I have setup set up access rules for port 5060Tcp from a wan range to a lan single and from the same lan singel to the same WAN range.
The outgoing rule works perfectly, but the incoming rule works only for a short moment.
I have the impression that the incomming rule only works a limited number of minutes after a outgoing rule has been used.
I have installed the latest firmware (v1.4.2.19).
When I open the port 5060 in the port forwarding, it works all the time, but then there is no WAN limitation.
What adaptions to I have to make in order to make it work properly?
Thanks in advance for your assistance,
Johan Van Orshaegen
