy
route-policy two
set med 200
end-policy
route-policy three
apply two
set community (2:666) additive
end-policy
route-policy four
apply one
apply three
pass
end-policy
The ability to call one policy with a variable to be used in another policy:
route-policy one ($med)
set med $med
end-policy
route-policy two
apply one (10)
end-policy
Or with 2 variables:
route-policy three ($med,$origin)
set med $med
set origin $origin
end-policy
route-policy four
apply three (10, incomplete)
end-policy
In your RPL you can put the prefix set or as-path etc in the IF statement construction or you can reference a separate set with the AS-list.
They look like the following:
Inline:
route-policy use_inline
if as-path in (ios-regex '_42$', ios-regex '_127$') then
pass
else
drop
endif
end-policy
Named-Set:
as-path-set named_set
ios-regex '_42$',
ios-regex '_127$'
end-set
route-policy use_named
if as-path in named_set then
pass
else
drop
endif
end-policy
There is a performance difference between teh two. the Named Set is obviously slightly slower, but is easier to manage especially when the list gets long. I would personally recommend for short lists to use inline and for longer lists to use the named-set.
Each individual set element results in a separate call to the expression engine:
as-path-set as_51
ios-regex ‘_2129$’,
ios-regex ‘_2147$’,
ios-regex ‘_2856$’,
ios-regex ‘_3486$’,
ios-regex ‘_6432$’,
ios-regex ‘_6468$’,
ios-regex ‘_7310$’,
ios-regex ‘_7768$’,
ios-regex ‘_7862$’,
ios-regex ‘_8296$’
end-set
The same set can be written as follows:
as-path-set as_51
ios-regex '_(2129|2147|2856|3486|6432|6468|7310|7768|7862|8296)$'
end-set
as-path-set aset1
ios-regex ’_42$’,
ios-regex ’_127$’
end-set
prefix-set galaga
171.68.118.0/24,
192.168.0.0/16 ge 16 le 30
end-set
community-set cset1
12:34,
12:78,
internet
end-set
internet
local-AS
no-advertise
no-export
private-as
show bgp policy route-policy <name>
Only display prefixes matching policy – filter show command
RP/0/0/CPU0:XR#show rpl route-policy states
ACTIVE -- Referenced by at least one policy which is attached
INACTIVE -- Only referenced by policies which are not attached
UNUSED -- Not attached (directly or indirectly) and not referenced
Here some examples of using prefix-sets. The use of the variable masks is not easy to understand and I found the CCO documentation not very explanatory, so here a few extra words on that.
Prefix: Explanation:
10.0.1.1, match only one possible value, 10.0.1.1/32, mask omitted means 32.
10.0.2.0/24, match only one possible value, 10.0.2.0/24
10.0.3.0/24 ge 28, match a range of prefix values, from 10.0.3.0/28 to 10.0.3.255/32
10.0.4.0/24 le 28, match a range of values, from 10.0.4.0 to 10.0.4.240 (eg we can’t “reach” the last 4 bits)
10.0.5.0/24 ge 26 le 30, matches prefixes in the range from 10.0.5.0/26 to 10.0.5.252/30
10.0.6.0/24 eq 28 match any prefix of length 28 in the range from 10.0.6.0/28 through 10.0.6.240/28
10.0.7.2/32 ge 16 le 24, matches any prefix of length 32 in the range 10.0.[0..255].2/32 (from 10.0.0.2/32 to 10.0.255.2). This is a little funky given the “7” in the 3rd octet which effectively becomes don’t care.
10.0.8.0/26 ge 8 le 16 matches any prefix of length 26 in the range 10.[0..255].8.0/26 (from 10.0.8.0/26 to 10.255.8.0/26)
I am using an RPL that sets the local pref to 1234 if it matches the prefix set, and that prefix set is as per the above sample list.
=> What is excluded here ? Is 10.0.3.128 excluded from the prefix range ?
Whether the .128 is excluded or not, depends on the mask of the prefix being advertised.
Basically what this means is that if the mask of the route is larger or equal than 28 (so 29,30,31,32) then it matches:
Network Next Hop Metric LocPrf Weight Path
*>i10.0.3.0/28 8.1.1.1 100 1234 0 2 3 {4} i
*>i10.0.3.16/28 8.1.1.1 100 1234 0 2 {3,4} i
*>i10.0.3.32/28 8.1.1.1 100 1234 0 2 3 {4,5} i
*>i10.0.3.48/28 8.1.1.1 100 1234 0 2 i
*>i10.0.3.0/26 8.1.1.1 100 300 0 2 3 {4} i
*>i10.0.3.64/26 8.1.1.1 100 300 0 2 {3,4} i
*>i10.0.3.2/31 8.1.1.1 100 1234 0 2 {3,4} i
*>i10.0.3.4/31 8.1.1.1 100 1234 0 2 3 {4,5} i
*>i10.0.3.6/31 8.1.1.1 100 1234 0 2 i
*>i10.0.3.0/24 8.1.1.1 100 300 0 2 3 {4} i
=> What is excluded here ? 10.0.4.1, .2, .3, .17, .18,.19,.20, etc?
Same as before, but now where the mask is less than 28, so routes in the 10.0.4.x range that have a mask that is shorter 28 will get “hit”.
The mask on the prefix itself sets the “base”. Eg 10.0.3 would not match here as it is not part of the 10.0.4.0/24. Seems obvious but just to be clear ...
*>i10.0.4.0/24 8.1.1.1 100 1234 0 2 3 {4} i
*>i10.0.4.0/26 8.1.1.1 100 1234 0 2 3 {4} i
*>i10.0.4.64/26 8.1.1.1 100 1234 0 2 {3,4} i
*>i10.0.4.128/26 8.1.1.1 100 1234 0 2 3 {4,5} i
*>i10.0.4.48/28 8.1.1.1 100 1234 0 2 i
*>i10.0.4.64/28 8.1.1.1 100 1234 0 2 3 {4,5} i
*>i10.0.4.24/30 8.1.1.1 100 300 0 2 3 i
*>i10.0.4.28/30 8.1.1.1 100 300 0 2 {3} i
Combining the previous two together on the .5.0 range:
*>i10.0.5.4/30 8.1.1.1 100 1234 0 2 {3,4} i
*>i10.0.5.8/30 8.1.1.1 100 1234 0 2 3 {4,5} i
*>i10.0.5.12/30 8.1.1.1 100 1234 0 2 i
*>i10.0.5.4/31 8.1.1.1 100 300 0 2 3 {4,5} i
*>i10.0.5.6/31 8.1.1.1 100 300 0 2 i
*>i10.0.5.5/32 8.1.1.1 100 300 0 2 3 {4,5,6} i
*>i10.0.5.6/32 8.1.1.1 100 300 0 2 3 i
*>i10.0.5.0/25 8.1.1.1 100 300 0 2 3 {4} i
*>i10.0.5.128/25 8.1.1.1 100 300 0 2 {3,4} i
*>i10.0.5.64/26 8.1.1.1 100 1234 0 2 {3,4} i
*>i10.0.5.128/26 8.1.1.1 100 1234 0 2 3 {4,5} i
*>i10.0.7.2/32 8.1.1.1 100 1234 0 2 3 {4} i
*>i10.0.7.3/32 8.1.1.1 100 300 0 2 {3,4} i
*>i10.0.0.2/32 8.1.1.1 100 1234 0 2 3 {4} i
*>i10.0.0.3/32 8.1.1.1 100 300 0 2 {3,4} i
*>i10.1.7.2/32 8.1.1.1 100 300 0 2 3 {4} I <<doesn’t match because of 2nd octet
If I slightly change the prefix statement to: 10.0.7.4/32 ge 16 le 24
*>i10.0.7.0/30 8.1.1.1 100 300 0 2 3 {4} i
*>i10.0.7.4/30 8.1.1.1 100 300 0 2 {3,4} i
*>i10.0.7.8/30 8.1.1.1 100 300 0 2 3 {4,5} i
Still no match as the base mask is not met on the prefixes received.
So the /<whatever> determines the MASK of the route I wanted to match. whereas the GE/LE provide me the variance in either that mask (if bigger) or from the other octects (if smaller then the /mask)
To determine what in your route-policy is consuming the majority of the time, you can use route profiling.
It allows some data collection in the background with minimal impact on the execution of the rpl. After the collection has been running for some time you can use show commands to find out which steps take a lot of time in the execution and make some improvements.
Once we figure out which portion of the policy is performance drag, its much easier to try out an alternative. Something like regex match always failing means we need to evaluate route using prefix match prior to validating its as-paths.
Example usage:
debug pcl profile detail
then
Policy execution profile
Protocol : bgp 10
Attachpoint : neighbor-in-dflt
AP Instance : default-IPv4-Uni-1.2.3.4
Policy Name : rpl_profile(nexthop)
Pass : 10
Drop : 5
Total : 15
Avg execution time : 110usec
Router#sh rpl route-policy rpl_profile detail
route-policy test
apply test2
done
end-policy
route-policy test2
end-policy
route-policy rpl_profile($p_nexthop)
set med 155
else
set med 77
endif
apply test
end-policy
Protocol : bgp 10
Policy : rpl_profile(nexthop)
Pass : 15
Drop : 0
Total : 15
GOTO : PXL_0_6
Router#
As you have noticed when editting RPL's you need to reconfigure the complete policy in the regular CLI. An easier method is using the "edit" option described above.
When you are changing your RPL or prefix-set or any other list that RPL is using, it will trigger a few things:
If the RPL is used for BGP and your peer is not REFRESH capable, it will restart your BGP session.
If the peer is REFRESH capable a full table refresh is executed.
The reason for that is, that the RPL change or say prefix set change could have excluded some routes before that now may need to be imported.
On the Receiving Side:
For BGP, routes that are filtered are completely discarded and are NOT kept in memory with some kind of mark that says bgp rpl filtered.
We will use route refresh to obtain the routes again from the neighbor whenever there is a change in inbound route policy.
For this the neighbor has to be refresh capable, else we have to do clear bgp.
When the BGP peer receives a route refresh request it sends the complete table again to the requesting peer. While asking for the table they ask for the relevant (AFI, SAFI) table. When the routes are received from the peer an inbound filter if any is applied and the routes are aggregated.
On the sending side:
if I apply an RPL basically removing some previously advertised route, would BGP send withdraws for these now filtered routes?
What would rpl/bgp do when the RPL is modified to:
1) do advertise some previously filtered routes
To advertise previously filtered routes it is similar to regular advertising of routes
2) stop advertising previously advertised routes
BGP will send withdraws when it stops advertising previously filtered routes.
Xander Thuijs, CCIE #6775
Sr. Tech Lead ASR9000
I find suspicious behavior of RPL delete community command, policy applied on BGP ingress.
RPL example:
set community (1:1,2:2) additive
delete community in (1:*)
Result is route with community 2:2 but I would expect 1:1,2:2
Based on documentation all attribute check should be based on original attributes, not modified/new (valid at least for 'if'), but seems that delete works with both original and new communities.
IOS XR 5.3.4, ASR9K, RSP880
Best regards
Michael
It is working properly.
Actions work on exsiting and changed attributes.
Conditional matching uses only original attributes.
HTH, Brad
Hi Smail,
Have you been able to find solution for your requirement? I have been searching for this currently too. If you have found solution, I will be very happy to know the solution. Juniper has a very easy solution as you know, if XR has this solution it would be great.
Rajendra
under the vrf definition's address-family, you can do a route-target import to pull in the prefixes from the other vrf's RT.
that doesnt work?
and correct, the next hop is inherited from the other vrf, it would say
vrf x:
prefix/mask next-hop <that next hop> (found in vrf y)
xander
Hi Rajendra,
What version are you running? I believe that you need 6.1.2+ for
It's "export to
If you are stuck please reply and we will try to help you out.
Hi Smail/Xander,
Thanks a lot for recommendations. Working on Smails suggestion. Thumbs up. Also as Xander is referring on next hop case, it will be applicable for networks beyond the p2p ip. I have some requirements where I need connected routes to be leaked between vrfs. Or like say in BNG, if some subscribers routes need to be shared between vrf, how can we do that? since it is learned as "subscriber". I have faced this issue using CGNAT.
In juniper its very easy using rib-groups where I can share any routes of any protocol between 2 vrfs.
Rajendra
Hi Rajendra,
you can redistribute subscriber routes the same way like it's with static or connected routes.
Under BGP address family configure "redistribute subscriber route-policy SET_COM_101" Do not redistribute subscriber routes! You could kill the device. Create a summary static route and use the same approach i.e. redistribute static route-
Using RPL you can decide
RPL should look like this:
set community (101:101)
Under VRF config configure conditional export
export route-policy EXPORT_SUBSCRIBER
RPL config:
if community matches-any (101:101) then
set
endif
delete community in (101:101)
Rajendra,
I did a quick edit of my previous post. I am replying so that you get a notification.
Hi Smail,
Thanks for the help. I solved it using your reference. You guys are great.
Thumbs up !!!
Rajendra
Presume I have an existing RPL where I am not aware of the number of IF/ELSE statements within it.
For example:
if TEST-1 then
set SOMETHING to "A"
elseif TEST-3 then
set SOMETHING to "C"
elseif TEST-4 then
set SOMETHING to "D"
elseif TEST-24 then
set SOMETHING to "X"
end
I dont want to rewrite the entire RPL appending my new statement appropriately into this RPL.
Is there some way I can insert an IF/ELSE statement into this RPL?
for example:
elseif TEST-2 then
set SOMETHING to "B"
If yes,
1. How can I insert this at the start of this RPL?
2. How can I insert this at the end on an RPL?
3. How can I insert this at the "n"th position of an RPL?
Thanks in advance for your response.
Kenny
Hello Xander,
Wonder if it is correct place to ask for SR related stuff, but it is also RPL related.
I need to apply "set label-index" on route-policy to or from BGP LU neighbor, but 6.1.2 is complaining that ""
!!% Policy [BSID] uses the 'label-index' attribute. There is no 'label-index' attribute at the bgp neighbor-out-dflt attach point. ""
Segment Routing book Part I also states on page 241 that at the time of writing of the book XR can only set Prefix-SID when originating the route.
Official config guide says:
A routing policy with the set label-index attribute can be attached to a network configuration or redistribute configuration. Other routing policy language (RPL) configurations are possible. For more information on routing policies, refer to the "Implementing Routing Policy" chapter in the Cisco ASR 9000 Series Aggregation Services Router Routing Configuration Guide.
What are the options of setting Prefix-SID attribute on router which is NOT the originator of the route (no redistribute, no network)?
Hey Xander,
Great article as always. Question on BGP route injection. I have a scenario where our upstream peer only accepts /128 IPv6 host routes. I need to match conditionally on a /64 network inside an L3vpn and then inject the /128 to my eBGP peer. Is there a clean way of doing this in XR?
thanks,
Jon
Hello.
Is it possible to pass a route-policy name as a parameter of another route-policy, to apply different route policies according to this parameter? I would like to achieve something like this (on incoming policy for ebgp peer):
route-policy RPL_EGBP_PEER_IN($peer_type,$peer_as,$lp)
apply $peer_type
set community (64555:$peer_as)
set local-preference $lp
end-policy
Thanks.
Edit: looks like it works if I specify exact route-policy name as $peer_type parameter. Is it possible to set up some aliases between parameter value and route-policy name? I would like to use some other $peer_type value, not an exact route-policy name. For example, if I specify $peer_type = big, I would like to apply a route policy RPL_UPLINK_BIG, or if I specify $peer_type=full, then it should refer to policy RPL_UPLINK_FULL etc.
Hello again,
Is it expected behavior that "done" statement in child policy also stops execution of a parent policy? Example:
route-policy PARENT
apply CHILD
set community COMM1
set local-preference LP
end-policy
I have condition in CHILD policy with"done" statement, and if it matches then execution stops and does not return to PARENT policy for set statements.
Thanks.
Maybe a newbie question, but I am in need of a route-policy whereby I specify a number of /32s and I want to divert only their udp/53 to a specific next-hop. Everything else flows normally.
What I have so far is:
route-policy Diversion
if destination in Prefixes then
set next-hop 10.10.10.10
end-policy
prefix-set Prefixes
2.2.2.2/32 eq 32,
3.3.3.3/32 eq 32
end-set
How do I add in that I only want to divert udp/53 to a route-policy? If not possible via route-policy - what commands in IOS-XR could I use to accomplish this? Not ABF since this isn't in ingrres but rather on egress.
Thanks!
