1392
Highlighted
Beginner
192.168.0.x
I am replacing a Cisco 1811 router with an RV-325.  The 1811 used 192.168.0.x as the secure default and 192.168.1.x as the open wifi.  I have not been able to get the RV-325 to default to 192.168.0.x.  I have added a 192.168.5.0 for the open wifi but will have to change several static IP printers if I have to change to the 192.168.1.x network as the default.  Sorry if my ignorance is showing.  The GUI interface is great but this is the first time I am using it.  Kind of like going from DOS to Windows, its good once you know your way around.    Thanks,  Dan
1 ACCEPTED SOLUTION
Highlighted
you add VLANs to the router and assign the VLANs to ports ( tagged or untagged etc. )
You also decide which VLAN have management interface access and which VLANs can see each other. I.e. for guest networks inter vlan routing should be off.
Then you assign under DHCP settings the subnets for each VLAN. For the default VLAN  change the device ip address from 192.168.1.1 to 192.168.0.1. The 192.168.1x subnet is gone.
3 REPLIES 3
Highlighted
VIP Expert
Not sure if i understand correctly, you can change the internal IP address how ever you like, there is no Limiation in see here.
here is the quick setup guide :
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv320/administration/guide/en/Updated/rv32x_ag_en.pdf
BB
*** Rate All Helpful Responses ***
Highlighted
Highlighted
Thank you.  Finding the default IP under DHCP was my issue.  Sorry, it’s obvious to those that have used the GUI interface before but I had not.  It would be helpful if the default IP was part of the easy start up questions.  I have a few other questions but I will post them separately,  thanks again, Dan
