03-12-2011 04:49 AM
I have trying to update the firmware of SA520-K9, after the firmware update, the router diag led still lit, unable to do a reset factory using reset factory.
Do you know if it 's possible to reset the SA520 using usb port or do a reset factory when the button reset do nothing ?
Regards.
03-15-2011 11:03 AM
Hi Sebastien,
To perform a factory reset, please press and hold down the Reset button on the side of your SA520 for at least 10 seconds. After 3 - 5 minutes, the SA should be reverted to a factory default. In your state, wait over five minutes. If the DIAG light still has not turned off after this, please perform this procedure a couple more times.
If after this the SA520 still is in state with DIAG LED on, then I advise you to try to get RMA process started.
A quick question from me to you is what was the initial firmware you upgraded from, and to which firmware image did you upgrade to?
Hope this helps.
Cheers,
Julio
03-15-2011 11:12 AM
Yes, if you uploaded to latest firmware 2.1.18 please let SA500 seat for
8 to 12 minutes after powering on and the diag light should go off. you
might see the LAN light go off as well, but this is normal behavior . Once
the lan light comes back on you should be able to access the unit.
Jason Bryant
Cisco Support Engineer
03-15-2011 11:34 AM
Hi all,
I have wait more than 30 minutes and the diag led still fit. The reset factory does not work anymore.
Cisco has processed an RMA for this one today.
Sébastien DOS-SANTOS
09-02-2023 06:01 PM
Hi were can o download firmware?
