Nicolas Fevrier
Quick and dirty copy/paste of the different steps used for this installation on the VSM card.
First, it's important to remind that the system does not operate in stand-alone mode, you need to pair it with a Peakflow SP (the netflow collector + attack detector + controller of the entire solution) and you need to use the proper licenses.
Before you install TMS-VSM software on the VSM blade, do the following:
0. Configure "allow TFTP" in the CoPP:
control-plane
 management-plane
  inband
  interface all
    allow TFTP
1. Insert the VSM blade in the ASR 9000 router backplane
2. Connect a serial console or laptop to the ASR 9000 router
3. Use telnet or ssh to log on to the CLI of the ASR 9000 router that has the VSM blade
4. Use the ASR 9000 CLI to perform the following tasks:
virtual-service enable
commit
- Verify that virtual services are initialized with:
show virtual-service list
- Enter the following commands to uninstall any existing services on the VSM blade:
config
no virtual-service tmsX
commit
exit
virtual-service uninstall name tmsX
To install the TMS-VSM software on the VSM blade:
1. Log on to the CLI of the ASR 9000 router that has the VSM blade.
2. To copy the .ova file to the router:
copy tftp:/Peakflow-TMS-7.0-EKU0.ova disk0:
Use the correct path/filename for your build.
- At the prompt Address or name of remote host[]?, type the IP address for the remote host (for example, 10.8.22.116)
- At the prompt Destination filename, press enter.
3. To verify that the .ova file was copied:
dir disk0:
The file should appear at the end of the directory file list.
4. To find the node name for your VSM blade:
show inventory all | include "Virtualized Services Module"
The node name will be of the form 0/slot/CPU0.
Note: To verify the node name:
5. To install the virtual service:
virtual-service install name tms3 package /disk0:/Peakflow-TMS-7.0-EKU0.ova node 0/n/CPU0
where:
n = the slot number for the VSM blade.
Allow approximately 10 to 12 minutes for installation to complete.
6. To verify that the virtual service is installed:
Note: If the installation is initializing, this show command does not show any data. If installation is in process, this command shows the message Installing. When installation is complete, you can rerun this show command to verify that the virtual service is listed as installed.
To map VNIC interfaces on the router to TMS interfaces on the VSM blade:
1. To map the interfaces, enter the following commands, replacing n with the slot number for the VSM blade:
virtual-service tmsn
vnic interface TenGigE0/n/1/0
vnic interface TenGigE0/n/1/1
vnic interface TenGigE0/n/1/2
vnic interface TenGigE0/n/1/3
vnic interface TenGigE0/n/1/4
vnic interface TenGigE0/n/1/5
vnic interface TenGigE0/n/1/6
vnic interface TenGigE0/n/1/7
vnic interface TenGigE0/n/1/8
vnic interface TenGigE0/n/1/9
vnic interface TenGigE0/n/1/10
vnic interface TenGigE0/n/1/11
commit
activate
commit
To verify that all interfaces are activated:
2. Create the interface bundle for mitigation interfaces tmsx0-3 and tmsx7-10 and to bundle the subinterfaces
3. Set up the management interfaces, tmsx5-6
4. Set up the unused interfaces, tmsx4 and tmsx11
Configuration will finally look like this:
vrf onRamp
address-family ipv4 unicast
address-family ipv6 unicast
vrf offRamp
snmp-server host 25.2.1.10 traps arbor
snmp-server community arbor
virtual-service TMS1
vnic interface TenGigE0/1/1/0
vnic interface TenGigE0/1/1/1
vnic interface TenGigE0/1/1/2
vnic interface TenGigE0/1/1/3
vnic interface TenGigE0/1/1/4
vnic interface TenGigE0/1/1/5
vnic interface TenGigE0/1/1/6
vnic interface TenGigE0/1/1/7
vnic interface TenGigE0/1/1/8
vnic interface TenGigE0/1/1/9
vnic interface TenGigE0/1/1/10
vnic interface TenGigE0/1/1/11
activate
control-plane
management-plane
inband
interface TenGigE0/2/0/6
allow TFTP
allow SNMP
allow SNMP peer
address ipv4 25.2.1.10
interface Bundle-Ether2
description bundle to-from vsm1
load-interval 30
interface Bundle-Ether2.100
description offramp subinterface
ipv4 address 13.37.13.37 255.255.255.252
bundle load-balancing hash src-ip
load-interval 30
encapsulation dot1q 100
interface Bundle-Ether2.101
description onramp subinterface
vrf onramp
ipv4 address 13.37.13.41 255.255.255.252
load-interval 30
encapsulation dot1q 101
interface Loopback0
ipv4 address 4.4.4.4 255.255.255.255
interface MgmtEth0/RSP0/CPU0/0
ipv4 address 1.2.3.4 255.255.255.0
bundle id 2 mode on
load-interval 30
bundle id 2 mode on
load-interval 30
bundle id 2 mode on
load-interval 30
bundle id 2 mode on
load-interval 30
load-interval 30
description mgt0 on TMS1
ipv4 address 25.3.1.1 255.255.255.0
load-interval 30
description mgt1 on TMS1
load-interval 30
bundle id 2 mode on
load-interval 30
bundle id 2 mode on
load-interval 30
bundle id 2 mode on
load-interval 30
bundle id 2 mode on
load-interval 30
shutdown
Last step will consist in configuring the BGP peers and BGP flowspec peers according to the divertion (offRamp/onRamp) strategy.
Sun Dec 7 17:31:13.867 UTC
Trying 192.0.131.3...
Connected to 192.0.131.3.
Escape sequence is '^^e'.
010: Using CD-ROM
018: No system configuration found
020: Configuring CD-ROM
Do you want to begin the install process?
This will remove all current data and configuration [n/y] y
Initializing filesystem "boot"..........................done.
Writing boot blocks....done.
Initializing filesystem "system"..........................done.
Initializing filesystem "data"..........................done.
Initializing swap partition......done.
system: clean, 11/512064 files, 53444/2048000 blocks
data: clean, 11/407360 files, 53327/3107840 blocks
boot: clean, 28/128016 files, 26963/510976 blocks
Installing software package "cdrom:arbos-6.1-ELDN-x86_64"
Extracting package...done.
Changes to ArbOS will take effect after the next reload.
Installing software package "cdrom:Peakflow-TMS-7.0-ELDN-vm"
Collecting inventory information..done
Building databases.......................................................................done.
virtual-service connect name TMS1 console node 0/1/CPU0
010: Using CD-ROM
.......................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................*****..*************boot: …
system: clean, 24175/512064 files, 171499/2048000 blocks
data: clean, 419/407360 files, 61114/3107840 blocks
boot: clean, 64/128016 files, 129079/510976 blocks
005: Configuring swap devices
006: Configuring software packages
007: Restoring system configuration
021: Done rc.sysinit
ArbOS/6.1 (arbos)
arbos login: admin
Password:
Peakflow TMS v7.0
Copyright (c) 2000-2014 Arbor Networks, Inc. All Rights Reserved.
Welcome to ArbOS
mkhalil10
Dear Nicolas
Thanks for the great post
I was in a discussion with Cisco TAC regarding the same subject , according to them , I cannot use more than a service per VSM module
I am already running NAT44 service and am attaching virtual-interfaces to it
When I asked them about how many virtual-interfaces do I need , they told me I need another module?
What do u think?
BR,
Mohammad
Nicolas Fevrier
Hi Mohammad,
the TAC engineer is right, we don't support multiple VMs over a single VSM.
If you need to run both the TMS app and the CGN app, you need two VSM cards in the chassis.
On the TMS case, among the 12 interfaces: 8 are gathered in a bundle for traffic and 2 are assigned to management (2 last are shut down).
BR,
N.
lemmocisco
I am having some trouble with the TMS VM...
this is the output I get from the activate command:
RP/0/RSP0/CPU0:BB-ASR9K(config)#virtual-service tms3
RP/0/RSP0/CPU0:BB-ASR9K(config-virt-service)#activate
RP/0/RSP0/CPU0:BB-ASR9K(config-virt-service)#comm
Mon Mar 13 17:03:20.343 MET
RP/0/RSP0/CPU0:2017 Mar 13 17:03:21.721 MET: service_mgr[413]: %OS-LIB_VMAN-3-START_FAILED : Virtual Service[tms3]::Start failed::Failed to start the virtual service::Resource Manager: vm_resource_allocate_best_effort :Failed to allocate socket resources
RP/0/RSP0/CPU0:2017 Mar 13 17:03:22.945 MET: service_mgr[413]: %OS-SMGR-3-VM_ACTIVATE_FAIL : Service VM 'tms3' activation failed
Do you have any idea what could be the problem?
Thank you.
Aleksandar Vidakovic
Which IOS XR release are you running and which Arbor TMS version?
regards,
/Aleksandar
lemmocisco
Cisco IOS XR Software is Version 5.3.4 while TMS is Peakflow-TMS-7.5.1-FJBK.ova
Nitin Pabbi
TMS 7.5.1 is not compatible with 5.3.4 because we have introduced memory composition for VSM operations.
kindly use TMS 8.1 with 5.3.4. TMS 8.1 was released in Dec '16 and have better memory consumption model along with better performance capabilities.
Nitin Pabbi
Jerry Ebanks
Hi Nicolas:
this step below that is blod:
does that mean that it will reboot the entire router or just the VSM card. Am asking because am placing a vsm card and the router is a live node that has live traffic and can affect service.
Your advice would be greatly appreciated.
Thank you.
smailmilak
Level 4
Level 4
No way that the whole router will be rebooted because of one module.
We have a couple of ISM-100 and the installation process restarts only the module.
Jerry Ebanks
Hi Smailmilak:
Thanks for the feedback. I can see that but just wanted to be sure. is ISM-100 like VSM? or have you done VSM card installation?
lemmocisco
Hi Jerry,
I have installed the TMS on a VSM-500 and the ASR does not reboot, actually, regarding the point:
it means the Virtual MAchine will be restarted, not even the VSM.
This is the whole log from the installation:
RP/0/RSP0/CPU0:BB-ASR9K#virtual-service connect name TMS console node 0/1/CPU0
Tue Mar 21 17:45:00.818 MET
Trying 192.0.129.3...
Connected to 192.0.129.3.
Installing software package "cdrom:arbos-6.2-GLBL-x86_64"
Checking package integrity...done.
Checking package preconditions...done.
Extracting package...!done.
Installing software package "cdrom:Arbor-TMS-8.1.0-GLBL-x86_64"
Building databases.....................................................done.
System hostname? [arbos] TMS
160: Invalid hostname
System hostname? [arbos] ARBOR
IP address for interface mgt0: [none] 10.10.20.41
Netmask for interface mgt0: [255.255.255.0] 255.255.255.252
Media for interface mgt0: [none]
IP address for interface mgt1: [none]
Default route: [none] 10.10.20.42
bgp access from which network? [done]
http access from which network? [done] 10.10.0.0/24
https access from which network? [done] 10.10.0.0/24
openflow access from which network? [done] 10.10.0.0/24
ping access from which network? [done] 10.10.0.0/24
snmp access from which network? [done] 10.10.0.0/24
ssh access from which network? [done] 10.10.0.0/24
Generating new SSH host key file.....done.
Current time and date: [031316082017.42] 032116532017.50
Tue Mar 21 16:53:50 GMT 2017
NTP server IP address: [done] 10.10.20.42
init: sysinit main process (4023) killed by TERM signal
Error opening /base/mnt/huge: No such file or directory
717: Cannot stop /base
Sending all processes the TERM signal...
Sending all processes the KILL signal...
Syncing hardware clock to system time
Unmounting loopback filesystems
Unmounting remaining filesystems
Remounting remaining filesystems readonly
Please stand by while rebooting the system...
[ 1021.507463] reboot: Restarting system
Press any key to continue.
GNU GRUB version 0.97 (639K lower / 2882536K upper memory)
Use the ^ and v keys to select which entry is highlighted.
Press enter to boot the selected OS, 'e' to edit the
commands before booting, 'a' to modify the kernel arguments
.........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................*****.*************Superblock last write time (Tue Mar 21 16:57:21 2017,
now = Mon Mar 13 16:12:04 2017) is in the future.
Fix? yes
boot: clean, 64/128016 files, 156038/510976 blocks
..******.*****002: Scanning for filesystems
003: Using system disk
004: Checking file system integrity
Superblock last write time (Tue Mar 21 16:57:28 2017,
now = Mon Mar 13 16:12:15 2017) is in the future.
Fix? yes
system: clean, 33702/512064 files, 210306/2048000 blocks
now = Mon Mar 13 16:12:17 2017) is in the future.
Fix? yes
data: clean, 1098/407360 files, 64053/3107840 blocks
Arbor TMS/8.1.0 (ARBOR)
ARBOR login: admin
Password:
Arbor TMS v8.1.0
Copyright (c) 2000-2016 Arbor Networks, Inc. All Rights Reserved.
Welcome to ArbOS
admin@ARBOR:/#
Jerry Ebanks
Hi Lemmocisco:
Thanks. This is what i needed to know. Just want to be sure because the router (ASR9k) which we are installing the VSM card is a production router and I didn't want to disrupt services.
Thank you for the feedback.
Jerry Ebanks
Whenever I try to break the process for VSM I use ctrl +e but I notice sometimes it does not break it. what exactly is the break sequence. What does this mean Escape sequence is '^^e'.
haitham.jneid
Hi All,
I need to understand the solution regarding arbor deployment on VSM card in ASR9000. how the solution works? what happens exactly?. is there any document that describe the solution?
thanks,
Haitham Jneid
Nitin Pabbi
Hey Haiham,
Peakflow TMS (Threat Management System) on VSM-500 (Cisco CGN card) is used for Arbor’s Peakflow TMS and ArbOS x86_64bit software running on a Cisco Virtualized Services Module (“VSM blade”) for Cisco’s ASR 9000 series routers. Each ASR 9000 chassis can support one Peakflow TMS-VSM.
This solution addresses ISPs, cloud providers and enterprises customers common concerns of DDoS (Distributed Denial of Service) attacks which impacts customers operations and reduce network availability.
Peakflow TMS network SW provide an important traffic-scrubbing component of the Peakflow solution. The Peakflow TMS can be deployed inline to provide “always on” protection and also supports a mitigation architecture called “diversion/reinjection.” In this mode only the traffic stream carrying the DDoS attack is redirected to the Peakflow TMS through routing updates issued by the Peakflow solution. The Peakflow Threat
Management System removes only the malicious traffic from that stream and forwards
the legitimate traffic to its intended destination.
We have published a CCO doc explaining this solution details:-
http://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/solution-overview-c22-736143.html
At the bottom of this link you will find links for whitepaper and solution information.
Kindly go through from these and share your feedback. Accordingly we will add/modify the content for better understanding of this solution.
Nitin Pabbi
haitham.jneid
Hi Nitin,
thanks for the great information you provided. it was very useful for me.
the design I am trying to work on is as the following:
- 1xASR9006
- 1xVSM Module
- Peakflow SP on Cisco UCS.
As per Cisco documentation the requirements will be as the below:
Hardware:
   Fixed and modular Ethernet line cards (second-generation and later)
   Route Switch Processor 440 (RSP440) or Route Switch Processor 880 (RSP880)
   Cisco ASR 9000 Series Route Processor 1 (RP1) or Route Processor 2 (RP2) for Cisco ASR 9912 and ASR 9922 systems
   Virtualized Services Module (VSM)
Software:
   Cisco IOS® XR Software Release 5.3.0 and later
   Arbor TMS Version 7.0.1 and later
I need resources about the following if possible:
- Installation/Configuration of VSM inside ASR9000
- Pair VSM TMS with Peakflow SP
- Netflow/BGP configuration on TMS,ASR and Peakflow SP
- TMS policies/rules configuration guide
- Install/activate licenses
Appreciate your valuable support.
thanks,
Haitham Jneid
