05-28-2019 10:36 PM
Hi all,
I'm doing research in updating our list of routers for our customers. For a while we have mostly used C881 and C887-VAM routers however now in Australia services are starting to increase from 100Mbit we're now exploring 890 and 1100 series routers. Unfortunately from my research online I can't find any concrete difference other then IOS-XE which the 1100 series use. Interface wise they are very similar from the two series and i can get prices roughly the same between to the two series.
Any suggestions or help will be much appreciated.
05-28-2019 11:44 PM
05-28-2019 11:50 PM
05-29-2019 04:11 PM
I've seen this page, unfortunately it doesn't tell you why one is better then the other, other than the 1111 uses IOS-XE.
05-29-2019 06:38 PM
05-29-2019 09:37 PM
Hi Leo Laohoo,
I think you're talking as if the router will be running concurrent services as in everything the router can do at the same time. I understand the throughput of the 1100 series router is default 50Mbit and can be upgraded as high as 350Mbps with the performance license but the routers we deploy are simply just doing NAT and a few security ACL's thats it. I just found this interesting document which does a good description on all models.
https://www.cisco.com/c/dam/m/en_sg/cisco-start/assets/pdfs/cisco-start-catalog.pdf
