Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
826
memmas nanashi
Beginner
Cisco 886VA advipservices license and not VPN?
I have a cisco886VA with c880data-universalk9-mz.154-3.M9.bin
l had DMVPN set on a 1841 and I would like to move it to this vDSL router.
Problem is that if I boot with advsecurity I have no eigrp, if I boot with advipservices I don't have VPN
        crypto engine name:  Virtual Private Network (VPN) Module
        crypto engine type:  hardware
                     State:  Enabled
              Product Name:  Onboard-VPN
                FW Version:  1
              Time running:  1226907 seconds
               Compression:  Yes
                       DES:  Yes
                     3 DES:  Yes
                   AES CBC:  Yes (128,192,256)
                  AES CNTR:  No
     Maximum buffer length:  4096
          Maximum DH index:  0050
          Maximum SA index:  0050
        Maximum Flow index:  0100
      Maximum RSA key size:  0000
        crypto engine name:  Cisco VPN Software Implementation
        crypto engine type:  software
             serial number:  D58048B2
       crypto engine state:  installed
     crypto engine in slot:  N/A
Is there a way to activate both features?
Here is my license information
Index 1 Feature: advipservices
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: advsecurity
        License State: Active, Not in Use
Index 3 Feature: ios-ips-update
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
regards
memmas
1 ACCEPTED SOLUTION
memmas nanashi
Beginner
OK.. I found the problem , still trying to resolve it on another discussion, but it's NOT a license issue....
1 REPLY 1
memmas nanashi
Beginner
