on 07-14-2013 05:11 AM
This document provides a guide on how to use the satellite (ASR9000v) with the ASR9000 and ASR9900 series routers. It will be discussed what you can and cannot do, how to verify the satellite operation and use cases.
This document is written assuming that 5.1.1 or greater software release will be used.
Satellite is a relatively new technology that was introduced in XR 4.2.1. Satellite provides you a great and cheap way to extend your 1G ports by using this port-extender which is completely managed out of the ASR9000. The advantage is that you may have 2 devices, but 1 single entity to manage. All the satellite ports are showing up in the XR configuration of the ASR9000.
Another great advantage of the Satellite is that you can put it on remote locations, miles away from the ASR9000 host!
Although there is a limit to the number of satellites you can connect to an ASR9000 (cluster), the Satellite general concept of ASR9000 is shown here in this picture:
The physical connections are very flexible. The link between the Satellite and the ASR9000 is called the ICL or "Inter Chassis Link".
This link transports the traffic from the satellite ports to the 9000 host.
In the ASR9000 host configuration you define how the satellite ports are mapping between the ICL and the satellite ports.
You can statically pin ports from the Satellite to a single uplink (that means there is no protection, when that uplink fails, those satellite
ports become unusable), or you can bundle uplinks together and assign a group of ports to that bundle. This provides redundancy,
but with the limitation that the satellite ports that are using an uplink bundle, can't be made part of a bundle themselves.
We'll talk about restrictions a bit later.
In the picture below you see Access Device A1 connecting with a bundle that uses uplink (green) to the 9k host LC-2.
A second satellite has all their ports in a bundle ICL.
Note that there is no bandwidth constraints enforced, so theoretically you can have a 2 member ICL bundle and 30 Satellite ports mapped to it, but that would mean there is oversubscription.
While the ASR9000v/Satellite is based on the Cisco CPT-50, you cannot convert between the 2 devices by loading different software images.
You can't use the 9000v as a standalone switch, it needs the ASR9000 host.
Visual differences include that the 9000v starts the port number at 0, where the CPT starts at 1. Also the CPT has 4 different power options
and the ASR9000v only 3: AC-A, DC-A, DC-E (A for Ansi, E for ETSI).
Satellite packet format over L1 topologies looks like this; there is a simple sneaky dot1q tag added which we call the nV tag:
In L2 topologies, such as simple ring, we use dot1ad.
There is a license required to run the ASR9000v. There are 3 licenses for 1, 5, or 20 Satellites per 9k host named:
While licenses are not hard enforced, this meaning the system will still work even though a license may not be present, however you are urged to obtain the proper license, syslog messages will show the "violation of use".
Note when using simple ring, a host license for each satellite is needed on each host. E.g. a simple ring with three satellites requires six A9K-NVSAT1-LIC licenses.
A variety of optics are supported on the ASR9000v, they may not be always the same as the ASR9000. Reference this link for the supported optics for ASR9000/9000v.
When using Tunable optics for the 9000v, pay attention to the following:
(*) note for the tunable optic on the IRL you need to set the wavelength the first time via the 9000v shell on insertion of the optic before shipping it to the destined location.
Handling of Unsupported Optics
For the 9000v ports we do not support the 'service unsupported-transceiver' or 'transceiver permit pid all' commands.
The satellite device simply flags an unsupported transceiver without disabling the port or taking any further action. As long as the pluggable is readable by the satellite the SFP may work, but there are no additional 'hacks' such as the hidden commands beyond what is shown as supported in the tables from the supported optic reference link.
The following software and hardware requirements exist for the ASR9000v. Although support started in XR4.2.1 My personal recommendation is to go with XR43 (latest) as many initial restrictions are lifted from the first release:
Minimum version is XR 4.2.1
Note: If the wrong port is used for ICL then the link will stay down on the 901. Once the correct ICL port is used and the 9K configured then a reload of the 901 will need to occur for the link to come up and the 901 become recognized as a satellite.
Generally speaking all features supported on physical GigE ports of ASR9K are also automatically supported on the GigE ports of the
satellite switch such as L2, L3, multicast, MPLS, BVI, OAM … (everything that works on a normal GigE).
–L1 features: applied on the satellite chassis
1) The following features are not supported on satellite ports in 5.1.1
*Need to update this*
2) When the ICL is a link bundle, there are some restrictions :
QoS can be applied on the ASR9000 host (runs on the NP where the satellite ports have their interface descriptors) or offloaded to the satellite
When you have oversubscription, that is more then the number of 1G ports compared to the ICL total speed there could be a potential issue. However there is an implicit trust model for all high priority traffic.
Automatic packet classification rules determine whether a packet is control packet (LACP, STP, CDP, CFM, ARP, OSPF etc), high priority data (VLAN COS 5,6,7, IP prec 5, 6, 7) or normal priority data and queued accordingly
For the downstream direction, that is 9000 host to the Satellite, the "standard" QOS rules and shaping are sufficient enough to warrant the delivery of high priority packets to the satellite ports. (e.g. inject to wire etc).
As the ICL link between the satellite and host may be oversubscribed by access interfaces, configuring QoS on the satellite itself is optimal for avoiding the lose of high priority traffic due to congestion. This feature was introduced in 5.1.1
3 steps to configuring QoS offload
INPUT access interface (CLI config) example:
class-map match-any my_class
match dscp 10
end-class-map
policy-map my_policy
class my_class
set precedence 1
end-policy-map
interface GigabitEthernet100/0/0/9
ipv4 address 10.1.1.1 255.255.255.0
nv
service-policy input my_policy
Traffic is hashed across members of this ICL LAG based on satellite access port number. No packet payload information (MAC SA/ DA or IP SA/ DA) used in hash calculation. This ensures that QoS applied on ASR9K for a particular satellite access port works correctly over the entire packet stream of that access port. Current hash rule is simple (port number modulo # of active ICLs)
Plug-and-play installation: No local config on satellite, no need to even telnet in!
It is recommended to use the auto-IP feature, no loopback or VRF need to be defined. A VRF **nVSatellite will be auto-defined and does not count towards the number of VRFs configured (for licensing purposes).
Optional config secret password for satellite login. Note that the username is 'root'
There are two options for ICL:
That is static pinning; designate some ports from the satellite to use a dedicated uplink.
Using a bundle ICL that provides for redundancy when one uplink fails.
All interfaces mapped to an ICL bundle:
ASR9000 TenG interface putting into bundle mode ON (No LACP support)
Define the bundle ethernet on the ASR9000 host, and designate which ports will be mapped to the bundle:
Because of the order and batching in which things get applied in XR there are some things that you need to know when it comes down to negating certain config which additions of others.
Examples of this are:
In such cases, failures are expected to be seen; generally speaking, failures are expected to be deterministic, and workarounds available
(re-apply the configuration in two commit batches)
Recommendation to users is to commit ICL configuration changes in separate commits to Satellite-Ether configuration changes
Starting in 5.1.1 many new features were added to expand upon the basic single host hub-and-spoke model. These features take more configuration than the base satellite configuration and will be discussed below.
Starting in 5.1.1 the ability for a satellite (hub-and-spoke) or a ring of satellites (simple ring) to be dual-homed to two hosts was added. (nV Edge acts as one logical router)
With this configuration one ASR9K host is the active and the other is standby. Data and control traffic from the satellite will flow to the active host, but both hosts will send and receive management traffic via the SDAC protocol. This is used to determine connectivity, detect failures, sync the configuration, etc.
The two hosts communicate management information via ICCP with a modified version of SDAC called ORBIT.
Supported Topologies:
Hub-and-spoke dual hosts
9000v with 10G ICL or bundle ICL
901 with 1G ICL
9000v (10G) or 901 (1G) using L2 fabric sub-interfaces
Satellites may be partitioned
Simple ring dual hosts
9000v with 10G ICL
901 with 1G ICL
Satellites may not be partitioned
Note: Partitioning is when you carve out certain access ports to be used by certain ICL interfaces
Current limitations:
Must be two single chassis, no clusters
Load balancing is active/standby per satellite, per access port planned
No user configuration sync between hosts
Configuration Differences:
The most notable changes when coming from a simple hub-and-spoke design is ICCP, and adding the satellite serial number.
Example
Router 1
redundancy
iccp
group 1
member
neighbor 172.18.0.2
nv satellite
system-mac <mac> (optional)
nv
satellite 100
type asr9000v
ipv4 address 10.0.0.100
redundancy
host-priority <priority> {optional)
serial-number <satellite serial>
vrf nv_mgmt
interface loopback 10
vrf nv_mgmt
interface Loopback1000
ipv4 address 172.18.0.1 255.255.255.255
interface GigabitEthernet0/1/0/4
ipv4 address 192.168.0.1 255.255.255.0
interface ten 0/0/0/0
ipv4 point-to-point
ipv4 unnumbered loopback 10
nv
satellite-fabric-link [network satellite <> | satellite <>]
redundancy
iccp-group 1
remote-ports gig 0/0/0-43
mpls ldp
router-id 172.18.0.1
discovery targeted-hello accept
neighbor 172.18.0.2
router static
address-family ipv4 unicast
172.18.0.2/32 192.168.0.2
Starting in 5.1.1 we have the ability to support more than just simple hub-and-spoke. The ring topology allows for satellite chaining, cascading, and in general a more advanced satellite network.
Requirements and Limitations:
Configuration:
This is essentially the same as the dual hosts setup, but the network option must be used when entering 'satellite-fabirc-link'
This is treated as special ring and works the same way as simple ring.
The biggest difference is that in 5.1.1 cascading supports single host while simple ring does not.
Starting in 5.1.1 we have the ability to extend the ICL across an EVC. Normally an IRL is a L1 connection. This increases the flexibility of satellite by allowing for greater distances between the ASR9K host and the satellite device.
Requirements and limitations:
Configuration:
On Active-Host:
interface TenGigE0/1/0/23.200
encapsulation dot1q 200
nv
satellite-fabric-link satellite 200
redundancy
iccp-group 1
remote-ports GigabitEthernet 0/0/0-43
On Standby-Host:
interface TenGigE0/1/1/0.200
encapsulation dot1q 220
nv
redundancy
iccp-group 1
Note: L2 cloud configuration not shown
'show nv satellite status'
Checking Version: The version of the software running on the satellite is being checked for compatibility with the running version of IOS-XR on the host
Configured Serial Number: (If configured) the serial number configured for the satellite, checked against that presented by the satellite during control protocol authentication
Configured Satellite Links: One entry for each of the configured satellite-fabric-links, headed by the interface name. The following information is present for each configured link:
Discovered Satellite Fabric Links: This section is only present for redundant satellite-fabric-links. This lists the interfaces that are members of the configured link, and the per-link discovery state.
Conflict: If the configured link is not conflicted, the satellite discovered over the link is presenting data that contradicts that found over a different satellite-fabric-link.
'show nv satellite protocol discovery'
Host IPv4 Address: The IPv4 address used for the host to communicate to this satellite. Should match the IPv4 address on all the satellite-fabric-links
For Bundle-Ether satellite-fabric-links, there are then 0 or more 'Discovered links' entries; for physical satellite-fabric-links, the same fields are present but just inline.
'show nv satellite protocol control'
Authenticating: The TCP session has been established, and the control protocol is checking the authentication information provided by the Satellite
Connected: The SDACP control protocol session to the satellite has been successfully brought up, and the feature channels can now be opened.
For each channel, the following fields are present:
Open(In Resync - Awaiting Client Resync End) The Feature Channel Owner (FCO) on the host has not finished sending data to the FCO on the Satellite. If this is the state then typically the triage should continue on the host by the owner. The owner of the Feature Channel should be contacted.
Open(In Resync - Awaiting Satellite Resync End) The FCO on the Host is awaiting information from the FCO on the Satellite. If this is the state then typically the triage should continue on the satellite.
Notes:
icpe_gco[1148]: %PKT_INFRA-ICPE_GCO-6-TRANSFER_DONE : Image transfer completed on Satellite 101
A few issues can cause this:
Conflict Messages
Examples:
BNG access over satellite is only qualified over bundle access and isn’t supported over bundle ICLs.
BNG access over ASR9k host and NCS5k satellite specifically is in the process of official qualification in 6.1.x. Please check with PM for exact qualified release.
Access bundles across satellites in an nV dual head solution are generally not recommended. The emphasis is not to bundle services across satellites in a dual head system as if they align to different hosts, the solution breaks without an explicit redundant path. An MCLAG over satellite access is a better solution there.
Bundle access over bundle fabric / ICL require 5.3.2 and above on ASR9k. For NCS5k satellite, bundle ICL including bundle over bundle is supported from 6.0.1 and nV dual head topologies are planned to be supported only from 6.1.1
MC-LAG over satellite access might be more convergence friendly and feature rich than nV dual head for BNG access from previous case studies. For non BNG access, nV dual head and MC-LAG are both possible options with any combinations of physical or bundle access and fabric.
In an MC-LAG with satellite access, the topology is just a regular MC-LAG system with the hosts syncing over ICCP but with satellite access as well. Note that the individual satellites aren’t dual homed/hosted here so there is no dual-host feature to sync over ICCP beyond just MC-LAG from CE.
As a deployment recommendation, unless ICL links (between satellite and host) are more prone to failure over access, MC-LAG might be preferable over nV dual head solution. However, if ICL links have higher failure probability and the links going down can affect BW in bundle ICL cases, then MC-LAG may not switch over unless the whole link goes down or access goes down.
Xander Thuijs CCIE#6775
Principal Engineer, ASR9000
Sam Milstead
Customer Support Engineer, IOS XR
Hi Alex,
Is BFD included in control protocol in auth-qos?
Mei
hi Mei,
yes, it is. Refer to
regards,
/Aleks
Thanks Alex!
Is auto QoS and QoS offload mutual exclusive? if that's the case, when we configure QoS offload, we have to consider all including the sat control, protocol, and user data etc. right?
Mei
Thank you so much Aleksandar, this is exactly what I needed, it all makes sense now.
adam
hi Mei,
On NCS5k as satellite, once you configure QoS Offload the satellite management traffic is still prioritised in the same way as with Auto-QoS, but the user traffic is left to user configuration. Auto-QoS and QoS Offload are mutually exclusive on asr9000v and asr9000v2 and there are no plans to change this.
regards,
Aleks
Hi Xander
i have a question regarding Bundle ICL attached on both parents of a nv edge cluster (9000v2 attached to 2*9006 ver:6.1.3)
You wrote ICL members are chosen regarding access port on SAT. Well
So if we have 2 members, we can assume we have an odd/even load balancing.
Can you explain me how are packets switched between 2 SATs in this case (both are dual attached to parents) ? Because when i read document the following document it's a bit confusing regarding locality :
Bundle local member links or ECMP paths on a local rack are preferred over any
cross rack member links or ECMP paths
• Link bundle rack locality is supported in 4.2.1
locality is per link bundle, applies to only flow based loadbalance
configurable under bundle interface
Interface bundle-ether 100
bundle load-balancing localize threshold links < n >
If the number of active member links on local rack > n, enable locality for the bundle
• Rack locality supports unicast paths only
L2 multicast/flood traffic continue to use all member links in both racks
The same is for L3 multicast
The same applies to ICL bundle to/from ASR9000v
• Rack locality is off by default
I really don't want to overload my IRL for SAT2SAT flows.
Thanks for your help
regards
hi Jerome,
bundle member selection on ICL is not flow-based. It's using a modulo N, where N is the number of ports in the bundle. That way the traffic towards the same satellite access interface will always go via the same member.
/Aleksandar
thanks for help. However, maybe i wasn't clear enough or you didn't catch my real question
Let's try to be more clear :
Assuming ICL bundle has 2 members. Each of these members are connected to 2 different parents (ASR 9006 cluster for example)
That's what i called odd/even load balancing. port 0 flows go to rack 0 // 1 to 1 // 2 to 0 .....
Assuming we have 2 SAT connected in the same manner.
If a flow either come on rack 0 or 1 is ti directly forwarded to SAT2 by either rack 0 or 1 ? Or do some flows go throug IRL ?
I was sure, IRL was not involved in SAT2SAT flows but reading the attached document is really confusing
Rack locality is not on by default. So in the standard case when a member is selected for the sat port, it may not be local to the rack and we might need to use the IRL.
if we do configure/enable rack locality, you will use a member that is local to the rack, but if say rack0 attracts say 22G of traffic, and rack 0 has 2 members, you have a situation there also.
So while rack locality limits IRL usage, you might have an issue when one rack attracts more traffic than another.
xander
Hi Xander
first of all thanks for your reply
It make sense. In our topology, we try to avoid oversubscription thanks for warning.
When reading locality literature (unfortunately to small) we can see
"locality is per link bundle, applies to only flow based loadbalance "
On ICL bundle load balacing is done thanks to a input access port hash method
Does it mean we need to config a flow based loadbalacing on ICL bundle even if it's not used by devices ?
thanks for help
here is a sample config from our devices
interface Bundle-EtherXXXX
description ICL-XXXXXXX
bundle load-balancing localize threshold links 1
nv
satellite-fabric-link satellite XXXX
remote-ports GigabitEthernet 0/0/0-19,33-39,41
interface TenGigE0/1/0/0
description ICL-XXXX Port 44
bundle id XXXX mode on
interface TenGigE1/1/0/0
description ICL-XXXX Port 45
hi jerome! for the sat port to bundle ICL member, we do a simple modulo, so a sat port always takes the same member.
xander
I seem to have an issue with tunable optics in the 9000v2. As per xander's comment in one of the posts, I tuned the optic on a router before placing it in the satellite and sending it to the remote site, but still seem to have issues. here is what I did:
- I initially setup satellite and host back to back with standard single mode optics to verify that functionality is correct. I also upgraded the satellite to the software matching the XR version on the host (5.3.3)
- I setup 2 tunable optics in host router and verified they were both transmitting correct wavelength as tuned, by verifying the wavelength of the transmitted light with a light meter. both ok
- I moved SFP to the satellite and the link failed to come up over the DWDM network. I initially suspected the DWDM network filters etc.. but while troubleshooting I also checked if the SFP on the satellite was still transmitting.
and this is the tough part: Although there was a light signal which was sufficiently strong coming from the satellite SFP, the same light meter could not pick up which wavelength was being trasmitted, and in fact at the host router side, it was not receiving anything at all. Looks like the SFP was no longer functioning as expected when moved to the satellite !!
- So I moved the SFP back to the host and verified (with no actions on the host) that the SFP was transmitting at correct wavelength, it was perfectly fine.
So im stuck and need someone to help me figure out whats going on
cheers
Mark
hi mark,
if you are on the latest 9000v ios image, then there is support for the tunable optic. however it comes up with the default wavelength of 1561.02nm.
when you check that wavelength do you see power there?
once the initial discovery is there, we can use inband management towards the 9000v to adjust the wavelength that will be persistent between reloads of the satellite.
xander
Hi xander,
spot on !
the tunable in the satellite is indeed transmitting at 1561.02 i must have missed that in my troubleshooting before, even if same sfp back in the 9k host transmits at the intended/programmed wavelength.
satellite version is as per below
Satellite 305
Status: Connected (Stable)
Type: asr9000v2
Description: Sat305
Displayed device name: Sat305
MAC address: d42c.4452.2ed8
IPv4 address: 10.1.49.1 (auto, VRF: **nVSatellite)
Serial Number: CAT2036U0HD
Remote version: Compatible (latest version)
ROMMON: 128.1 (Latest)
FPGA: 1.13 (Latest)
IOS: 533.102 (Latest)
Configured satellite fabric links:
Bundle-Ether305
Status: Satellite Ready
Remote ports: GigabitEthernet0/0/0-43
Discovered satellite fabric links:
TenGigE0/0/1/1: Satellite Ready; No conflict
So if you can give me a pointer for the inband mgmt on the 9000v you mention, so we make it persistent across reboots that would be great !
Im understanding that just tuning the SFP in a 9k host router before using it in the 9000v is not sufficient, but we also need to tell the satellite that it has a tunable SFP in its port ?
cheers
Mark
hi mark, ah great! Ok so the following commands to be done from the satellite console:
Sat200#test dwdm wavelength set 44 1 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 1 Wave length : 1566.77 nm
the value set will be saved in rommon. this until it is replugged with a non dwdm sfp, then the rommon variable will be erased and the next time the dwdm is plugged in that same port, you'd need to reconfigure the wavelength.
cheers
xander
