Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
980
Highlighted
NSS6000 - Can't configure backup
Hi all
I've problems to configure the integrated backup function on my NSS6000. I want to backup my data from my NSS6000 to one of my filers. Here I've tried to configure the internal backup function on the NSS but I get everytime the error "An error occured communicating with remote share. Verify connectivity and login parameters".
All settings are correct on my filer, its a Win 2003 Server. Do anyone have an idea what I'm doing wrong.
My NSS has the latest firmware, 1.16.
Thanks and regards
Alex
3 REPLIES 3
Highlighted
Beginner
Re: NSS6000 - Can't configure backup
If you have a firewall running on the server disable it and try again.   Also some Antivirus software now has firewalls built in so unload it  next.  Have you check DNS?  Try communication with the server by IP  address, next I would make sure that the filer has RPC running in  windows services.  Can you connect from your workstations to the win  2003 server share?  Just some basics I thought I would throw out there
Highlighted
Hi Goeff
Thanks for your reply.
I already checked all settings. A firewall isnt running, DNS is also fine and I'm able to access the share from my clients. Thats strange.
Any further ideas?
Highlighted
Frequent Contributor
Alexander,
I have looked into this and couldn't replicate the same error, right user permission on my file server and had no trouble setting backups.
My Lab Microsoft Server 03 is member server to 08 server. Set up 03 as file server and tried to replicate the issue.
Server 03 is running minimum configuration and no firewall no anti-virus.
I would try giving Everyone read,write,and full access to that one share/target and just see if you can run the backup from NSS6000. Also can you display some of the logs NSS6000. I tired denying access, allowing full access, user access and still couldn't get same error as you.
This seem something speicfic to your Small Business Server
could be polices
permissions
anti-virus
firewall/programs
Jason Bryant
Cisco Small Business Support Engineer.
