Hi Jason, the RVS4000 does not support intervlan communication with VPN. If you want your vlan 5 subnet to work over a VPN you will need to make a second tunnel for the vlan 5 subnet.
Smart port settings I suspect won't do the 3750 any good (aside allowing enough hosts via port security...). The reason being there is no CDP or any other advertisements from the router.
The RVS4000 if my memory serves me correctly will only support 4 vlans. So if you have vlan 1,2,3,4 trunked to a port connecting to the 3750, those are working fine, it is good. However, a 5th vlan will not work since the router does not support 5 total vlans.
-Tom
Please mark answered for helpful posts
-Tom
http://blogs.cisco.com/smallbusiness/
