Nitin Pabbi
Symptoms
 When VSM services part fails, the failure will not propagate to ABF, which will result in black holing of the traffic instead of switching the traffic to backup VSM, if one exists
Solution
To track the reach-ability between Ingress service App interface and Egress traffic port using IPSLA and trigger the ABF when this reach-ability breaks.
Details
Consider a router with VSM and CGN services running on both of them. We have applied an ABF on Ingress port with first next hop pointing to Ingress service App in VSM1 and second next hop pointing to Ingress service App in VSM 2. At any instance, when next hop 1 becomes unreachable, the ABF will start diverting the traffic to service App in VSM2. Hence black holing of traffic will be avoided.
   Each VSM has service and Infra part. There are situations where a service part of the VSM will not get propagated to infra part of VSM, which results in ABF been not notified of the next hop failure. So ABF will not switch the traffic to next hop, instead will continue to forward traffic to VSM1 which will result in traffic dropped as service part is no longer in running state to process the traffic.
   To mitigate this scenario, one of the approach it to implement IPSLA which will track the path from Ingress service App to Egress traffic port. IPSLA used ICMP to track the path. If any failure happens in service part, this path will break and IP reachability goes down. Hence when service part of VSM fails, the IPSLA catches the failure. The failure will be propagated to ABF from then on and action will be taken accordingly which will be switchover of traffic from nexthop1 to next hop 2. Even after the failure, the IPSLA continues to track the path and once it comes back again, ABF will switch traffic back to nexthop1. Thus the traffic black holing due to services part failure is mitigated.
   Following figures give a clear explanation on packet flow when VSM1 is active and when VSM1 fails. Also it gives explanation where the IPSLA is triggered. After these figures, the configuration examples are provided, which will help in implementing the solution without any hick ups.
  This solution is verified on ASR9K routers with VSM running CGN services. We need to define one IPSLA track per VSM card using any one service App. The same can be used for tracking all ABFs associated with that card
Note: Please refer to following cisco support forum page for detailed explanation on CGN on VSM with HA scenarios.
https://community.cisco.com/t5/xr-os-and-platforms/ism-100-to-vsm-500-migration-and-redundancy-managment-guide-with/m-p/2876457
 IPSLA Tracking Enabled between service Ingress Port and Egress Traffic Port:
  1. IPSLA is run between Ingress service App port of VSM1 and egress traffic port.
  2. IPSLA used ICMP for tracking
  3. On failure ABF will be notified, which results in traffic switchover according to the ABF rule defined
Traffic Path When VSM 1 is Active:
  1. Traffic enters Ingress traffic port.
  2. Then based on ABF applied on Ingress traffic port, which has next hop IP as Ingress Service App IP, also based on IPSLA which doesn’t report any failure, traffic enters service App 1 in VSM1.
  3. Then traffic passes to Egress service App on VSM1 along with NAT been applied.
  4. Then traffic exits out of Egress traffic port based on Routing information available.
Example configuration:
Ingress traffic port configuration:
RP/0/RSP0/CPU0:Hulk#sh running-config interface bundle-ether 400.101
interface Bundle-Ether400.101
 ipv4 address 10.22.231.2 255.255.255.252
 encapsulation dot1q 101
 ipv4 access-group VNAT1_ABF ingress
Egress traffic port configuration:
interface TenGigE0/3/0/4
 ipv4 address 22.1.1.1 255.255.255.0
Ingress service App configuration:
RP/0/RSP0/CPU0:Hulk#sh running-config interface serviceApp 1
interface ServiceApp1
 vrf SVSM-1
 ipv4 address 10.22.241.14 255.255.255.252
 load-interval 30
 service cgn VSM-1 service-type nat44
VRF configuration for ingress service App:
RP/0/RSP0/CPU0:Hulk#sh running-config vrf SVSM-1
vrf SVSM-1
 description <<inside vrf1 on VSM-1>>
 address-family ipv4 unicast
  import route-target
   20:1
  export route-target
   20:1
Static route to Traffic Egress port under Ingress next Hop:
RP/0/RSP0/CPU0:Hulk#sh running-config router static vrf SVSM-1
router static
 vrf SVSM-1
   10.1.1.0/24 vrf default 10.22.231.1
   22.1.1.1/32 ServiceApp1
IPSLA Configuration:
RP/0/RSP0/CPU0:Hulk#sh running-config ipsla
ipsla
 operation 1000
  type icmp echo
   vrf SVSM-1
   source address 10.22.241.14
   destination address 22.1.1.1
   timeout 2000
   frequency 5
reaction operation 1000
  react timeout
   action logging
schedule operation 1000
  start-time now
  life forever
Track configuration:
RP/0/RSP0/CPU0:Hulk#sh running-config track
track TSA1
 type rtr 1000 reachability
 delay up 5
 delay down 5
ABF configuration (ABF is attached to ingress traffic port):
RP/0/RSP0/CPU0:Hulk#sh running-config ipv4 access-list VNAT1_ABF
 10 permit ipv4 10.1.1.0/24 any nexthop1 track TSA1 vrf SVSM-1 ipv4 10.22.241.13 nexthop2 vrf SVSM-33 ipv4 10.22.241.141
 20 permit ipv4 10.1.2.0/24 any nexthop1 track TSA1 vrf SVSM-3 ipv4 10.22.241.21 nexthop2 vrf SVSM-35 ipv4 10.22.241.149
 30 permit ipv4 10.1.3.0/24 any nexthop1 track TSA1 vrf SVSM-5 ipv4 10.22.241.29 nexthop2 vrf SVSM-37 ipv4 10.22.241.157
 40 permit ipv4 10.1.4.0/24 any nexthop1 track TSA1 vrf SVSM-7 ipv4 10.22.241.37 nexthop2 vrf SVSM-39 ipv4 10.22.241.165
 50 permit ipv4 10.1.5.0/24 any nexthop1 track TSA1 vrf SVSM-9 ipv4 10.22.241.45 nexthop2 vrf SVSM-41 ipv4 10.22.241.173
 60 permit ipv4 10.1.6.0/24 any nexthop1 track TSA1 vrf SVSM-11 ipv4 10.22.241.53 nexthop2 vrf SVSM-43 ipv4 10.22.241.181
 70 permit ipv4 10.1.7.0/24 any nexthop1 track TSA1 vrf SVSM-13 ipv4 10.22.241.61 nexthop2 vrf SVSM-45 ipv4 10.22.241.189
 80 permit ipv4 10.1.8.0/24 any nexthop1 track TSA1 vrf SVSM-15 ipv4 10.22.241.69 nexthop2 vrf SVSM-47 ipv4 10.22.241.197
 1000 permit ipv4 any any
IPSLA statistics:
RP/0/RSP0/CPU0:Hulk#sh ipsla statistics
Entry number: 1000
    Modification time: 16:15:15.275 IST Fri May 20 2016
    Start time       : 16:15:15.276 IST Fri May 20 2016
    Number of operations attempted: 18435
    Number of operations skipped  : 0
    Current seconds left in Life  : Forever
    Operational state of entry    : Active
    Operational frequency(seconds): 5
    Connection loss occurred      : FALSE
    Timeout occurred              : FALSE
    Latest RTT (milliseconds)     : 47
    Latest operation start time   : 17:51:25.481 IST Sat May 21 2016
    Next operation start time     : 17:51:30.481 IST Sat May 21 2016
    Latest operation return code  : OK
    RTT Values:
      RTTAvg  : 47         RTTMin: 47         RTTMax : 47
      NumOfRTT: 1          RTTSum: 47         RTTSum2: 2209
Results :
VSM HA will induce 15sec of delay while convergence if CGN APP fails.
IPSLA solution can help us reduce the SWO time considering IPSLA probes tracking.
Note: Probe timers should not be less than 10 to avoid building stress conditions.
antonio.kucar
Hello Nitin,
Excellent article about active-active VSM mode.
It reminds me on my setup of VSM solution.
1. Per your config, is it enough to SLA tracking only one ServiceApp1 on VSM module?
There is no need to track ServiceApp1, ServiceApp3, ServiceApp5... because they are all on the same VSM module?
So there is no need to send SLA traffic inbound to inside physical interface Bundle-Ether400.101 to get NATed?
It can be just sourced from ServiceApp interface, no need for a traffic to right enter a ServiceApp through an inside physical interface?
2. In your setup you have only one uplink interface TenGigE0/3/0/4 (to the Internet).
If we have a multihoming, then this SLA tracking of only one uplink is maybe not accurate because if this particular uplink will go down then there is a ABF switchover and that is actually not necessary because other uplinks will work.
Is there a valid solution if a SLA tracking is toward a Loopback interface in global routing table?
3. I found a command o2i-vrf-override, is this a valid solution instead of a route leaking?
In your config ServiceApp1 is in vrf SVSM-1 and inside physical port Bundle-Ether400.101 is in global routing table.
Would that command help here so you don't have a following static route in your config?
router static
 vrf SVSM-1
I appreciate your answers.
Best regards,
Antonio
