Advanced Routing Configuration on RV320 and RV325 VPN Routers
savvy2
Home use. (cable Wan modem x16 chan. ARRIS,SB6183)
to my new rv320 , newest firmware.   wan1 only usage, wan2, NC. Gateway mode.
I replaced a old  d_link, dir933 has krack-WPA, and maker says too old to suport so (parked it)
enter rv320,  no problems I do love it is a solid router, for many months, amazing actually.
my issue is getting my 3 ipwebcams (foscams) back on line, that is from the web to the cams.
All 3 are on wired gigalan switches and all work great locally
eg: 10.10.1.110:4444  (set up as fixed (reserved IP on the sub lan , at cam end and 320 side.)
the I have (for years) the noip.com account that sets up my real IP to  name, say
cam1.ddns.net:4444  (cam1 is not true im hiding real name here but ddns.net is real and works)
if i do full online IP scans for ports,  all ports are dead. but 4444. (shows open port, but no camera page) but in the stead.
but to my horror!
if Get not my camera page but the cisco log in page, (https, or http accessed) ouch
why?
I'm sure im doing it wrong, so dont hold back there... lol
I will never use vpn, and is off.
what confuses me is this.
I have block wan requests enabled. and...
examples below , snap shots.
why does 192.xxx.xxx do,  can I delete this, ive no need for vlan. or vpn.
when I browse my private web domain, it shows the CISCO login page no mater what I do.
with our with port address on the end,  cam1.ddns.net
please help me... thanks
Thank you Rosica , for your help and support.!!
I deleted those 2  x  192.168.x.x addresses ,
REDUX 1
here is how i fixed this,
i put pico sized, mineweb.exe program on my pc, and its at 10.10.1.100:8000
set all firewalls to this and fails (wan to lan) lan ok.
now i go  to CISCO RV.
I disable the fire wall (check box)
bam all works great.
so what is wrong, i then go into Firewall Access rules and set RESTORE default RULES.
I enable fire wall in RV, and it still works. all does.
the lesson is, my PAT was in a war with Access rules.
just this and not any thing else makes it work.  works 3 ways, lan, lan to web and back, and on CELL.
thanks, now only https access is needed. to cams.
Rosica Sareva
Hello savvy2,
Regarding the VLANs 25 and 100, that are with the 192.168.x.x addresses - yes, you can delete them if you are not going to use them. If you decide you need some more VLANs in future - you can add them again, no problem.
On your other questions - when you have the Block WAN Request enabled, like it is by default - this option will only prevent you or anyone else to ping your RV320's public IP from the outside.
REDUX 1
