806
Highlighted
Participant
ap fails to join WLC [dtls_disconnect: ERROR shutting down]
Hi.
WLC : 5508
AP : 2802
Ping is no problem.
WLC time is my current time.
The time between WLC and AP seems to be different, but does it matter?
I will attach AP and WLC logs.
What is the problem ??
-AP LOG-
May 9 04:49:16 kernel: [*05/09/2020 04:49:16.0551] CAPWAP State: Discovery
May 9 04:49:16 kernel: [*05/09/2020 04:49:16.0574] Discovery Request sent to 172.20.201.9, discovery type STATIC_CONFIG(1)
May 9 04:49:16 kernel: [*05/09/2020 04:49:16.0595] Discovery Request sent to 172.20.201.9, discovery type STATIC_CONFIG(1)
May 9 04:49:16 kernel: [*05/09/2020 04:49:16.0612] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
May 9 04:49:16 kernel: [*05/09/2020 04:49:16.0619] Discovery Response from 172.20.201.9
May 9 04:49:16 kernel: [*05/09/2020 04:49:16.0705] Discovery Response from 172.20.201.9
May 9 04:49:26 kernel: [*05/09/2020 04:49:26.0000]
May 9 04:49:26 kernel: [*05/09/2020 04:49:26.0000] CAPWAP State: DTLS Setup
May 9 04:50:23 kernel: [*05/09/2020 04:50:23.0133] dtls_disconnect: ERROR shutting down dtls connection ...
2 ACCEPTED SOLUTIONS
Highlighted
Hall of Fame Community Legend
AP Running Image     : 8.3.150.0
Primary Boot Image   : 8.3.150.0
Backup Boot Image    : 8.3.143.0
Ok, so this AP has joined a controller in the past.
Do this command on the AP:
capwap ap erase all
See if this works.
Highlighted
Hi.
There was NAC appliance on site.
We allowed AP IP and everything is normal.
Thanks for your interest in my question.
12 REPLIES 12
Highlighted
May  9 04:56:26 kernel: [*05/09/2020 04:56:26.6105] CAPWAP State: Discovery
May  9 04:56:26 kernel: [*05/09/2020 04:56:26.6162] Discovery Request sent to 172.20.201.9, discovery type STATIC_CONFIG(1)
May  9 04:56:26 kernel: [*05/09/2020 04:56:26.6176] Discovery Request sent to 172.20.201.9, discovery type STATIC_CONFIG(1)
May  9 04:56:26 kernel: [*05/09/2020 04:56:26.6196] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
Check firewall.
Logs in the AP shows the AP sending out join request to the controller, however, there is no response from the WLC.
Highlighted
Thank you for answer.
But it doesn't go through the firewall.
Highlighted
Can the AP ping the WLC IP address?
Post the complete output to the following WLC command:
show ap join stats detailed <AP NAME>
NOTE:   Put the output in a TEXT file (instead of an XLS).
Highlighted
WLC and AP can be ping.
The APs is not joined to the WLC, so cannot perform the command you request.
Highlighted
I don't care.
Enter the command in the WLC and post the complete output.
Highlighted
(Cisco Controller) >show ap join stats detailed C4B2.39F7.2A02
No join information found for AP: c4:b2:39:f7:2a:02
Highlighted
Good.
This means something is blocking the AP's Join Request from reaching the controller.
What happens if the AP and the WLC in the same VLAN?
Highlighted
WLC and AP are not the same vlan.
However, other APs that were installed in the past are already joined to WLC.
However, only two APs installed today are not joining.
One good news is that one of the two unjoined APs succeeded in joining.
One does not know why the join succeeded.
Highlighted
capwap ap erase all
See if this works.
Highlighted
Hi.
Highlighted
The remaining APs that failed to join were also joined.
Since the discovery was repeated with 200.9 and 201.9, it was joined after AP Reset.
Cause not found T_T
Highlighted
Beginner
