Get the latest Cisco news in this December issue of the Cisco Small Business Monthly Newsletter
3453
Highlighted
Beginner
Concurrent users unable to open a shared Microsoft Access MDB database
I have a share on a Cisco NSS2000, the NSS is in Workgroup mode (Firmware 1.13).
Every user have read/write rights on this share.
When I try to open an access MDB database from this share it happens that only a single user at time can open the database.
The second user that try to open the database get a "Cannot lock file" error message.
So, when a user has the Access DB opened, no-one other can open (or connect to) the same DB.
It's impossible to open the DB using the access IDE ("Cannot lock file" error message).
It's impossible to make multiple connection to the DB using OleDB ("Cannot lock file" error message).
I've tried give full access to the mdb file.
I've tried give full access to the mdb folder.
I've even tried to give full access to the temporary LDB file.
I always get the same error message.
Is there a workaround?
Thanks, Max
Everyone's tags (4)
4 REPLIES 4
Highlighted
Beginner
Re: Concurrent users unable to open a shared Microsoft Access MD
Max,
Please update your firmware to the latest posted version, 1.16.
-carl
Carl Tung
SBTG - PE, Storage
Reply-To: "cisco-marketing@sgaur.hosted.jivesoftware.com"
Date: Wed, 07 Apr 2010 00:07:20 -0600
To: Carl Tung
Subject: New message: "Concurrent users
unable to open a shared Microsoft Access MDB database"
catung,
A new message was posted in the thread "Concurrent users unable to open a
shared Microsoft Access MDB database":
https://www.myciscocommunity.com/message/42739#42739
Author : IsiSviluppo
Profile : https://www.myciscocommunity.com/people/IsiSviluppo
Message:
Highlighted
Beginner
Will I loose my data due to the firmware update?
Thanks, Max
catung wrote:
Max,
-carl
Carl Tung
SBTG - PE, Storage
Highlighted
Beginner
Max,
No, you shouldn't. However, if the NAS is your primary data store, it's
always a good practice to back up data and configuration regularly, and
especially just before a firmware upgrade to guarantee business continuity.
This is the same advice I get regarding any server product, and even my PC
and Mac regarding an upgrade.
-carl
Date: Thu, 08 Apr 2010 00:09:09 -0600
To: Carl Tung
Subject: New message: "Re: Concurrent users
catung,
https://www.myciscocommunity.com/message/42925#42925
Message:
Highlighted
Beginner
I've finally been able to update the firmware to the latest 1.16.
Now everything works fine, problem solved! :)
Max
catung wrote:
Max,
-carl
Carl Tung
SBTG - PE, Storage
<cisco-marketing@sgaur.hosted.jivesoftware.com>
To: Carl Tung <catung@cisco.com>
Subject: Small Business Network Storage New message: "Concurrent users
unable to open a shared Microsoft Access MDB database" YbIMb-16E-b7l
catung,
Message:
