01-29-2020 03:52 PM
What would be the best way to setup a VLAN for IP Cameras so I can still remote into them and make changes?
ie.. vlan1 network computers or ip cameras
vlan2 ip cameras or network computers
I"m new to this so if someone can point me in the right direction, I just setup the vlan to test and it works, but once this setup goes 1600 miles away, I want to avoid a mess up where I would have to go back to the site with the router.
Solved! Go to Solution.
01-29-2020 06:07 PM
@Powerwav wrote:
When I plugged my pc lan into vlan200 port 2 it was fast.
That's what I said: Some don't like VLANs.
01-29-2020 06:42 PM
01-29-2020 06:45 PM
01-29-2020 03:58 PM
01-29-2020 04:10 PM
01-29-2020 04:52 PM
@Powerwav wrote:
I was able to get into the GUI But it was very slow. I probably will not use inter vlan routing, wouldn’t that defeat the purpose of a VLAN?
If you put your PC into the same VLAN as the cameras, is the performance better?
01-29-2020 05:00 PM
Yes, When I was testing, VLAN1 on port1&port2 for pc; then I made VLAN200 on port 3&4 for NVR.
Also is VLAN1 the default? I was reading that it might not be good to use it, not really sure.
01-29-2020 05:08 PM
I still like to learn this stuff, but in reality for this setup it would be used to mainly just to remote into the router to access the NVR and cams, and there will most likely be only 1 hard wired computer and a wireless AP. So is it just better to stay on VLAN1 for remote access to router and cams, I dont need access to the computer.
I would still like to know, a possible better way if there is one, ie.. access to the whole network from VPN.
Thanks...
01-29-2020 05:14 PM
Also screenshot attached:
Does this mean that VLAN1 and VLAN300 can talk to each other but not VLAN200?
01-29-2020 05:37 PM
Another ?
Lets say I want to run 4 Vlans, how do I setup the tags, I got it to work with vlan1 port 1&2 vlan200 port 3&4, but when I add more it get hard the tags keep switching around.
01-29-2020 06:07 PM
01-29-2020 06:10 PM
I guess they dont, can U help me with my last ? above. Not sure how to work all the tags.
01-29-2020 06:42 PM
01-29-2020 06:45 PM
l
Like this?
