2622
Highlighted
Beginner
>> NSS-322, new drive #2 not available
NS322, latest firmware.
Original second drive was replaced due to 800+ bad sectors.
The drives were set as a Stripe RAID.
Replaced with a similar 'WD' one, but larger (3TB not 2TB).  AFter reinserting the new drive, it does
not show in the Smart Storage manager.
Any thoughts?  Anything special I should have done?
Thank you,
Robert
2 REPLIES 2
Highlighted
Rising star
Highlighted
Well I was fianlly able to get back to checking the NSS322 on Friday...
The new harddrive I purchased is newer then the Approved List, so I replaced that with
the original drive #2 that had the bad blocks.
I check the NSS an hour after turning it on, the second drive (now back to the original)
still is not showing.  When I click on Drive #2 to see it properties, etc. (from the web
dashboard), I get kicked out of the web dashboard.
I reset the NSS back to factory settings, thinking it might reformat the drives, no go.
Drive #2 still not showing.
Any Ideas?
Thank you,
Robert
