02-26-2015 04:18 PM
Just hoping someone can tell me which 4G USB modems are/aren't compatible with the Cisco RV215W? I am told by a customer that an MF823 modem (Telstra) is not working and is not compatible.
Solved! Go to Solution.
03-01-2015 02:28 PM
Yes, there are some options/sources where to find updated list supported modems:
02-27-2015 03:40 PM
Hello
please have a look here on RV215W compatible 3G/4G modems. Yes, you're right, your MF823 is not on that list.
03-01-2015 01:32 PM
Thanks Michal, I appreciate your reference to that compatibility list - most helpful.
I do note that the list is 2 years old now, so any modems released to market in the last two years would not be on the list - whether they work or not. I believe the MF823 falls in this category, so I am still not entirely sure if the MF823 'should' work with the RV215W.
Do you know if there is a more recent updated list? How else could I find out if modern modems are compatible?
Cheers,
03-01-2015 02:28 PM
03-01-2015 02:28 PM
One more important note about USB dongles for Cisco RV routers:
03-02-2015 10:10 PM
Thanks Michal, your comprehensive information is most helpful.
