2932
Highlighted
Beginner
NSS6000 and WD 1TB hdd
Hello we have problem with NSS6000 FW 1.14 and WD 1TB WD1000FYPS GP 16MB SATAII/ 300 7200 RE2.
If i copy something to NSS i have throughput about 12MB/s but between two computer i have throughput 70-80 MB/s, in core i have gigabit switch.
Thank you
Tomas
5 REPLIES 5
Highlighted
Participant
This is really due to the Windows CIFs environment.  Windows to Windows PC is the fastest.  Our performance is actually very good compared to our competition.  All non-Windows based devices such as a linux based NAS will see the same type of issues.
You can see a third party performance report at www.tolly.com   Search for NSS6100.  This will compare our performance versus our two major competitors.  Report is attached as well.
Highlighted
Thank you.
regards
Tomas
Highlighted
From your document i read throughput about 30-60Mbps but end user have in RAID5 throughput 12Mbps.
Thanx
Tomas
Highlighted
The Tolly report is really just a comparison.  You need to run the same HW configuration and setup against all cases to be fair.  It's not an absolute value. That is why the HW test setup and test commands are provided in the Tolly report.
Highlighted
Hi Thomas,
There's several factors that can limit the throughput, always depending the devices involved.
One of the limitations can be the OS that is used. In our lab we got almost the 40 MB using MAC OSX 10.5
- jms
