10-27-2021 06:43 PM
Hello, I would like to know if there is a way in banding policy to cut a network the network
suppose 192.168.1.0/24 but to keep only the 192.168.1.20/24 machine active on a fail over wan 1
to date my fail over is working fine but unable to keep a machine only active on the desired network segment
10-31-2021 06:45 AM
The requirement is not clear to me, and you have not mentioned the router model as well. In case you would like to divert the traffic of a specific machine (192.168.1.20) via a specific WAN interface (WAN1) then you can try ‘Policy Based Routing’ option available in Cisco RV series routers. You may check the link for details https://www.youtube.com/watch?v=PoRiD7aojn8
10-31-2021 08:15 AM
yes thank you I found how to do it was necessary to put / 32 and no / 24 but the other point
we can change the order of priorities without erasing everything and start over in the order that the rules want
