Web shows different Outputs than CVRF and OVAL
klohse
i am using the CVRF and OVAL downloads in XML format. I saw that for example CVE-2016-6379 (cisco-sa-20160928-ipdr) shows more information when opened in HTML than in the CVRF and OVAL files, for example the affected products section is completely missing in the files. Also the list of affected IOS versions is different in the Bugtool and the CVRF and OVAL files. There are no fixed versions in the files.
Is there a reason for that, am i doing something wrong ?
kind regards,
Kai Lohse
Omar Santos
Hi !
Yes indeed. The CVRF files will not include all fields in the advisory. For example, the affected product section will not be in the CVRF file. For your reference, this is a representation of the fields that CVRF currently supports:
Regarding the comment about version information. For IOS and IOS-XE the authoritative sources of version information are the OVAL definitions and IOS Software Checker.  For the rest of the advisories, unfortunately there's no support for tools and functionality like OVAL or Software checkers for other products. The human-readable advisory is the most up-to-date document for versions.
