Get the latest Cisco news in this February issue of the Cisco Small Business Monthly Newsletter
231
Highlighted
Beginner
ASR1004 Hw design
All ,
I have requirement , would be great if you can share your experience and knowledge
Requirement 1
1 x   Cisco ASR 1004 40Gig
4 x   SPA-10X1GE-V2 (10 port Ethernet Module)
Requirement 2
3 x   SPA-10X1GE-V2 (10 port Ethernet Module)
1 x   SPA-8XCHT1/E1-V2 (8 Port Channelized T1/E1 Module)
When Tried to build the Bill of material in cisco  CCW tool ,  finding an error  while adding  double height SPAs  (SPA-10X1GE-V2 ) , the below combination used.
Added  two ASR1000-SIP40 .sip40-NB1 ,  and excluded the SIP slot bundle  ASR1000-SIP40-NB0  which supports only  1 *10G SPA adapter
  • ASR1000-SIP40    -     2*  SPA-10X1GE-V2 ( double height SPAs)
  • ASR1000-SIP40-NB1   - 2 * SPA-10X1GE-V2 ( double height SPAs)
Tried to include the  SIP slot bundle  ASR1000-SIP40-NB0  , along with two ASR1000-SIP40 ,SIP40-NB1    , the configuration not completing and generates error. ( error attached )
  • Would like to check with you , the above customer proposed requirement can be done , please suggest
  • Also cisco data sheet says , ASR1004 can add  8 SPA , could you please suggest what are the combination  can be used ?.
