narvenka
1. Description:
This document describes about how to derive yang path from a yang module. It’s challenging to get the sensor path info from the yang modules containing data models. Below section explains about how to get the a data model from a Yang module.
This can be used for both Cisco and openconfig specific yang modules.
Yang is a data modeling language used to model configs and provide real time state data.
2. Summary
  1. Install Pyang
  2. Download yang modules from git
  3. Using pyang derive the path
  4. Configure on xr router and validate
3. Detailed steps using pyang to derive the path
3.1 Get pyang using “pip install pyang”
3.2 Use the below github link to clone or download
https://github.com/YangModels/yang.git
NARVENKA$ git clone https://github.com/YangModels/yang.git
Cloning into 'yang'...
remote: Enumerating objects: 2, done.
remote: Counting objects: 100% (2/2), done.
remote: Compressing objects: 100% (2/2), done.
remote: Total 21976 (delta 0), reused 1 (delta 0), pack-reused 21974
Receiving objects: 100% (21976/21976), 42.41 MiB | 3.48 MiB/s, done.
Resolving deltas: 100% (17077/17077), done.
Checking out files: 100% (20902/20902), done.
NARVENKA$
3.3  Browse through the directory:
NARVENKA$ cd yang/
NARVENKA$ ls
README.md  experimental  setup.py           standard          testall.sh          tools                   vendor
NARVENKA$ cd vendor/
NARVENKA$ cd cisco/
NARVENKA$ ls
README.md  check.sh           common                         nx                        xe                        xr
NARVENKA$ cd xr/
NARVENKA$ ls
530                     533                     601                     612                     622                     632                     651
531                     534                     602                     613                     623                     641                     README.md
532                     600                     611                     621                     631                     642                     check.sh
NARVENKA$ cd 651/
NARVENKA$ pwd
/Users/macuser/yang/vendor/cisco/xr/651
3.4 Based on the requirement select the yang model from
https://github.com/YangModels/yang/tree/master/vendor/cisco/xr
3.5 Using pyang construct yang path
<Modulename:yang tree with leaf>
Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface/member-interfaces/member-interface/output
NARVENKA$ pyang -f tree Cisco-IOS-XR-qos-ma-oper.yang  --tree-depth=1
module: Cisco-IOS-XR-qos-ma-oper
  +--ro qos
NARVENKA$ pyang -f tree Cisco-IOS-XR-qos-ma-oper.yang  --tree-path=qos --tree-depth=2
  +--ro qos
     +--ro nv-interface-table
     +--ro nv-satellite
     +--ro nodes
     +--ro qos-global
     +--ro interface-table
NARVENKA$ pyang -f tree Cisco-IOS-XR-qos-ma-oper.yang  --tree-path=qos/interface-table --tree-depth=3
  +--ro qos
        +--ro interface* [interface-name]
NARVENKA$ pyang -f tree Cisco-IOS-XR-qos-ma-oper.yang  --tree-path=qos/interface-table/interface --tree-depth=4
  +--ro qos
           +--ro nodes
           +--ro interface-name       xr:Interface-name
           +--ro member-interfaces
           +--ro satellite-ids
           +--ro input
           +--ro output
NARVENKA$ pyang -f tree Cisco-IOS-XR-qos-ma-oper.yang  --tree-path=qos/interface-table/interface/member-interfaces --tree-depth=5
  +--ro qos
              +--ro member-interface* [interface-name]
NARVENKA$ pyang -f tree Cisco-IOS-XR-qos-ma-oper.yang  --tree-path=qos/interface-table/interface/member-interfaces/member-interface --tree-depth=6
  +--ro qos
                 +--ro satellite-ids
                 +--ro input
                 +--ro output
NARVENKA$ pyang -f tree Cisco-IOS-XR-qos-ma-oper.yang  --tree-path=qos/interface-table/interface/member-interfaces/member-interface/output --tree-depth=7
  +--ro qos
                 +--ro output
                    +--ro service-policy-names
NARVENKA$
4. Construct sensor path and validate data model
Now construct the sensor path including tree with respective leaf. In XR node sensor path configured under sensor group. Please refer the below example for validation.
sensor-path Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface/member-interfaces/member-interface/output
Example:
RP/0/RSP0/CPU0:BX03#conf terminal
RP/0/RSP0/CPU0:BX03(config)#telemetry model-driven
RP/0/RSP0/CPU0:BX03(config-model-driven)#sensor-group 1minute
RP/0/RSP0/CPU0:BX03(config-model-driven-snsr-grp)# sensor-path Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface/member-interfaces/member-interface/output
RP/0/RSP0/CPU0:BX03(config-model-driven-snsr-grp)#commit
RP/0/RSP0/CPU0:Sep 25 20:20:41.691 UTC: config[66977]: %MGBL-CONFIG-6-DB_COMMIT : Configuration committed by user 'narvenka'. Use 'show configuration commit changes 1000000386' to view the changes.
RP/0/RSP0/CPU0:BX03(config-model-driven-snsr-grp)#end
RP/0/RSP0/CPU0:Sep 25 20:20:43.069 UTC: config[66977]: %MGBL-SYS-5-CONFIG_I : Configured from console by narvenka
RP/0/RSP0/CPU0:BX03#show telemetry model-driven subscription
Subscription:  1minute                  State: NA
  Sensor groups:
  Id                               Interval(ms)        State
  1minute                          60000               Resolved
RP/0/RSP0/CPU0:BX03#show telemetry model-driven subscription detail
Subscription:
  State:       NA
  Collection Groups:
  No active collection groups
RP/0/RSP0/CPU0:BX03#show telemetry model-driven subscription 1minute
  State:       NA
  Sensor groups:
    Sample Interval:      60000 ms
    Sensor Path:          Cisco-IOS-XR-asr9k-np-oper:hardware-module-np/nodes/node/nps/np/load-utilization
    Sensor Path State:    Resolved
    Sensor Path:          Cisco-IOS-XR-telemetry-model-driven-oper:telemetry-model-driven/destinations/destination
    Sensor Path:          Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface/member-interfaces/member-interface/output
  Collection Groups:
Also refer “Implementing GRPC/Telemetry on XR devices” for more info about implementation.
rborad
Nice Info. Thanks Venkat !!
patoh
hi @narvenka
my experience is that not all models listed in repo for specific version (https://github.com/YangModels/yang/tree/master/vendor/cisco/xr) are supported.
I found useful to check supported models via netconf: ssh <router> -s netconf
see more details here:
https://community.cisco.com/t5/xr-os-and-platforms/testing-telemetry-on-xrv9k-6-6-3/m-p/4041347/highlight/true#M11433
