Today we have multiple applications that run directly on the Smart Storage devices and can be installed via in the simple PKG process. These are wide ranging applications that help with asset management, content management, e-commerce, web publishing (bulletin boards, wikis, etc), & e-learning systems.
Beyond what is is available now, what applications would you like to see? We'd love to hear what you'd like to see.
Applications Available Now (version numbers)
To Download Add-on PKG Applications:
Release Notes for all the available for all applications
Support for free add-on PKG applications is through online community forums.
Something like rtorrent or some other remote enable bittorrent client.
The python package helps a lot in this regards, but not complete there.
And really the web applications are nice, but a determined developer can get those on, it's the base things (python/ruby/etc) that really extend the usefulness of this device, at least in my opinion.
Eric,
Thanks. The first group of applications are definitely focused more on end users than developers. Just to show off the platform potential. We'll working on more developer focused applications. This sort of feedback helps us prioritize between the two types of users.
SFTP server with GUI supporting multiple users
TFTP server with GUI supporting multiple users
SMTP server
SYSLOG server
App that supports scheduled downloads from Cisco software centre
App to replicate content between Smart Storage devices on a scheduled basis
James,
Great feedback.
Are there any specific SMTP server features/functions that you would require? Or just having the general fucntionality as an add-on application is good enough?
There is already a SYSLOG server built into the base software for Cisco Smart Storage.
WIthin your administration GUI you can find the Syslog server in Applications > Syslog Server
You can enable/disable the server, setup log settings, email notifications, filters, and of course view the log
Remote Replication between Cisco Smart Storage devices is also already built into the software.
WIthin the administration GUI, go to Backup > Remote Replication
You can setup replication between two devices on a scheduled basis directly from the GUI.
Dropbox Client
uTorrent (or similiar with ability to monitor folders for .torrent file)
TwonkyServer
Embedded Cisco Camera software
Support for more than just Mozy (Intronis, Egnyte, S3, for cloud storage)
Ben,
Thanks for the input.
Specifically for twonkyserver, it seems to work pretty well, but the transcoding part of it doesn't seem to work, at least in my configuration? Maybe I'm doing something wrong, if it doesn't right now, that'd be a nice feature to have.
Eric,
Appreciate for the follow-up. Transcoding isn't supported in the OEM/Basic license included. I'll look into this for the future.
Thanks.
This is really wishful, but why don't you guys just buy QNAP??
I mean look at this list - http://www.qnap.com/pro_detail_feature.asp?p_id=182
+1 for Dropbox
+1 for Cisco small biz Camera software
I would like a nice pkg for:
1. Subversion
2. Bugzilla (or another issue tracking system)
Sean,
Both of those are straightfoward requests.
Hi Doishi,
There are some updates on the twonky media server which I'm looking for, in twonkyserver6.0.30.
http://www.twonkyforum.com/downloads/6.0.30/ seems to list some files. Could you please help with the correct
file and how to do the upgrade(a guide if available) on my NSS 324? QNAP is giving update via .qpkg file @
http://www.twonkyforum.com/viewtopic.php?f=2&t=8913
When the package is available for download from twonky website, from a user perspective it doesnt feel good if I'm not able to update my system. Hope Cisco documentation for this product will be updated soon with all these details, like for other products.
Sijin
I just bought an NSS 326 after having used QNAP, Thecus and Synology NASses in the last couple of years.
What bothers me is that no NAS has an Active Directory implementation.
I don't mean that the NAS becomes a member of AD but the NAS itself can have the role as a Active Directory Master.
So for me that would be an interesting Add-On package for the NSS 3xx Series.
At least that is on my wishlist.
Klaasdj
