lamarsh
Level 5
Level 5
Overview
The Cisco® WAN Automation Engine (WAE) Topology Service is a lightweight service that enables Cisco Network Services Orchestrator (NSO) to automate node discovery in a network. The service leverages WAE key capabilities without requiring a WAE license.
NSO (enabled by Tail-f) simplifies the process of provisioning services in both physical and virtual networks. It decouples network services from specific components, while automatically configuring the network according to the service specifications.
This demonstration requires familiarity with networking architecture and routing fundamentals, and it highlights scenarios in which you use Cisco WAE to interact with a segment routing-enabled network.
Check it out here: Cisco WAN Automation Engine 6.4 Topology Service with NSO 4.1.1 with 8 Nodes v1
Scenarios
  • Scenario 1: Prepare Demonstration Devices
  • Scenario 2: Configure Node Discovery
  • Scenario 3: Run Data Collection
  • Scenario 4: Automate Scheduled Collection
Requirements
RequiredOptional
  • Laptop
  • Cisco AnyConnect
Components
  • Cisco WAE 6.4 Topology Service
  • Cisco NSO 4.1.1
  • VIRL simulating 8 ASR9ks
Features
Cisco WAE
  • Lightweight service that enables NSO to automate node discovery in a network.
  • Topology Service leverages WAE key capabilities without requiring a WAE license.
Cisco NSO
  • A single, network-wide interface to all network devices and all network applications and services.
Virtual Internet Routing Lab (VIRL)
  • Multi-purpose network virtualization platform.
  • Provides an easy way to build, configure, and test new or existing network topologies.
Topology
