05-27-2014 10:13 PM
I cannot connect to the SR 520 Router. The device's IP Address is 192.168.0.1 and shows up as the default gateway for client computers. I can ping the SR 520 and get replies to my pings. However, I can't telnet or ssh to the router, it tries to connect and then "connection refused".
I tried the Cisco Configuration Assistant, and putting the IP address into as a standalone device returns the message unable to connect, and when I go through Customer sites and discover by IP range, it discovers the router as 192.168.0.1, but says the Connection has failed.
Anyone have any ideas?
05-31-2014 11:16 PM
Bump. Anyone?
06-10-2014 03:45 PM
Can nobody help?
06-10-2014 04:26 PM
I have also tried a static IP in the same subnet range (I also populated the default gateway details) with the ethernet cable plugged into both the console and one of the LAN ports (although I believe that I need a ethernet to serial cable in order to use the console port), and I still cannot get the CCA to connect using any of the options I tried above.
