06-07-2014 01:55 PM - edited 08-08-2019 08:04 AM
BGP flow spec is a new tool that can be used to assist in DDOS mitigation in a dynamic fashion, levering BGP.
When I first started working and looking at BGP-FS I was a bit confused and in this article I would like to try and unravvle some of the specifics of BGP-FS, what you can do with it and how it works.
Conceptually in this picture:
DDOS mitigation with the help of BGP is generally done via RTBH (remote triggered blackhole). And this comes basically in 2 key flavors: Source and Destination based.
The concept is that a BGP edge speaker has a static route defined to a "special next hop" to null0.
From a central point we inject a new route for a particular destination (eg our affected webserver) with a next hop pointing to that special next hop. This means that now at our border routers, our webserver address is set to a next hop, and this next hop is drop, and we prevent this traffic from hitting our server. This protects it nicely. But it removes the ability to reach this server completely!
The source based model is a similar concept whereby we KNOW where an attack comes from and now we send in a bgp path for that source with the special next hop, which then points to null.
Now when we use uRPF (reverse path forwarding), when a packet from that suspect source comes in, we apply RPF, we find the nexthop set to null0/discard. This would make RPF fail and we drop the packet from that host (or subnet for that matter).
Both options work great, but are big hammers.
BGP flowspec allows for a more granular appraoch and effectively construct instructions to match a particular flow with source AND destination, and L4 parameters and packet specifics such as length, fragment etc, and allow for a dynamic installation of an action at the border rotuers to either:
Cool. Now that we got that theory out of the way, how about Flowspec then, what does it do and how is it different?!
This conceptually describes how flowspec works:
So instead of sending/injecting a route for our server or server subnet with a special community that the border routers will associated with a nexthop to drop in their route policy language, in this case we are sending the new flowspec attribute format down to the border routers instructing them to create a sort of ACL with class-map and policy-map to implement this rule that we are advertising!
Very nifty, am lovin it. So in order to do that, we need to extend the BGP protocol a bit, and this is how the RFC is defining that approach:
BGP FS adds a new NLRI (network layer reachability info) to the BGP protocol:
NLRI defined (AFI=1, SAFI=133)
It adds the following packet/attribute format:
It allows for the following parameters to be defined:
6.Source Port (+1 component)
7.ICMP Type (asr9k has support for this yet, CRS does also)
8.ICMP Code (asr9k has support for this yet, CRS does also)
9.TCP Flags (asr9k supports lower byte, crs can not look at all bits)
10.Packet length
11.DSCP
12.Fragment
The actions that can be associated to a flow that we matched on by the parameters specified above are encoded as follows:
And the available actions that we can define are:
So with these new rules we can define a prefix or prefix set and not just that, we can base it on L3 source, L3 dest, its L4 specifics and even on packet length and L3 header options such as fragments! Then we can specify what actions we want to associate with that flow, redirect it, remark it, drop it or police it. And that is the full flow info.
All actions are supported by both CRS and ASR9000.
Ok this is all awesome, now that we got the theory out of the way, you want to go set it up I am sure!
In BGP-FS there is a client and a server. What that effectively means is that there is a device that injects the new flowspec entry (for the lack of a better word I guess) and there is a device (BGP speaker) that receives that NRLI and has to implement something in the hardware forwarding to act on that instruction.
So the device sending or injecting the NRLI is what I call the server, and the device that receive the NRLI and programs the hardware forwarding is called the client.
Visually:
In this concept the server in the grey box injects the flowspec NRLI and the client in the right box receives the information, sends it to the flow spec manager, configures the ePBR (enhance Policy based routing) infrastructure who then in turn programs the hardware from the underlaying platform in use.
The server is configured either via CLI or XML to provide that entry for NRLI injection.
Note that XRv, virtual XR, can be a Server, it can inject those NRLI's for an asr9000 or CRS to act on those. Obviously XRv, not having a hardware forwarding layer is not a client
conceptually
BGP
applicable to both client and server, we need to enable the new address family for advertisement:
router bgp 100
address-family ipv4 flowspec
! Initializes the global address family
address-family ipv6 flowspec
neighbor 1.1.1.1
remote-as 100
! Ties it to a neighbor configuration
Interface
You can disable flowspec on the interface as follows:
Interface gigabit0/0/0/0
ipv4 flowspec disable
requires no special config other then a flowspec enabled peer.
The server side configuration includes the policy-map definition and the association to the ePBR config consists of 2 portions, the class definition, and using that class in ePBR to define the action.
Classification
class-map type traffic match-all <class-name>
<match statement> #Any combination of tuples 1-13 match statements goes here.
end-class-map
Tuple definition possibilities:
#Type 1: match destination-address {ipv4| ipv6} <IPv4/v6 address>/<mask-length>
#Type 2: match source-address {ipv4| ipv6} <IPv4/v6 address>/<mask-length>
#Type 3: match protocol { <value> | <min_value> - <max_value> }
<!In case of IPv6, it will map to last next-header >
#Type 4: create two class-maps one with source-port and another with destionation-port
match source-port { <value> | <min_value> - <max_value> }
match destination-port { <value> | <min_value> - <max_value> }
<! Applicable only for TCP and UDP protocol !>
#Type 5: match destination-port { <value> | <min_value> - <max_value> }
#Type 6: match source-port { <value> | <min_value> - <max_value> }
#Type 7: match {ipv4 | ipv6} icmp-type { <value> | <min_value> - <max_value>}
#Type 8: match {ipv4 | Ipv6} icmp-code { <value> | <min_value> - <max_value>}
#Type 9: match tcp-flag <value> bit-mask <mask-value>
#Type 10: match packet length { <value> | <min_value> - <max_value> }
#Type 11: match dscp { <value> | <min_value> - <max_value> }
match ipv6 traffic-class { <value> | <min_value> - <max_value> }
[for providing 8 bit traffic class value]
#Type 12: match fragment-type {dont-fragment, is-fragment, first-fragment, last-fragment}
#Type 13: match ipv6 flow-label { <value> | <min_value> - <max_value> }
policy-map type pbr <policy-name>
class type traffic <class-name>
<action> #Any one of the extend community action listed below
class class-default
end-policy-map
ACTIONS:
##Traffic rate:
police rate < > | drop
#Traffic action:
sample-log
#Traffic marking:
set dscp <6 bit value> |
set ipv6 traffic-class <8 bit value>
#VRF redirect based on route-target:
redirect {ipv6} extcommunity rt <route_target_string>
# Redirect IP nexthop support
redirect {ipv6} next-hop <ipv4/v6 address> {ipv4/v6 address}
The following ties the flowspec to the PBR policies defined earlier.
flowspec
[local-install interface-all]
address-family ipv4
service-policy type pbr <policy-name>
address-family ipv6
vrf <vrf-name>
address-family ipv4
address-family ipv6
Example use case/configuration:
Target:
all packets to 10.0.1/24 from 192/8 and destination-port {range [137, 139] or 8080, rate limit to 500 bps in blue vrf and drop it in vrf-default. Also disable flowspec getting enabled on gig 0/0/0/0.
Associated copy paste config:
class-map type traffic match-all fs_tuple
match destination-address ipv4 10.0.1.0/24
match source-address ipv4 192.0.0.0/8
match destination-port 137-139 8080
end-class-map
policy-map type pbr fs_table_blue
class type traffic fs_tuple
police rate 500 bps
class class-default
end-policy-map
policy-map type pbr fs_table_default
drop
class class-default
end-policy-map
flowspec
address-family ipv4
service-policy type pbr fs_table_default
vrf blue
address-family ipv4
service-policy type pbr fs_table_blue local
Interface GigabitEthernet 0/0/0/0
vrf blue
BGP Flowspec and local QoS configuration
When flowspec is implemented on an interface that is also having local QoS configuration, local config will come before flowspec processing.
Local config will police and dscp-mark the packets and pass them to flowspec.
Flowspec will then do its processing (police, redirect) except dscp marking.
Flowspec will retain dscp marking as dictated by local qos config.
Say, we have the following:
inbound qos config : police 100Mbps, mark dscp af11
ipv4 access-list acl_ipv4_qos_stream
6 permit ipv4 any host 200.255.5.2
class-map match-any cm_ipv4_qos_stream
match access-group ipv4 acl_ipv4_qos_stream
end-class-map
policy-map pm_ipv4_qos_stream
class cm_ipv4_qos_stream
police rate 100 mbps
set dscp af11
class class-default
end-policy-map
interface hundredGigE 0/4/0/35
service-policy input pm_ipv4_qos_stream
Then we receive the following in flowspec advertisement.
flowspec config : police 50Mbps, mark dscp af43, redir vrf.
RP/0/RP0/CPU0:fretta-50#sh flowspec ipv4 detail | b 200.255.5.2
Flow :Dest:200.255.5.2/32
Actions :Traffic-rate: 50000000 bps DSCP: af43 Redirect: VRF honeypot Route-target: ASN2-4787:13 (bgp.1)
Statistics (packets/bytes)
Matched : 116570713/12822778430
Transmitted : 57360817/6309689870
Dropped : 59209896/6513088560
Then the outcome will be:
NCS5500 platform will also display this same behavior.
Special thanks to Nic Fevrier whose pictures I used for some of the visuals above.
Xander Thuijs CCIE#6775
Principal Engineer, ASR9000
Hi Nicolas,
It worked. Removed some configurations and reloaded . Thanks for the support.
Nimmi MP
RP/0/RSP0/CPU0:ios#sh platform
Tue Jul 28 01:43:39.843 UTC
Node Type State Config State
0/RSP0/CPU0 ASR9001-RP(Active) IOS XR RUN PWR,NSHUT,MON
0/0/CPU0 ASR9001-LC IOS XR RUN PWR,NSHUT,MON
0/0/0 A9K-MPA-4X10GE OK PWR,NSHUT,MON
0/0/1 A9K-MPA-20X1GE OK PWR,NSHUT,MON
RP/0/RSP0/CPU0:ios#
Nimmi
Hi Nimmi,
ASR9001 is Typhoon based, all supported for BGP FS.
But if you said a reload fixed it, you can keep on running your tests then.
BR,
N.
Hi all,
We have an ASR9001. I would like some info about the sizing of BGP-FS. For example, how many /32 routes can i send over it, without reaching tcam limits?
DDOS attacks can easily reach hundred of thousands attacking hosts...
thanx,
Sp
Hi Sp,
The scale we support (ie that we test in our labs) is 3000 rules. In the context of DDoS mitigation it's usually way enough because we are not trying to identify every single source responsible for the attack, but more generally we identify the victim or the range of addresses under attack and we try to filter based on packet specificities.
For example: in the case of NTP amplification attack, we will drop packet following this description:
- Destination address: victim IP or range of the victim IPs
- protocol 17: UDP
- port source or destination: 123
- packet size: larger than 400 (it's a random number)
--> we don't define the source, so it could be from everywhere as long as these other conditions are met (also, it's common to define a second rule for fragmented packets targeted to the victim because the attack packets may be larger than the PMTU and will often be fragmented).
Hope it helps a bit,
N.
On asr9k we support 3k simple rules per system. If you require a more advanced solution, you could consider the DDoS prevention solution that we developed in collaboration with Arbor. You would need a larger asr9k for that solution and a VSM line card.
/Aleksandar
Thank you Nicolas and Aleksandar for the answers!
Sp
Given FS limite indication, you can mix and match with RPF unicast check and RTBH.
If it's a DoS or small source set DDoS, you use FS. If it's a massive DDoS (thousand of sources), it's better to RBTH, whose limit is route table size (way mooore), and its protection applies to all customers at the same time, and whose drawback is only that the DDoS source become unreachable (not a big deal if they are botnet infected machines).
Hi, can you please share some design guide for ASR9K and Arbor integration?. Specific for ASR9K VSM + BGP FlowSpec. I not found in Cisco Website.
hi mauricio, I dont have something pre-cut for that at the moment, but I know some sales guidance exists for it that explains the VSM+arbor solution for ddos mitigation.
There is a white paper that talks about the solution here, does that get you going?
cheers!
xander
Hi Mauricio,
I suggest you watch the CiscoLive Berlin session "BRKSPG-3012 - SP Security - Leveraging BGP FlowSpec to protect your infrastructure (2016 Berlin)".
You'll find recommandation for each type of attacks.
Also this one "BRKSPG-3335 - Advanced - DDoS Mitigation Deployment: Impact on your Architecture " still has a lot of good examples.
Cheers,
N.
Do we need special router to run flowspacs? we have ASR1001-X does it support BGP flowspecs?
also does ISP or provider need to enable flowspecs in their side to run flowspecs?
Hi Satish,
ASR1001-X should support BGP FS as a client since IOS XE 3.15.
By nature, BGP is a peering relationship between two entities. So you need another end to control your ASR1000 and inject rules via BGP FS.
In short, it really depends what you are trying to do :)
BR,
N.
Hi Alexander,
As per the RFC 5575 there are validation steps for the Flow Spec NLRI containing destination prefix component. What about the Flow Spec NLRIs that don't have the destination prefix component? Is there no validation for such kind of Flow Spec NLRIs? Please clarify.
Pavana.
hi pavana, it is basically for ebgp advertisements, it defines the "protocol" for advertising the flow rules to a peer based on the best path selection algorithm. if the dest prefix is missing it wouldn't match a "real" prefix, hence the flow spec rule is not advertised along since the best path doesnt match the flowspec rule.
eBGP usage of flowspec is topic of much discussion (that is me having a flowspec rule and passing it on to another AS for implementation at their borders) and today possibly not part of consideration (yet).
xander
