07-11-2012 01:48 PM
Good afternoon friends...
I have RV042 Router, I'm using only one Internet conection, I'm using IP group like this 192.168.95.x, my DHCP setting use 192.168.95.120 to 192.168.95.240, but in this time I have 245 workstations (may be I will have 25 additionals workstations) and some times I see IP conflict message in my current workstations.
I had read about SUBNET like response about my problem, but I'm not sure about that and how to make subnet with my RV042.
Can you give me a idea about that...?
Thank you very much.
Rafael.
Solved! Go to Solution.
07-11-2012 02:21 PM
Rafael, you can use any subnet you'd like such as 192.168.94.1 subnet mask 255.255.255.0.
07-11-2012 01:58 PM
Rafael, hello.
You can navigate to setup -> network
Below is a checkbox to enable multiple subnet then you click add/edit
Add the desired subnet.
07-11-2012 02:07 PM
Hello dear Thomas... Thank you for your reply...
I had using 192.168.95.1 to 192.168.95.254, which should be the other IP range ? subnet mask ?
Thank you for your cooperation...
Rafael.
07-11-2012 02:21 PM
07-11-2012 02:37 PM
Thank you Mr. Thomas...!
07-11-2012 03:13 PM
Mr. Thomas, sorry for the inconvenience...
I'm making test, with my new subnet (192.168.94.1; subnet mask 255.255.255.0) my workstations inside from new subnet has internet, mail, local system, etc... but I can't browse shared folder in workstation placed in subnet... and I can't shared folder from workstation placed in subnet to workstation placed in principal net)
I had set in local connection adapter (workstation placed in new subnet):
IP Address: 192.168.94.3
Subnet mask: 255.255.255.0
Default gateway: 192.168.94.1 (I made test with 192.168.95.1, but I get same problem)
Thanks for your patience...
Rafael
07-11-2012 03:29 PM
Rafael, this sounds like a Firewall issue on the resources you're accessing.
07-11-2012 04:31 PM
Mr. Thomas, when I set old setting in local conection adapter everything is working very well. I had disable firewall in every workstation, but the problem always persists.
PD: Ping command is working fine between subnet workstations and principal net workstations...
Thank you...
