1666
Highlighted
Beginner
NSS3000: unable to access web page
After changing the IP-address and subnet mask of my Cisco NSS3000 I'm unable to access web configuration page. Filesharing via CIFS works fine. Please help.
2 REPLIES 2
Highlighted
Beginner
Are you getting an error when trying to reach the web configuration page on the device?  Is your computer on the same subnet as the new IP address on the NSS?  I would try setting an IP address statically on the PC and connecting directly to the NSS3000 to see if you can reach it that way.
Jason Nicle
Highlighted
Thank you for reply! Below is my answers to you and solution of the problem.
No, I was getting nothing! Like there is no web configuration page binded to new IP address.
Yes! Otherwise I could not connect to NSS via NetBIOS.
The IP address on my PC was set statically.
I had solved my problem by resetting the network setting of NSS3000 and set them again. Seems that there is a bug in latest firmware, because I have two NSS3000 and they both was not reachable through web-interface after changing their IP addresses and subnet masks.
