on 07-14-2013 05:11 AM
This document provides a guide on how to use the satellite (ASR9000v) with the ASR9000 and ASR9900 series routers. It will be discussed what you can and cannot do, how to verify the satellite operation and use cases.
This document is written assuming that 5.1.1 or greater software release will be used.
Satellite is a relatively new technology that was introduced in XR 4.2.1. Satellite provides you a great and cheap way to extend your 1G ports by using this port-extender which is completely managed out of the ASR9000. The advantage is that you may have 2 devices, but 1 single entity to manage. All the satellite ports are showing up in the XR configuration of the ASR9000.
Another great advantage of the Satellite is that you can put it on remote locations, miles away from the ASR9000 host!
Although there is a limit to the number of satellites you can connect to an ASR9000 (cluster), the Satellite general concept of ASR9000 is shown here in this picture:
The physical connections are very flexible. The link between the Satellite and the ASR9000 is called the ICL or "Inter Chassis Link".
This link transports the traffic from the satellite ports to the 9000 host.
In the ASR9000 host configuration you define how the satellite ports are mapping between the ICL and the satellite ports.
You can statically pin ports from the Satellite to a single uplink (that means there is no protection, when that uplink fails, those satellite
ports become unusable), or you can bundle uplinks together and assign a group of ports to that bundle. This provides redundancy,
but with the limitation that the satellite ports that are using an uplink bundle, can't be made part of a bundle themselves.
We'll talk about restrictions a bit later.
In the picture below you see Access Device A1 connecting with a bundle that uses uplink (green) to the 9k host LC-2.
A second satellite has all their ports in a bundle ICL.
Note that there is no bandwidth constraints enforced, so theoretically you can have a 2 member ICL bundle and 30 Satellite ports mapped to it, but that would mean there is oversubscription.
While the ASR9000v/Satellite is based on the Cisco CPT-50, you cannot convert between the 2 devices by loading different software images.
You can't use the 9000v as a standalone switch, it needs the ASR9000 host.
Visual differences include that the 9000v starts the port number at 0, where the CPT starts at 1. Also the CPT has 4 different power options
and the ASR9000v only 3: AC-A, DC-A, DC-E (A for Ansi, E for ETSI).
Satellite packet format over L1 topologies looks like this; there is a simple sneaky dot1q tag added which we call the nV tag:
In L2 topologies, such as simple ring, we use dot1ad.
There is a license required to run the ASR9000v. There are 3 licenses for 1, 5, or 20 Satellites per 9k host named:
While licenses are not hard enforced, this meaning the system will still work even though a license may not be present, however you are urged to obtain the proper license, syslog messages will show the "violation of use".
Note when using simple ring, a host license for each satellite is needed on each host. E.g. a simple ring with three satellites requires six A9K-NVSAT1-LIC licenses.
A variety of optics are supported on the ASR9000v, they may not be always the same as the ASR9000. Reference this link for the supported optics for ASR9000/9000v.
When using Tunable optics for the 9000v, pay attention to the following:
(*) note for the tunable optic on the IRL you need to set the wavelength the first time via the 9000v shell on insertion of the optic before shipping it to the destined location.
Handling of Unsupported Optics
For the 9000v ports we do not support the 'service unsupported-transceiver' or 'transceiver permit pid all' commands.
The satellite device simply flags an unsupported transceiver without disabling the port or taking any further action. As long as the pluggable is readable by the satellite the SFP may work, but there are no additional 'hacks' such as the hidden commands beyond what is shown as supported in the tables from the supported optic reference link.
The following software and hardware requirements exist for the ASR9000v. Although support started in XR4.2.1 My personal recommendation is to go with XR43 (latest) as many initial restrictions are lifted from the first release:
Minimum version is XR 4.2.1
Note: If the wrong port is used for ICL then the link will stay down on the 901. Once the correct ICL port is used and the 9K configured then a reload of the 901 will need to occur for the link to come up and the 901 become recognized as a satellite.
Generally speaking all features supported on physical GigE ports of ASR9K are also automatically supported on the GigE ports of the
satellite switch such as L2, L3, multicast, MPLS, BVI, OAM … (everything that works on a normal GigE).
–L1 features: applied on the satellite chassis
1) The following features are not supported on satellite ports in 5.1.1
*Need to update this*
2) When the ICL is a link bundle, there are some restrictions :
QoS can be applied on the ASR9000 host (runs on the NP where the satellite ports have their interface descriptors) or offloaded to the satellite
When you have oversubscription, that is more then the number of 1G ports compared to the ICL total speed there could be a potential issue. However there is an implicit trust model for all high priority traffic.
Automatic packet classification rules determine whether a packet is control packet (LACP, STP, CDP, CFM, ARP, OSPF etc), high priority data (VLAN COS 5,6,7, IP prec 5, 6, 7) or normal priority data and queued accordingly
For the downstream direction, that is 9000 host to the Satellite, the "standard" QOS rules and shaping are sufficient enough to warrant the delivery of high priority packets to the satellite ports. (e.g. inject to wire etc).
As the ICL link between the satellite and host may be oversubscribed by access interfaces, configuring QoS on the satellite itself is optimal for avoiding the lose of high priority traffic due to congestion. This feature was introduced in 5.1.1
3 steps to configuring QoS offload
INPUT access interface (CLI config) example:
class-map match-any my_class
match dscp 10
end-class-map
policy-map my_policy
class my_class
set precedence 1
end-policy-map
interface GigabitEthernet100/0/0/9
ipv4 address 10.1.1.1 255.255.255.0
nv
service-policy input my_policy
Traffic is hashed across members of this ICL LAG based on satellite access port number. No packet payload information (MAC SA/ DA or IP SA/ DA) used in hash calculation. This ensures that QoS applied on ASR9K for a particular satellite access port works correctly over the entire packet stream of that access port. Current hash rule is simple (port number modulo # of active ICLs)
Plug-and-play installation: No local config on satellite, no need to even telnet in!
It is recommended to use the auto-IP feature, no loopback or VRF need to be defined. A VRF **nVSatellite will be auto-defined and does not count towards the number of VRFs configured (for licensing purposes).
Optional config secret password for satellite login. Note that the username is 'root'
There are two options for ICL:
That is static pinning; designate some ports from the satellite to use a dedicated uplink.
Using a bundle ICL that provides for redundancy when one uplink fails.
All interfaces mapped to an ICL bundle:
ASR9000 TenG interface putting into bundle mode ON (No LACP support)
Define the bundle ethernet on the ASR9000 host, and designate which ports will be mapped to the bundle:
Because of the order and batching in which things get applied in XR there are some things that you need to know when it comes down to negating certain config which additions of others.
Examples of this are:
In such cases, failures are expected to be seen; generally speaking, failures are expected to be deterministic, and workarounds available
(re-apply the configuration in two commit batches)
Recommendation to users is to commit ICL configuration changes in separate commits to Satellite-Ether configuration changes
Starting in 5.1.1 many new features were added to expand upon the basic single host hub-and-spoke model. These features take more configuration than the base satellite configuration and will be discussed below.
Starting in 5.1.1 the ability for a satellite (hub-and-spoke) or a ring of satellites (simple ring) to be dual-homed to two hosts was added. (nV Edge acts as one logical router)
With this configuration one ASR9K host is the active and the other is standby. Data and control traffic from the satellite will flow to the active host, but both hosts will send and receive management traffic via the SDAC protocol. This is used to determine connectivity, detect failures, sync the configuration, etc.
The two hosts communicate management information via ICCP with a modified version of SDAC called ORBIT.
Supported Topologies:
Hub-and-spoke dual hosts
9000v with 10G ICL or bundle ICL
901 with 1G ICL
9000v (10G) or 901 (1G) using L2 fabric sub-interfaces
Satellites may be partitioned
Simple ring dual hosts
9000v with 10G ICL
901 with 1G ICL
Satellites may not be partitioned
Note: Partitioning is when you carve out certain access ports to be used by certain ICL interfaces
Current limitations:
Must be two single chassis, no clusters
Load balancing is active/standby per satellite, per access port planned
No user configuration sync between hosts
Configuration Differences:
The most notable changes when coming from a simple hub-and-spoke design is ICCP, and adding the satellite serial number.
Example
Router 1
redundancy
iccp
group 1
member
neighbor 172.18.0.2
nv satellite
system-mac <mac> (optional)
nv
satellite 100
type asr9000v
ipv4 address 10.0.0.100
redundancy
host-priority <priority> {optional)
serial-number <satellite serial>
vrf nv_mgmt
interface loopback 10
vrf nv_mgmt
interface Loopback1000
ipv4 address 172.18.0.1 255.255.255.255
interface GigabitEthernet0/1/0/4
ipv4 address 192.168.0.1 255.255.255.0
interface ten 0/0/0/0
ipv4 point-to-point
ipv4 unnumbered loopback 10
nv
satellite-fabric-link [network satellite <> | satellite <>]
redundancy
iccp-group 1
remote-ports gig 0/0/0-43
mpls ldp
router-id 172.18.0.1
discovery targeted-hello accept
neighbor 172.18.0.2
router static
address-family ipv4 unicast
172.18.0.2/32 192.168.0.2
Starting in 5.1.1 we have the ability to support more than just simple hub-and-spoke. The ring topology allows for satellite chaining, cascading, and in general a more advanced satellite network.
Requirements and Limitations:
Configuration:
This is essentially the same as the dual hosts setup, but the network option must be used when entering 'satellite-fabirc-link'
This is treated as special ring and works the same way as simple ring.
The biggest difference is that in 5.1.1 cascading supports single host while simple ring does not.
Starting in 5.1.1 we have the ability to extend the ICL across an EVC. Normally an IRL is a L1 connection. This increases the flexibility of satellite by allowing for greater distances between the ASR9K host and the satellite device.
Requirements and limitations:
Configuration:
On Active-Host:
interface TenGigE0/1/0/23.200
encapsulation dot1q 200
nv
satellite-fabric-link satellite 200
redundancy
iccp-group 1
remote-ports GigabitEthernet 0/0/0-43
On Standby-Host:
interface TenGigE0/1/1/0.200
encapsulation dot1q 220
nv
redundancy
iccp-group 1
Note: L2 cloud configuration not shown
'show nv satellite status'
Checking Version: The version of the software running on the satellite is being checked for compatibility with the running version of IOS-XR on the host
Configured Serial Number: (If configured) the serial number configured for the satellite, checked against that presented by the satellite during control protocol authentication
Configured Satellite Links: One entry for each of the configured satellite-fabric-links, headed by the interface name. The following information is present for each configured link:
Discovered Satellite Fabric Links: This section is only present for redundant satellite-fabric-links. This lists the interfaces that are members of the configured link, and the per-link discovery state.
Conflict: If the configured link is not conflicted, the satellite discovered over the link is presenting data that contradicts that found over a different satellite-fabric-link.
'show nv satellite protocol discovery'
Host IPv4 Address: The IPv4 address used for the host to communicate to this satellite. Should match the IPv4 address on all the satellite-fabric-links
For Bundle-Ether satellite-fabric-links, there are then 0 or more 'Discovered links' entries; for physical satellite-fabric-links, the same fields are present but just inline.
'show nv satellite protocol control'
Authenticating: The TCP session has been established, and the control protocol is checking the authentication information provided by the Satellite
Connected: The SDACP control protocol session to the satellite has been successfully brought up, and the feature channels can now be opened.
For each channel, the following fields are present:
Open(In Resync - Awaiting Client Resync End) The Feature Channel Owner (FCO) on the host has not finished sending data to the FCO on the Satellite. If this is the state then typically the triage should continue on the host by the owner. The owner of the Feature Channel should be contacted.
Open(In Resync - Awaiting Satellite Resync End) The FCO on the Host is awaiting information from the FCO on the Satellite. If this is the state then typically the triage should continue on the satellite.
Notes:
icpe_gco[1148]: %PKT_INFRA-ICPE_GCO-6-TRANSFER_DONE : Image transfer completed on Satellite 101
A few issues can cause this:
Conflict Messages
Examples:
BNG access over satellite is only qualified over bundle access and isn’t supported over bundle ICLs.
BNG access over ASR9k host and NCS5k satellite specifically is in the process of official qualification in 6.1.x. Please check with PM for exact qualified release.
Access bundles across satellites in an nV dual head solution are generally not recommended. The emphasis is not to bundle services across satellites in a dual head system as if they align to different hosts, the solution breaks without an explicit redundant path. An MCLAG over satellite access is a better solution there.
Bundle access over bundle fabric / ICL require 5.3.2 and above on ASR9k. For NCS5k satellite, bundle ICL including bundle over bundle is supported from 6.0.1 and nV dual head topologies are planned to be supported only from 6.1.1
MC-LAG over satellite access might be more convergence friendly and feature rich than nV dual head for BNG access from previous case studies. For non BNG access, nV dual head and MC-LAG are both possible options with any combinations of physical or bundle access and fabric.
In an MC-LAG with satellite access, the topology is just a regular MC-LAG system with the hosts syncing over ICCP but with satellite access as well. Note that the individual satellites aren’t dual homed/hosted here so there is no dual-host feature to sync over ICCP beyond just MC-LAG from CE.
As a deployment recommendation, unless ICL links (between satellite and host) are more prone to failure over access, MC-LAG might be preferable over nV dual head solution. However, if ICL links have higher failure probability and the links going down can affect BW in bundle ICL cases, then MC-LAG may not switch over unless the whole link goes down or access goes down.
Xander Thuijs CCIE#6775
Principal Engineer, ASR9000
Sam Milstead
Customer Support Engineer, IOS XR
Hi xander,
perfect thanks
question for you: how do i map the number to the wavelength.
You use 44 for 1566.77 - I dont see 44 mapped to 1566.77 in itu mapping for 50Ghz, neither in "show controllers dwdm 0/0/1/1 wavelength-map" on my 9904 host.
I need to setup with 1530.33nm on the satellite, whats the number I need to use, or can i use different cli and use wavelength ?
cheers
Mark
Hi, Xander:
Can you please shed some light into the following capture?
Sat128# sh satellite alarms
Equipment / Chassis level Alarms:
None Set
Port level Alarms:
Port 1: None Set
[snip]
Port 44: None Set
Port 45: defect 3(DEF_SYNCLOSS)
Port 45: defect 8(DEF_LOCAL_FAULT)
Port 46: None Set
Port 47: None Set
Port 48: None Set
Sat128#sh log | inc port 45
*Apr 24 16:52:22.456: %SAT9k_NOTIF-1-LINK_ALM: DEF_SYNCLOSS has been raised for port 45
*Apr 24 16:52:22.456: %SAT9k_NOTIF-1-LINK_ALM: DEF_LOCAL_FAULT has been raised for port 45
I cannot find any reference for what it means anywhere. My customer opted not to use that port because of the syslog messages.
c.
hi carlos,
this means that the interface has a local fault identified and notably the fact that it lost its framing/syncing. it could be the light levels are too low, or the port is not seeing any framing.
could any of that be the case?
xander
Honestly, I don't think so. Customer stopped using that port altogether.
I think an SR is in order here but wanted to see I you could help me out with the syslog message first.
Thanks, Xander.
yeah the syslog by itself (and both of them go hand in hand) means that there is some sort of L1 issue.if there are extra circumstantial messages like high bias or low power etc that could explain the sync loss hence local fault raised.
the optic could be busted, the phy could be busted or thefiber itself.
few things to triage here are:
- move optic to different port to see if the problem moves with the optic
- use new optic or known working one from another port in this one to see if it is a phy issue.
check the optic light levels too via the cli to see if there is anything received (or too low) etc.
I checked for a few known issues in our database, but nothing sw wise stands out at this point to be aware of.
xander
hi xander,
this worked great - thanks for your help
it took me a while to figure out which value to use for the wavelength i needed.(plus the 44 i realised was the port, and 1 was the lamda in your example).
it was trial and error, as i could not find a mapping table.
happen to have a link for that, as the itu map or the asr9k map did not seem to be valid ?
cheers
mark
This is the unit test from the ddts that implemented it below. I also see a discrepancy between channel and wave length. It should be the 50G ITU spacing that the normal dwdm-sfp-c supports so that datasheet can be used/leveraged.
you program the channel number and the readback will show the programmed wavelength is what I see from the code.
I will check into see if I can get some more specifics on the table, but maybe this helps as a start already :
xander
at200#test dwdm wavelength set 44 1 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 1 Wave length : 1566.77 nm Sat200#test dwdm wavelength set 44 2 Number of retrycout 5, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 2 Wave length : 1566.31 nm Sat200#test dwdm wavelength set 44 3 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 3 Wave length : 1565.91 nm Sat200#test dwdm wavelength set 44 4 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 4 Wave length : 1565.52 nm Sat200#test dwdm wavelength set 44 5 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 5 Wave length : 1565.13 nm Sat200#test dwdm wavelength set 44 6 Number of retrycout 4, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 6 Wave length : 1564.67 nm Sat200#test dwdm wavelength set 44 7 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 7 Wave length : 1564.28 nm Sat200#test dwdm wavelength set 44 8 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 8 Wave length : 1563.89 nm Sat200#test dwdm wavelength set 44 9 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 9 Wave length : 1563.50 nm Sat200#test dwdm wavelength set 44 10 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 1, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 10 Wave length : 1563.5 nm Sat200#test dwdm wavelength set 44 11 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 11 Wave length : 1562.64 nm Sat200#test dwdm wavelength set 44 12 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 2, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 12 Wave length : 1562.25 nm Sat200#test dwdm wavelength set 44 13 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 13 Wave length : 1561.86 nm Sat200#test dwdm wavelength set 44 14 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 2, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 14 Wave length : 1561.41 nm Sat200#test dwdm wavelength set 44 15 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 15 Wave length : 1561.2 nm Sat200#test dwdm wavelength set 44 16 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 16 Wave length : 1560.63 nm Sat200#test dwdm wavelength set 44 17 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 17 Wave length : 1560.23 nm Sat200#test dwdm wavelength set 44 18 Number of retrycout 3, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 18 Wave length : 1559.78 nm Sat200#test dwdm wavelength set 44 19 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 19 Wave length : 1559.39 nm Sat200#test dwdm wavelength set 44 20 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 20 Wave length : 1559.0 nm Sat200#test dwdm wavelength set 44 21 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 21 Wave length : 1558.63 nm Sat200#test dwdm wavelength set 44 22 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 1, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 22 Wave length : 1558.17 nm Sat200#test dwdm wavelength set 44 23 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 23 Wave length : 1557.78 nm Sat200#test dwdm wavelength set 44 24 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 24 Wave length : 1557.39 nm Sat200#test dwdm wavelength set 44 25 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 25 Wave length : 1557.0 nm Sat200#test dwdm wavelength set 44 26 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 26 Wave length : 1556.55 nm Sat200#test dwdm wavelength set 44 27 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 27 Wave length : 1556.16 nm Sat200#test dwdm wavelength set 44 28 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 5, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 28 Wave length : 1555.77 nm Sat200#test dwdm wavelength set 44 29 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 29 Wave length : 1555.39 nm Sat200#test dwdm wavelength set 44 30 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 30 Wave length : 1554.94 nm Sat200#test dwdm wavelength set 44 31 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 31 Wave length : 1554.55 nm Sat200#test dwdm wavelength set 44 32 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 32 Wave length : 1554.16 nm Sat200#test dwdm wavelength set 44 33 Number of retrycout 0, val16bit 0 Number of retrycout 2, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 33 Wave length : 1553.77 nm Sat200#test dwdm wavelength set 44 34 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 34 Wave length : 1553.33 nm Sat200#test dwdm wavelength set 44 35 Number of retrycout 0, val16bit 0 Number of retrycout 5, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 35 Wave length : 1552.94 nm Sat200#test dwdm wavelength set 44 36 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 36 Wave length : 1552.55 nm Sat200#test dwdm wavelength set 44 37 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 37 Wave length : 1552.16 nm Sat200#test dwdm wavelength set 44 38 Number of retrycout 2, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 38 Wave length : 1551.72 nm Sat200#test dwdm wavelength set 44 39 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 39 Wave length : 1551.33 nm Sat200#test dwdm wavelength set 44 40 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 40 Wave length : 1550.94 nm Sat200#test dwdm wavelength set 44 41 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 5, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 41 Wave length : 1550.56 nm Sat200#test dwdm wavelength set 44 42 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 42 Wave length : 1550.11 nm Sat200#test dwdm wavelength set 44 43 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 43 Wave length : 1549.72 nm Sat200#test dwdm wavelength set 44 44 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 44 Wave length : 1549.34 nm Sat200#test dwdm wavelength set 44 45 Number of retrycout 3, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 45 Wave length : 1548.95 nm Sat200#test dwdm wavelength set 44 46 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 46 Wave length : 1548.50 nm Sat200#test dwdm wavelength set 44 47 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 47 Wave length : 1548.13 nm Sat200#test dwdm wavelength set 44 48 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 5, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 48 Wave length : 1547.73 nm Sat200#test dwdm wavelength set 44 49 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 49 Wave length : 1547.36 nm Sat200#test dwdm wavelength set 44 50 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 50 Wave length : 1546.91 nm Sat200#test dwdm wavelength set 44 51 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 3, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 51 Wave length : 1546.53 nm Sat200#test dwdm wavelength set 44 52 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 52 Wave length : 1546.14 nm Sat200#test dwdm wavelength set 44 53 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 53 Wave length : 1545.77 nm Sat200#test dwdm wavelength set 44 54 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 5, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 54 Wave length : 1545.31 nm Sat200#test dwdm wavelength set 44 55 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 55 Wave length : 1544.94 nm Sat200#test dwdm wavelength set 44 56 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 56 Wave length : 1544.55 nm Sat200#test dwdm wavelength set 44 57 Number of retrycout 3, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 57 Wave length : 1544.17 nm Sat200#test dwdm wavelength set 44 58 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 58 Wave length : 1543.72 nm Sat200#test dwdm wavelength set 44 59 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 59 Wave length : 1543.34 nm Sat200#test dwdm wavelength set 44 60 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 60 Wave length : 1542.95 nm Sat200#test dwdm wavelength set 44 61 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 2, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 61 Wave length : 1542.58 nm Sat200#test dwdm wavelength set 44 62 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 62 Wave length : 1542.14 nm Sat200#test dwdm wavelength set 44 63 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 63 Wave length : 1541.75 nm Sat200#test dwdm wavelength set 44 64 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 64 Wave length : 1541.38 nm Sat200#test dwdm wavelength set 44 65 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 65 Wave length : 1541.0 nm Sat200#test dwdm wavelength set 44 66 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 66 Wave length : 1540.55 nm Sat200#test dwdm wavelength set 44 67 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 67 Wave length : 1540.17 nm Sat200#test dwdm wavelength set 44 68 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 68 Wave length : 1539.80 nm Sat200#test dwdm wavelength set 44 69 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 69 Wave length : 1539.41 nm Sat200#test dwdm wavelength set 44 70 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 70 Wave length : 1538.97 nm Sat200#test dwdm wavelength set 44 71 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 71 Wave length : 1538.59 nm Sat200#test dwdm wavelength set 44 72 Number of retrycout 3, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 72 Wave length : 1538.20 nm Sat200#test dwdm wavelength set 44 73 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 1, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 73 Wave length : 1537.83 nm Sat200#test dwdm wavelength set 44 74 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 74 Wave length : 1537.39 nm Sat200#test dwdm wavelength set 44 75 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 75 Wave length : 1537.2 nm Sat200#test dwdm wavelength set 44 76 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 76 Wave length : 1536.64 nm Sat200#test dwdm wavelength set 44 77 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 77 Wave length : 1536.25 nm Sat200#test dwdm wavelength set 44 78 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 78 Wave length : 1535.81 nm Sat200#test dwdm wavelength set 44 79 Number of retrycout 0, val16bit 0 Number of retrycout 5, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 79 Wave length : 1535.44 nm Sat200#test dwdm wavelength set 44 80 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 80 Wave length : 1535.6 nm Sat200#test dwdm wavelength set 44 81 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 81 Wave length : 1534.69 nm Sat200#test dwdm wavelength set 44 82 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 82 Wave length : 1534.25 nm Sat200#test dwdm wavelength set 44 83 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 83 Wave length : 1533.86 nm Sat200#test dwdm wavelength set 44 84 Number of retrycout 5, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 84 Wave length : 1533.48 nm Sat200#test dwdm wavelength set 44 85 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 85 Wave length : 1533.11 nm Sat200#test dwdm wavelength set 44 86 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 86 Wave length : 1532.67 nm Sat200#test dwdm wavelength set 44 87 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 87 Wave length : 1532.30 nm Sat200#test dwdm wavelength set 44 88 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 88 Wave length : 1531.92 nm Sat200#test dwdm wavelength set 44 89 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 89 Wave length : 1531.55 nm Sat200#test dwdm wavelength set 44 90 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 90 Wave length : 1531.11 nm Sat200#test dwdm wavelength set 44 91 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 91 Wave length : 1530.73 nm Sat200#test dwdm wavelength set 44 92 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 92 Wave length : 1530.36 nm Sat200#test dwdm wavelength set 44 93 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 93 Wave length : 1529.98 nm Sat200#test dwdm wavelength set 44 94 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 94 Wave length : 1529.55 nm Sat200#test dwdm wavelength set 44 95 Number of retrycout 0, val16bit 0 Number of retrycout 3, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 95 Wave length : 1529.17 nm Sat200#test dwdm wavelength set 44 96 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Number of retrycout 0, val16bit 0 Sat200#show satellite dwdm-dump 44 Wl Channel Number : 96 Wave length : 1528.80 nm Sat200# Sat200#show satellite dwdm-dump 44 Wl Channel Number : 30 Wave length : 1554.94 nm Sat200#tes Sat200#test dw Sat200#test dwdm wa Sat200#test dwdm wavelength se Sat200#test dwdm wavelength set 44 68 Sat200#show satellite dwdm-dump 44 listen socket already exists, return from sat9k_control_listen_dequeued line 1052 Wl Channel Number : 68 Wave length : 1539.80 nm Sat200# Sat200# Sat200#show satellite dwdm-dump 44 Wl Channel Number : 68 Wave length : 1539.80 nm Sat200#sho Sat200#sho Sat200#show sa Sat200#show satellite in Sat200#show satellite inventory po Sat200#show satellite inventory port 45 Port 45 IDPROM Data: Product Id : DWDM-SFP10G-C Product Name : 10GE-DWDM Version ID : ES1 CLEI Code : ABCDE12345 Top Assembly Part No. : 10-303|# Serial Number : JFS18091008 PCB Revision : 0000<06> Vendor Name : CISCO-JDSU Wave length : 1539.80 nm
Update:
The dwdm sfp-c is indeed programmed by wavelength of the ITU 50G grid as I mentioned, the specific table can be found here in table 3.
when you do a dwdm-read on the satellite, you read back the actual wavelength the optic has been tuned to and there is a slight variation possible there in terms of 100's of a nm.
So basically if you want the set a nomimal wavelength, check the table 3 from the link and use that channel number to program the sfp.
cheers!
xander
great and thanks for the fast reply.
I had googled ITU grid and checked the config guide but they didnt match, hadnt figured that the datasheet was the one to go with !
thanks again
mark
Hi, Xander:
When telnetting directly into an nv sat, is there a way to change the hostname prompt you see?
(What does the "device-name" (under nv) command do? Don't have a sat at this moment to test it.)
Thanks!
c.
Hello. I see this thread is a bit old, but I'm clutching at straws right now. Anybody ever have an issue with all of the front panel LEDs staying red despite the fact that they are administratively down? I have circuits traversing the 9000v, and I'm not getting any errors in ASR9K logs. I've put the ports in service and then shut them down. Rebooted the 9000v and it comes up all red, except the ports that have an actually link, and they are green. I've tried a few of the ports in questions after I turned them up and plugged a host in, and they went green. I shut the port down, and it goes red, instead of going off. Strange. Any help would be greatly appreciated. Thanks.
does anybody know if this limitation still exist ?
Regarding configuration exemple i have on ASR9006 to connect my ASR9000v below, is a LAG now possible on GigabitEthernet1011/0/0/38 ?
Thanks for answer.
nv
satellite 1011
type asr9000v2
secret 5 xxxxxxxxxxxx
description 1011_Name
device-name 1011_Name
redundancy
host-priority 1 (or 2 for secondary 9006)
serial-number #serial
interface Bundle-Ether1011
description ICL-Name
nv
satellite-fabric-link satellite 1011
redundancy
iccp-group 11
remote-ports GigabitEthernet 0/0/0-41
interface TenGigE0/1/0/0
description ICL-Name-01_44
bundle id 1011 mode on
interface GigabitEthernet1011/0/0/38
description ICO-DSL-1
negotiation auto
interface GigabitEthernet1011/0/0/38.1502 l2transport
description DSL
encapsulation dot1q 1200
rewrite ingress tag pop 1 symmetric
interface GigabitEthernet1011/0/0/38.1525 l2transport
encapsulation dot1q 1525
ipv4 access-group 1vN ingress
